That’s a question that the logs will help answer
alright, but i’m not sure what i should be looking for…that’s more what i was asking.
Ok you can share the logs again if you don’t understand them.
I’ve created template sensors for GPS speed for both my and my wife’s phones, as an attempt to understand when the app is getting updates from Android. I’ve converted m/s to mph, to make it easy to correlate speed data with our daily commutes.
So far, the sensor history shows that the update rate is poor, infrequent and unreliable.
Is this a valid approach to checking the reliability of the GPS data update?
No you want to look at the logs to see if reports are being skipped. The decision making process to send a location update are printed in the companion app logs. Make sure to start with the location troubleshooting steps linked earlier in this thread.
I grabbed a log file after driving in to work this morning. What’s interesting to look at?
08-30 08:41:37.946 13540 13576 D UrlRepository: localUrl is: true and usesInternalSsid is: false
08-30 08:41:39.916 13540 23735 D LocBroadcastReceiver: Background location updates appear to have stopped, restarting location updates
08-30 08:41:39.916 13540 23735 D LocBroadcastReceiver: Removing background location requests.
08-30 08:41:39.940 13540 23735 D LocBroadcastReceiver: Registering for location updates.
08-30 08:41:40.006 13540 13576 D UrlRepository: localUrl is: true and usesInternalSsid is: false
08-30 08:41:54.225 13540 13576 D LocBroadcastReceiver: Background location updates appear to have stopped, restarting location updates
08-30 08:41:54.225 13540 13576 D LocBroadcastReceiver: Removing background location requests.
08-30 08:41:54.235 13540 13576 D LocBroadcastReceiver: Registering for location updates.
08-30 08:41:54.378 13540 23735 D UrlRepository: localUrl is: true and usesInternalSsid is: false
08-30 08:42:39.303 13540 23735 D LocBroadcastReceiver: Background location updates appear to have stopped, restarting location updates
08-30 08:42:39.304 13540 23735 D LocBroadcastReceiver: Removing background location requests.
08-30 08:42:39.322 13540 23735 D LocBroadcastReceiver: Registering for location updates.
08-30 08:42:39.417 13540 13576 D UrlRepository: localUrl is: true and usesInternalSsid is: false
08-30 08:42:40.920 13540 13540 D LocBroadcastReceiver: Received location update.
08-30 08:42:40.930 13540 13540 W LocBroadcastReceiver: Location accuracy didn't meet requirements, disregarding: Location[fused ******,****** hAcc=1899.999 et=+12d0h24m8s653ms alt=135.538281664994 vAcc=20.580078 {Bundle[EMPTY_PARCEL]}]
And then later on
08-30 08:55:13.384 13540 13540 D LocBroadcastReceiver: Received location update.
08-30 08:55:13.393 13540 13540 W LocBroadcastReceiver: Location accuracy didn't meet requirements, disregarding: Location[fused xxxx,xxxx hAcc=1700.0 et=+12d0h36m42s498ms alt=135.538281664994 vAcc=24.312788 {Bundle[EMPTY_PARCEL]}]
08-30 08:55:17.817 13540 23735 D UrlRepository: localUrl is: true and usesInternalSsid is: false
08-30 08:57:13.394 13540 13540 D SensorReceiver: Received intent: android.intent.action.TIME_TICK
08-30 08:57:13.403 13540 13575 D UrlRepository: localUrl is: true and usesInternalSsid is: false
08-30 08:57:13.407 13540 13575 D UrlRepository: localUrl is: true and usesInternalSsid is: false
08-30 08:57:13.448 13540 13540 D LocBroadcastReceiver: Received location update.
08-30 08:57:13.451 13540 13540 W LocBroadcastReceiver: Location accuracy didn't meet requirements, disregarding: Location[fused xxxx,xxxxx hAcc=1700.0 et=+12d0h38m42s603ms alt=135.538281664994 vAcc=24.312788 {Bundle[EMPTY_PARCEL]}]
08-30 08:57:15.337 13540 13575 D UrlRepository: localUrl is: true and usesInternalSsid is: false
08-30 09:00:41.696 13540 13540 D SensorReceiver: Received intent: android.intent.action.TIME_TICK
08-30 09:00:41.697 13540 13540 D SensorReceiver: Received intent: android.intent.action.TIME_TICK
08-30 09:00:41.701 13540 23735 D UrlRepository: localUrl is: true and usesInternalSsid is: false
08-30 09:00:41.708 13540 23735 D UrlRepository: localUrl is: true and usesInternalSsid is: false
08-30 09:00:41.713 13540 13575 D UrlRepository: localUrl is: true and usesInternalSsid is: false
08-30 09:00:41.715 13540 13575 D UrlRepository: localUrl is: true and usesInternalSsid is: false
08-30 09:00:41.832 13540 13540 D LocBroadcastReceiver: Received location update.
08-30 09:00:41.834 13540 13540 W LocBroadcastReceiver: Location accuracy didn't meet requirements, disregarding: Location[fused xxxx,xxxx hAcc=1700.0 et=+12d0h42m10s892ms alt=135.538281664994 vAcc=24.312788 {Bundle[EMPTY_PARCEL]}]
The last log line that says it was skipped. Are those accurate coordinates that you removed? Because accuracy there is 1700 which is much higher than the default of 200.
All three lat/long values are identical, and are out by about 250 m in distance, and about 15 minutes in time from the closest I would have been to that position. I arrived at work at 09:00 but the location in the logs relates to a position I was close to, 15 minutes in the past and approx. 7 miles/11 km from where I actually was at 09:00.
To me, it’s interesting that the three values for lat, long and altitude are exactly the same - this looks like frozen data to me, rather than successive updates, even if I was stationary?
What are the units for hAcc? is a large value good or bad?
Hard to tell the report was already skipped due to accuracy. Time evaluation comes after accuracy checks.
Meters
It’s going to vary from device to device you’ll need to go by the data in the logs to determine that. If you see a lot of reports being skipped then yes you should increase the setting. Some users in rural areas will need to make the value higher, that is why it’s user configurable.
alright, i’ve started trying to tinker with this again…i can’t for the life of me get the high accuracy based on zone to work. i have it set to only apply when entering home zone, with an offset of 10k meters. it stays on when i’m home, and if i turn it off manually it never turns on. if i turn it on when i’m out (and the phone is already detecting me as away), but still inside the expanded zone, it stays on but never turns itself off when i get home.
i have no idea what i’m doing wrong, but i just can’t get this to work. ever.
lately it works sometimes, but the times it doesn’t work I don’t notice until we’re long past the point where I can get logs to find out what is going on.
example: tonight I arrived home at 12:58am, according to my person tracker. according to the high accuracy sensor, that was turned on at 12:53am which makes sense for the size of my expanded home zone. so far, so good.
however it’s now 3:23am and I just noticed that HA mode is still on. it never turned off when I got home…and now the earliest log I have is 3:01am, which is useless.
is there a way to extend how long the logs are saved for before being cycled?
it happened again tonight. we arrived home about 2 hours ago, and just now i noticed that HA mode is still on. as such, the logs are again useless.
can anyone help me figure this out? it’s so insanely frustrating…
