I’m trying to setup a platform that uses one API call to update multiple sensors. I have been directed toward using the DataUpdateCoordinator object to handle polling of the API then scheduling sensors to update based on the data it gets. It looks like a pretty slick thing to use, but I’m running into some issues.
The API library I’m using isn’t “async friendly” so I’m trying to write this platform without using async functions, but it appears that DataUpdateCoordinator needs an async function for it’s update_method parameter (I might be wrong though, the documentation I have doesn’t talk about that very much). That’s all I have been able to figure out. I’m fairly new to python (but not programming, I’m very versed in Java) and the whole concept of async programming, so please forgive my gaps of knowledge.
This is how I’m creating my coordinator.
async def async_poll_api(hass):
#poll API here, grab the things I need from it, and set it to data
return data
coordinator = DataUpdateCoordinator(
hass,
_LOGGER,
name="sensor",
update_method=async_update_data,
update_interval=timedelta(seconds=30),
and I’m getting this error message
File "/workspaces/core/homeassistant/setup.py", line 213, in _async_setup_component
result = await task
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/workspaces/core/homeassistant/components/my_custom/__init__.py", line 141, in setup
File "/workspaces/core/homeassistant/helpers/update_coordinator.py", line 57, in __init__
request_refresh_debouncer = Debouncer(
File "/workspaces/core/homeassistant/helpers/debounce.py", line 34, in __init__
self._execute_lock = asyncio.Lock()
File "/usr/local/lib/python3.8/asyncio/locks.py", line 164, in __init__
self._loop = events.get_event_loop()
File "/usr/local/lib/python3.8/asyncio/events.py", line 639, in get_event_loop
raise RuntimeError('There is no current event loop in thread %r.'
RuntimeError: There is no current event loop in thread 'SyncWorker_3'.
I hate to ask for help in situations like these, but I’ve stared at it for a long time now and have gained no progress. Any point in the right direction would be much apricated! Thank you!
