Having Issue controling Volume throught stream deck
I have a sound system from arylic it is programmed and controllable through home assistant
when i try to control it through the stream deck either by the dial or by the button i`m able to send only 1 command either reduce it by 1 step or increase by 1 step or set to a certain volume level
once it reduces 1 step the reduce command doesnt work again i must press the increase button and if it increases by 1 step it will not increase again it will only reduce
does any one have any idea on how to solve it
You are probably using the Service “Turn Volume Up” or “Turn Volume Down”.
The correct way to do it is using the Service “Set Volume” with the Service Data JSON:
{ "volume_level": {{ rotationPercent / 100 }} }
