I’ve been playing around with my lovelace dashboard for a little while now, adding, removing, tweaking, slowly learning yaml and css and I wanted to share where it is today. I’m still pretty far down on the HA knowledge curve and there’s tons of stuff I want to continue to tweak and add, but it’s gotten to the point where it’s become something like what I’ve wanted it to be… a sort of dynamic, interactive window onto the world…
I’ve just managed to get css adjustments working using thomasloven’s card-mod, which opens up sooo much possibility. I think the next thing I’ll focus on is tightening the cards up further. There’s a lot of room to compress and consolidate and make room for more cool stuff!
It’s a vertical stack with a couple twists. It’s got a couple instances of the weather-forecast card set up a little differently for current weather and weekly forecast, the animated weather icon theme and the custom digital clock card. The background pulls from the live cam at Gillette Stadium which is near me so it updates when the page loads and gives an appropriate weather/time of day b/g lined up across the three vertical cards.
Nice, it was the background i was “after” … i have to weather “separated” also in vertical stack, with few entities in top, like to-days electricity-price etc. , but Clock in “Header-card”
… and was actually thinking of my “front-cam”, just didn’t knew you used cam, though is was a pic-background
oh cool… I’d like to do more with energy monitoring and electricity price would be a nice detail to get in there. The image is actually a static image… it’s a web cam at Gilette Stadium, but it’s not streaming. Most of the card b/gs are pulled from webcams, so they change every time the page loads. I do also have a few streaming videos on the page. A Boston Web Cam, a Live World Cam that steps through a bunch of international webcams, and the live feed from the ISS… and a couple security cams as well
gee, doesn’t it use quit some resources ? , thou size “matters” here i guess, and ofcause if it’s a wifi/wired devices( im thinking of 4 of my streaming cams in HQ, is about the limit, in 1 view,… thou i guess those “live web cams” uses other “techniques” through al, resolution/compression etc
I was wondering if I was going to bump into bandwidth issues! So far it hasn’t been a problem. I’ve got a pretty good connection and I don’t normally leave the dashboard open and running if I’m doing something else bandwidth intensive. I guess I use it a little differently than a typical dedicated interface screen? Though sometimes I just have it up on the screen as my ‘command center’ b/g.
(the live cams are streams from youtube through an iframe card)
At one point I had a grid with 4 different boston webcams that worked pretty well, but it seemed a little gratuitious, so I dropped it back to one and put the four cam card on another tab.
Ok, yeah endless “options” here in HA … taking too much of “free” time if one can’t control " the addiction “factor”
PS: I got lots of good ideas here tonight, thx, i also “dropped” the 4 cam view, have it on a separate webserver instead, but definitely will try with 2 small-size(background-cards) in my “overview” … and see where i end
I am working on getting this added to my home assist and appear to be a bit stuck.
When I add the customize part into my configurations.yaml, it tells me that there is no integration called ‘customize’. Is there something I need to download from HACS, or am I missing something?
Finally got it working, a bit of a struggle as I am vey new to this.
Now just to figure out how to arrange my cards the way I want them as the + and - when editing the dashboard does not zoom to get it and shuffle them in weird way that never works out.
Thank you.
