i’m having some issues trying to add 4 Aqara switches to my Zigbee devices.
I’m using ZHA and when i add a WXKG03LM it adds the device with only a battery entity
I tried readding the device several times but everytime is the same result.
I’m a beginner with HA (i’m going to migrate away from Homey) and i just need a few control switches for the WAF ![:wink: :wink:](https://community.home-assistant.io/images/emoji/twitter/wink.png?v=9)
Thanks in advance for any help/suggestions!
gijsje
(Gijs)
2
Thats normal you will not see the switches there.
If you make an automation over the automation editor you can use the switch there
well i’ll be…thanks!
i can see it in the automation;
![image](https://community-assets.home-assistant.io/original/3X/b/c/bc74d1616d1bcb3e0313a9bc53977028f689c62c.png)
now, for the bonus round…
i’m making my automations in NodeRed.
in NodeRed i need to use the entity_id property.
How could i use this switch in NodeRed?
(Thanks again for the pointer!)
hello
did you fix it?
I have the same problem,and i don’t know how to fix it.
can you help me?
tmaniac
5
i switched to Zigbee2MQTT and everything works way better ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=10)
