I used to have a perfect working setup with my Hue bulbs connected with ZHA, where I would group them through ZHA and then I could simply create preconfigured values through the Lovelace dashboard that would apply to all lights in the group. This would work without fail, and all lights would always be synced with one press.
The Lovelace code would look something like this:
type: button
entity: light.common_room
tap_action:
action: call-service
service: light.turn_on
service_data:
brightness: 108
color_temp: 400
target: {}
Then I went and introduced a led strip that is not from the Hue brand, and I noticed the scale of what color temperature the strip would be, was way off the other bulbs.
So to fix it, I need to provide different values. One set of values to the bulbs and another set to the strip. And as I can’t provide different values in the same button as above, I needed a different approach.
My first thought was to create a scene, where I targeted a group containing all other lights than the strip with X values, and then the strip with Y values, something akin to this:
- id: '1625858692608'
entities:
light.common_room_except_strip:
brightness: 128
color_temp: 440
state: 'on'
light.dining_room_strip:
brightness: 51
color_temp: 500
state: 'on'
icon: mdi:candle
And for Lovelace:
type: button
tap_action:
service: scene.turn_on
service_data:
entity_id: scene.cozy
transition: 2
icon: mdi:candle
state_color: false
Then I could call the scene through a Lovelace button, but the issue is that now, I get a lot of failures. Almost every time, one of the lights isn’t toggled, or it only changes brightness and not color temperature. If I hit the button a couple more times, it will eventually transition and mimic the others.
It appears to be random which lamp will act out, and I have a strong Zigbee mesh, which I suppose is evident, since the first method worked.
Does anyone know what the best method to change multiple lights, with different values, with one key press?
