Having issues with frigate since upgrading to 0.14 from 0.13
Ive got 3 Dahua cameras 2x HDBW1430DE-SW (dont work) and a SD22404DB-GNY-W IK10 (works) they all worked in Frigate 0.13 since updating to 0.14 I can only get 1 to work Im using HAOS on a standalone (Odroid H3+) machine with 32Gb ram with a dual edge TPU
My config is as follows:
mqtt:
  enabled: true
  host: homeassistant.local
  user: username
  password: password
cameras:
  Driveway:
    enabled: true
    ffmpeg:
      hwaccel_args: preset-vaapi
      inputs:
        - path: rtsp://username:[email protected]:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
          roles:
            - record
        - path: rtsp://username:[email protected]:554/live
          roles:
            - detect
    detect:
      enabled: true
    record:
      enabled: true
detectors:
  coral1:
    type: edgetpu
    device: pci:0
  coral2:
    type: edgetpu
    device: pci:1
The error logs is as follows
Preparing Frigate...
Starting Frigate...
frigate.app                    INFO    : Starting Frigate (0.14.1-f4f3cfa)
frigate.app                    INFO    : Creating directory: /tmp/cache
frigate.util.config            INFO    : Checking if frigate config needs migration...
frigate.util.config            INFO    : frigate config does not need migration...
frigate.util.services          INFO    : Automatically detected vaapi hwaccel for video decoding
peewee_migrate.logs            INFO    : Starting migrations
peewee_migrate.logs            INFO    : There is nothing to migrate
frigate.app                    INFO    : Recording process started: 362
frigate.app                    INFO    : Recording process started: 364
frigate.app                    INFO    : go2rtc process pid: 98
detector.coral1                INFO    : Starting detection process: 391
frigate.detectors.plugins.edgetpu_tfl INFO    : Attempting to load TPU as pci:0
frigate.app                    INFO    : Output process started: 397
detector.coral2                INFO    : Starting detection process: 393
frigate.detectors.plugins.edgetpu_tfl INFO    : Attempting to load TPU as pci:1
frigate.detectors.plugins.edgetpu_tfl INFO    : TPU found
frigate.app                    INFO    : Camera processor started for Driveway: 439
frigate.app                    INFO    : Capture process started for Driveway: 441
frigate.video                  ERROR   : Driveway: Unable to read frames from ffmpeg process.
frigate.video                  ERROR   : Driveway: ffmpeg process is not running. exiting capture thread...
watchdog.Driveway              ERROR   : Ffmpeg process crashed unexpectedly for Driveway.
watchdog.Driveway              ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
ffmpeg.Driveway.detect         ERROR   : rtsp://*:*@192.168.69.80:554/live: Invalid data found when processing input
