Having difficulty with scenes
hi all
I am very new to configuring the home assistant
I am getting this error when i click ‘check config’
Error loading /config/configuration.yaml: mapping values are not allowed here
in “/config/configuration.yaml”, line 134, column 22
scene:
  - name: bedroom_normal
    entities:
      light.bedside_light
        state: 'on'
        transition: 2
        brightness_pct: 80
  - name: bedroom_dim
    entities:
      light.bedside_light
        state: 'on'
        transition: 2
        brightness_pct: 10
Any help is appreciated …
use a colon after the light. Quotes are not necessary:
    entities:
      light.bedside_light:
        state: on
        transition: 2
        brightness_pct: 80
you can btw use a nicer name i the scripts, the HA engine will create the correct scene name for you internally:
 - name: Bedroom normal
    entities:
        state: on
        transition: 2
        brightness_pct: 80
Thank you so much… will test it out…
It worked… no errors
Thank you so much
cool. please check the code above again. Below I’ve corrected a slip in the spacing of the entities: which should be in line with the name: field as follows:
   entities:
       state: on
       transition: 2
       brightness_pct: 80
