Having Problems getting Temperatures of Fibaro Smart Implant
Hello Everyone,
for first im new here in Forum and English is not my native Language, so i apologize strict in the beginning.
I have bought an Fibaro Smart Implant and trying to get this to work with some DS18B20 Temperature Sensors. (Its to get some Pool Temperatures)
I got the Implant to Work, getting some Entities, looks fine. The 2 Switches are useable in Home Assistant and are working fine in the Implant. The inclusion Process made no Mistakes.
But heres the Problem:
Wether the intern Temperatur oft the Implant, nor any connected Sensor works. Its shown as entity and has a Random Temperatur. The Implant mostly got about 30 °C and on or 2 Sensors about 27 °C etc.
I tried already to add and remove the device, reset the device, change the Temperature Sensors and finaly pulled up the data signal of the Sensor with a 4,7k Resistor from the VCC. Nothing helps. Its always the same in Home Assistant. Its shown a Temperature which doesnt move.
So anyone got the Smart Implant to work with temperature Sensors?
The Implant is on Firmware 5.1
Home Assistant is on 2021.06.08
Z-Wave Integration is: Zwave JS
Thanks for ur help :slight_smile:
Same issue here. Anyone got this to work?
I have the same problem.
I have two devices. 1. FGBS222 and 2.FGBS001
Both devices don’t show the three DS18B20 that I conected.
It is a pity that there is no documentation to solve this problem, please if anyone can help I appreciate it
I have a Fibaro Smart implant that came in yesterday. I powered it up and joined it hoping to use it as a repeater as I was setting up a thermostat in an out building and was having connection issues. Then I tried to set up the implant with some DS18b20’s (HiLetgo) and could not make it work.
I learned that I have to wire things up, remove the implant from the network and add it back. During the joining process it probes the sensors. I started with one, it found it/
Then I powered the implant down, and added three more sensors. The implant didn’t see the new three sensors on power up, I had to remove the implant and add it back to z-wave and then I saw all four.
Old thread but I searched and this was one that didn’t seem to have an answer.
Same problem, probably because I had it up and running before. Did this way to restore function. (Using a Zstick gen5+ interface):
Unpowered SmartImplant. (HomeAssistant wont remove if unit is answering a ping.)
Removed it from HomeAssistant, a forced remove.
Powered up SmartImplant.
Did a factory reset of the SmartImplant. (Hold button until yellow, a short confirm click, should turn into red indicating factory reset. See SmartImplant manual. (This will make HA think that it really is a new unit and ask for security PIN-code when adding it. And really forget my previous instance…))
Added again into HomeAssistant. (Add unit in HA, three short klicks on the SmartImplant, answered with PIN-code when prompted by HA-interface, got the unit successfully added, and heureka…)
Now I can see my two DS18B20 sensors again…
I have added the Fibaro smart implant in Home Assistant and I notice that I cannot see the inputs IN1 and IN2 under sensors.
With the previous module Fibaro Universal Binary Sensor I do see the inputs IN1 and IN2 under sensor and they work perfectly, so I think it is a shame that they are no longer made and the replacement does not work in Home Assistant.
My Home Assistant runs on an ODROID XU4 and an Aeotec Z-Stick Gen 5.
Does anyone have a solution for this mentioned problem?
It would be a huge step forward for me because now I am forced to use the Shelly UNI as a replacement module, which does work, but I am personally just as much a fan of it because the PCB is not so well protected because it has no housing and the antenna is mounted rather fragilely to the PCB.
