So I am fairly new with home assistant. I have gotten my ecobee to appear on my states tab and show data. If I click the away mode button on the states tab the ecobee will go into away mode. However, any time I try and make an automation to set the ecobee in away mode it will not do anything. I was initially trying to use owntracks to set the thermostat to away mode when I left the house. (Owntracks appears to be working correctly, it will show when I am away or home).
I have tried more simple automations like having it just go into away mode at a certain time or going to away mode when I turn a light off. Neither have worked.
Here is my config.yaml:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: #
longitude: #
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 345
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/New_York
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Uncomment this to add a password (recommended!)
api_password: #
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather prediction
# sensor:
# - platform: wunderground
# api_key: ##
# monitored_conditions:
# - alerts
# - dewpoint_c
# Text to speech
tts:
- platform: google
group: !include groups.yaml
script: !include scripts.yaml
ecobee:
api_key: ###
- platform: darksky
api_key: ###
- summary
- precip_type
- precip_probability
- temperature
- dew_point
- humidity
- precip_intensity
- wind_speed
- wind_bearing
- pressure
- cloud_cover
- visibility
- icon
- nearest_storm_distance
climate:
platform: ecobee
mqtt:
broker: m13.cloudmqtt.com
port: #####
username: ##
password: ##
device_tracker:
- platform: owntracks
max_gps_accuracy: 200
waypoints: True
waypoint_whitelist:
- Oneplus3
- Iphone
ifttt:
key: ####
light:
- platform: mqtt_json
state_topic: "cabinet"
command_topic: "cabinet/set"
effect: true
effect_list:
- bpm
- candy cane
- confetti
- cyclon rainbow
- dots
- fire
- glitter
- juggle
- lightning
- noise
- police all
- police one
- rainbow
- rainbow with glitter
- ripple
- sinelon
- solid
- twinkle
brightness: true
flash: true
rgb: true
optimistic: false
qos: 0
input_slider:
porch_animation_speed:
name: Porch Animation Speed
initial: 150
min: 1
max: 150
step: 10
automation:
- alias: "Cabinet Animation Speed"
initial_state: True
hide_entity: False
- platform: state
entity_id: input_slider.porch_animation_speed
- service: mqtt.publish
data_template:
payload: '{"transition":{{ trigger.to_state.state | int }}}'
Then here is my automations.yaml (Just the most recent automation I’ve tried to get working using the automations tab on Hass.io):
- alias: Ecobee
away_mode: 'true'
entity_id: climate.home
service: climate.home
alias: Ecobee Test
condition: []
- entity_id: light.cabinet_light
platform: state
to: 'off'
I can’t figure out where I’m going wrong. Any help would be appreciated. Thanks
