Having issues with media player after setting up duckDNS and SSL
Set up home assistant ssl duck
dns and I can’t even use the media player so when every time I use the media player this error appears image attached below
Resurrecting an old thread…I’m encountering the same error message with DuckDNS and SSL.
Tried setting the internal and external URL as shown in Setup basic information - Home Assistant, with several variations including having both set to my DuckDNS domain, setting the internal to my local IP, both with and without SSL.
I was able to get rid of the original error message with some of the config changes, but have had no luck streaming audio to a Muse Proto board I’m testing, without disabling SSL entirely and accessing via my local HA IP address.
Hello! I did something!! I still tested
