muddro
(Muddro)
1
I’ve had this issue with a normal esp32wroom and then bought and flashed the GL-S10.
INFO ESPHome 2023.9.1
INFO Reading configuration /config/esphome/gl-s10-bt-proxy-ce9b84.yaml...
WARNING GPIO12 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO15 is a Strapping PIN and should be avoided.
INFO Starting log output from gl-s10-bt-proxy-ce9b84.local using esphome API
WARNING Can't connect to ESPHome API for gl-s10-bt-proxy-ce9b84.local: Error resolving IP address: [Errno -5] No address associated with hostname (APIConnectionError)
INFO Trying to connect to gl-s10-bt-proxy-ce9b84.local in the background
INFO Successfully connected to gl-s10-bt-proxy-ce9b84.local
[14:53:06][I][app:102]: ESPHome version 2023.9.1 compiled on Sep 29 2023, 14:03:29
[14:53:06][I][app:104]: Project esphome.bluetooth-proxy version 1.0
[14:53:06][C][status_led:019]: Status LED:
[14:53:06][C][status_led:020]: Pin: GPIO32
[14:53:06][C][logger:357]: Logger:
[14:53:06][C][logger:358]: Level: DEBUG
[14:53:06][C][logger:359]: Log Baud Rate: 115200
[14:53:06][C][logger:361]: Hardware UART: UART0
[14:53:06][C][i2c.idf:061]: I2C Bus:
[14:53:06][C][i2c.idf:062]: SDA Pin: GPIO15
[14:53:06][C][i2c.idf:063]: SCL Pin: GPIO13
[14:53:06][C][i2c.idf:064]: Frequency: 50000 Hz
[14:53:06][C][i2c.idf:067]: Recovery: bus successfully recovered
[14:53:06][I][i2c.idf:077]: Results from i2c bus scan:
[14:53:06][I][i2c.idf:079]: Found no i2c devices!
[14:53:06][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Reset Button'
[14:53:06][C][gpio.binary_sensor:016]: Pin: GPIO33
[14:53:06][C][gpio.output:010]: GPIO Binary Output:
[14:53:06][C][gpio.output:011]: Pin: GPIO14
[14:53:06][C][gpio.output:012]: Inverted: YES
[14:53:06][C][gpio.output:011]: Pin: GPIO12
[14:53:06][C][bluetooth_proxy:088]: Bluetooth Proxy:
[14:53:06][C][bluetooth_proxy:089]: Active: YES
[14:53:06][C][safe_mode.button:022]: Safe Mode Button 'Safe Mode Boot'
[14:53:06][C][safe_mode.button:022]: Icon: 'mdi:restart-alert'
[14:53:06][C][esp32_ble:238]: ESP32 BLE:
[14:53:06][C][esp32_ble:240]: MAC address: C8:F0:9E:CE:9B:86
[14:53:06][C][esp32_ble:241]: IO Capability: none
[14:53:07][C][esp32_ble_tracker:617]: BLE Tracker:
[14:53:07][C][esp32_ble_tracker:618]: Scan Duration: 300 s
[14:53:07][C][esp32_ble_tracker:619]: Scan Interval: 1100.0 ms
[14:53:07][C][esp32_ble_tracker:620]: Scan Window: 1100.0 ms
[14:53:07][C][esp32_ble_tracker:621]: Scan Type: ACTIVE
[14:53:07][C][esp32_ble_tracker:622]: Continuous Scanning: True
[14:53:07][C][ethernet:221]: Ethernet:
[14:53:07][C][ethernet:363]: IP Address: 192.168.10.18
[14:53:07][C][ethernet:364]: Hostname: 'gl-s10-bt-proxy-ce9b84'
[14:53:07][C][ethernet:365]: Subnet: 255.255.255.0
[14:53:07][C][ethernet:366]: Gateway: 192.168.10.1
[14:53:07][C][ethernet:375]: DNS1: 10.10.10.10
[14:53:07][C][ethernet:376]: DNS2: 0.0.0.0
[14:53:07][C][ethernet:397]: MAC Address: C8:F0:9E:CE:9B:87
[14:53:07][C][ethernet:402]: Is Full Duplex: YES
[14:53:07][C][ethernet:407]: Link Speed: 100
[14:53:07][C][ethernet:224]: Power Pin: 5
[14:53:07][C][ethernet:226]: MDC Pin: 23
[14:53:07][C][ethernet:227]: MDIO Pin: 18
[14:53:07][C][ethernet:228]: Type: IP101
[14:53:07][C][ethernet:229]: PHY addr: 1
[14:53:07][C][mdns:115]: mDNS:
[14:53:07][C][mdns:116]: Hostname: gl-s10-bt-proxy-ce9b84
[14:53:07][C][ota:097]: Over-The-Air Updates:
[14:53:07][C][ota:098]: Address: gl-s10-bt-proxy-ce9b84.local:3232
[14:53:07][C][api:138]: API Server:
[14:53:07][C][api:139]: Address: gl-s10-bt-proxy-ce9b84.local:6053
[14:53:07][C][api:141]: Using noise encryption: YES
[14:53:24][D][api:102]: Accepted 192.168.20.36
[14:53:24][W][component:204]: Component api took a long time for an operation (0.05 s).
[14:53:24][W][component:205]: Components should block for at most 20-30ms.
[14:53:24][D][api.connection:1031]: Home Assistant 2023.9.3 (192.168.20.36): Connected successfully
[14:53:24][I][bluetooth_proxy:278]: [0] [D6:D1:7A:A9:54:BC] Connecting v3 with cache
[14:53:24][D][esp32_ble_tracker:214]: Pausing scan to make connection...
[14:53:24][I][esp32_ble_client:064]: [0] [D6:D1:7A:A9:54:BC] 0x01 Attempting BLE connection
[14:53:25][I][esp32_ble_client:144]: [0] [D6:D1:7A:A9:54:BC] Connected
[14:53:25][D][esp32_ble_tracker:246]: Starting scan...
[14:53:28][I][bluetooth_proxy:278]: [1] [FD:A4:66:1B:45:4B] Connecting v3 with cache
[14:53:28][D][esp32_ble_tracker:214]: Pausing scan to make connection...
[14:53:28][I][esp32_ble_client:064]: [1] [FD:A4:66:1B:45:4B] 0x01 Attempting BLE connection
[14:53:29][D][esp-idf:000]: W (34107) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x3e
[14:53:30][I][esp32_ble_client:144]: [1] [FD:A4:66:1B:45:4B] Connected
[14:53:30][D][esp32_ble_tracker:246]: Starting scan...
[14:53:33][I][esp32_ble_client:081]: [0] [D6:D1:7A:A9:54:BC] Disconnecting.
[14:53:33][D][esp-idf:000]: W (38272) BT_HCI: hci cmd send: disconnect: hdl 0x0, rsn:0x13
[14:53:33][D][esp-idf:000]: W (38277) BT_APPL: gattc_conn_cb: if=3 st=0 id=3 rsn=0x16
[14:53:33][D][esp-idf:000]: W (38280) BT_APPL: gattc_conn_cb: if=4 st=0 id=4 rsn=0x16
[14:53:33][D][esp-idf:000]: W (38282) BT_APPL: gattc_conn_cb: if=5 st=0 id=5 rsn=0x16
[14:53:33][D][esp-idf:000]: W (38285) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x16
[14:53:51][I][bluetooth_proxy:282]: [0] [44:D7:B4:7C:A8:8E] Connecting v3 without cache
[14:53:51][D][esp32_ble_tracker:214]: Pausing scan to make connection...
[14:53:51][I][esp32_ble_client:064]: [0] [44:D7:B4:7C:A8:8E] 0x01 Attempting BLE connection
[14:53:52][I][esp32_ble_client:196]: [0] [44:D7:B4:7C:A8:8E] Connected
[14:53:52][D][esp32_ble_tracker:246]: Starting scan...
[14:53:52][I][esp32_ble_client:081]: [0] [44:D7:B4:7C:A8:8E] Disconnecting.
[14:53:52][D][esp-idf:000]: W (57142) BT_HCI: hci cmd send: disconnect: hdl 0x0, rsn:0x13
[14:53:52][D][esp-idf:000]: W (57145) BT_APPL: gattc_conn_cb: if=3 st=0 id=3 rsn=0x16
[14:53:52][D][esp-idf:000]: W (57149) BT_APPL: gattc_conn_cb: if=4 st=0 id=4 rsn=0x16
[14:53:52][D][esp-idf:000]: W (57151) BT_APPL: gattc_conn_cb: if=5 st=0 id=5 rsn=0x16
[14:53:52][D][esp-idf:000]: W (57165) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x16
[14:53:54][I][esp32_ble_client:081]: [1] [FD:A4:66:1B:45:4B] Disconnecting.
[14:53:54][D][esp-idf:000]: W (59509) BT_HCI: hci cmd send: disconnect: hdl 0x1, rsn:0x13
[14:53:54][D][esp-idf:000]: W (59512) BT_APPL: gattc_conn_cb: if=3 st=0 id=259 rsn=0x16
[14:53:54][D][esp-idf:000]: W (59514) BT_APPL: gattc_conn_cb: if=4 st=0 id=260 rsn=0x16
[14:53:54][D][esp-idf:000]: W (59515) BT_APPL: gattc_conn_cb: if=5 st=0 id=261 rsn=0x16
[14:53:54][D][esp-idf:000]: W (59526) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x16
[14:54:07][I][bluetooth_proxy:278]: [0] [FD:A4:66:1B:45:4B] Connecting v3 with cache
[14:54:07][D][esp32_ble_tracker:214]: Pausing scan to make connection...
[14:54:07][I][esp32_ble_client:064]: [0] [FD:A4:66:1B:45:4B] 0x01 Attempting BLE connection
[14:54:07][I][esp32_ble_client:144]: [0] [FD:A4:66:1B:45:4B] Connected
[14:54:07][D][esp32_ble_tracker:246]: Starting scan...
[14:54:16][I][esp32_ble_client:081]: [0] [FD:A4:66:1B:45:4B] Disconnecting.
[14:54:16][D][esp-idf:000]: W (81208) BT_HCI: hci cmd send: disconnect: hdl 0x0, rsn:0x13
[14:54:16][D][esp-idf:000]: W (81211) BT_APPL: gattc_conn_cb: if=3 st=0 id=3 rsn=0x16
[14:54:16][D][esp-idf:000]: W (81214) BT_APPL: gattc_conn_cb: if=4 st=0 id=4 rsn=0x16
[14:54:16][D][esp-idf:000]: W (81215) BT_APPL: gattc_conn_cb: if=5 st=0 id=5 rsn=0x16
[14:54:16][D][esp-idf:000]: W (81226) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x16
[14:54:22][I][bluetooth_proxy:282]: [0] [63:08:1D:C8:88:4A] Connecting v3 without cache
[14:54:22][D][esp32_ble_tracker:214]: Pausing scan to make connection...
[14:54:22][I][bluetooth_proxy:282]: [1] [7F:B2:B4:36:B7:53] Connecting v3 without cache
[14:54:22][I][esp32_ble_client:064]: [0] [63:08:1D:C8:88:4A] 0x01 Attempting BLE connection
[14:54:31][I][bluetooth_proxy:278]: [2] [FD:A4:66:1B:45:4B] Connecting v3 with cache
[14:54:32][I][esp32_ble_client:081]: [0] [63:08:1D:C8:88:4A] Disconnecting.
[14:54:32][I][esp32_ble_client:064]: [1] [7F:B2:B4:36:B7:53] 0x01 Attempting BLE connection
[14:54:32][D][esp-idf:000]: W (97226) BT_L2CAP: L2CAP - LE - cannot start new connection at conn st: 1
[14:54:32][I][esp32_ble_client:064]: [2] [FD:A4:66:1B:45:4B] 0x01 Attempting BLE connection
[14:54:32][D][esp-idf:000]: W (97248) BT_L2CAP: L2CAP - LE - cannot start new connection at conn st: 1
[14:54:51][I][esp32_ble_client:081]: [2] [FD:A4:66:1B:45:4B] Disconnecting.
[14:54:52][D][esp-idf:000]: W (117260) BT_APPL: gattc_conn_cb: if=3 st=0 id=3 rsn=0x100
[14:54:52][D][esp-idf:000]: W (117266) BT_APPL: gattc_conn_cb: if=4 st=0 id=4 rsn=0x100
[14:54:52][D][esp-idf:000]: W (117267) BT_APPL: gattc_conn_cb: if=5 st=0 id=5 rsn=0x100
[14:54:52][D][esp-idf:000]: W (117274) BT_APPL: gattc_conn_cb: if=3 st=0 id=259 rsn=0x2
[14:54:52][D][esp-idf:000]: W (117277) BT_APPL: gattc_conn_cb: if=4 st=0 id=260 rsn=0x2
[14:54:52][D][esp-idf:000]: W (117278) BT_APPL: gattc_conn_cb: if=5 st=0 id=261 rsn=0x2
[14:54:52][W][esp32_ble_client:134]: [0] [] Connection failed, status=133
[14:54:52][W][esp32_ble_client:134]: [1] [] Connection failed, status=133
[14:54:57][I][bluetooth_proxy:278]: [0] [D6:D1:7A:A9:54:BC] Connecting v3 with cache
[14:54:57][I][esp32_ble_client:064]: [0] [D6:D1:7A:A9:54:BC] 0x01 Attempting BLE connection
[14:54:58][D][esp-idf:000]: W (122696) BT_L2CAP: L2CAP - LE - cannot start new connection at conn st: 1
[14:55:10][I][bluetooth_proxy:282]: [1] [40:7C:62:DE:D5:4E] Connecting v3 without cache
[14:55:17][I][esp32_ble_client:081]: [0] [D6:D1:7A:A9:54:BC] Disconnecting.
[14:55:17][I][esp32_ble_client:064]: [1] [40:7C:62:DE:D5:4E] 0x01 Attempting BLE connection
[14:55:17][D][esp-idf:000]: W (142692) BT_L2CAP: L2CAP - LE - cannot start new connection at conn st: 1
[14:55:20][I][esp32_ble_client:081]: [1] [40:7C:62:DE:D5:4E] Disconnecting.
After this usually the switchbot blinds are usually inaccessible. I have 3 of them connected.
muddro
(Muddro)
2
happens everytime over the course o like 3 to 4 minutes:
[16:23:16][I][app:102]: ESPHome version 2023.9.1 compiled on Sep 29 2023, 15:06:57
[16:23:16][I][app:104]: Project esphome.bluetooth-proxy version 1.0
[16:23:16][C][status_led:019]: Status LED:
[16:23:16][C][status_led:020]: Pin: GPIO32
[16:23:16][C][logger:357]: Logger:
[16:23:16][C][logger:358]: Level: DEBUG
[16:23:16][C][logger:359]: Log Baud Rate: 115200
[16:23:16][C][logger:361]: Hardware UART: UART0
[16:23:16][C][i2c.idf:061]: I2C Bus:
[16:23:16][C][i2c.idf:062]: SDA Pin: GPIO15
[16:23:16][C][i2c.idf:063]: SCL Pin: GPIO13
[16:23:16][C][i2c.idf:064]: Frequency: 50000 Hz
[16:23:16][C][i2c.idf:067]: Recovery: bus successfully recovered
[16:23:16][I][i2c.idf:077]: Results from i2c bus scan:
[16:23:16][I][i2c.idf:079]: Found no i2c devices!
[16:23:16][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Reset Button'
[16:23:16][C][gpio.binary_sensor:016]: Pin: GPIO33
[16:23:16][C][gpio.output:010]: GPIO Binary Output:
[16:23:16][C][gpio.output:011]: Pin: GPIO14
[16:23:16][C][gpio.output:012]: Inverted: YES
[16:23:16][C][gpio.output:011]: Pin: GPIO12
[16:23:16][C][bluetooth_proxy:088]: Bluetooth Proxy:
[16:23:16][C][bluetooth_proxy:089]: Active: YES
[16:23:16][C][safe_mode.button:022]: Safe Mode Button 'Safe Mode Boot'
[16:23:16][C][safe_mode.button:022]: Icon: 'mdi:restart-alert'
[16:23:16][C][restart.button:017]: Restart Button 'Restart Bluetooth Proxy'
[16:23:16][C][esp32_ble:238]: ESP32 BLE:
[16:23:16][C][esp32_ble:240]: MAC address: C8:F0:9E:CE:9B:86
[16:23:16][C][esp32_ble:241]: IO Capability: none
[16:23:16][C][esp32_ble_tracker:617]: BLE Tracker:
[16:23:16][C][esp32_ble_tracker:618]: Scan Duration: 300 s
[16:23:16][C][esp32_ble_tracker:619]: Scan Interval: 1100.0 ms
[16:23:16][C][esp32_ble_tracker:620]: Scan Window: 1100.0 ms
[16:23:16][C][esp32_ble_tracker:621]: Scan Type: ACTIVE
[16:23:16][C][esp32_ble_tracker:622]: Continuous Scanning: True
[16:23:16][C][ethernet:221]: Ethernet:
[16:23:16][C][ethernet:363]: IP Address: 192.168.10.18
[16:23:16][C][ethernet:364]: Hostname: 'gl-s10-bt-proxy-ce9b84'
[16:23:16][C][ethernet:365]: Subnet: 255.255.255.0
[16:23:16][C][ethernet:366]: Gateway: 192.168.10.1
[16:23:16][C][ethernet:375]: DNS1: 10.10.10.10
[16:23:16][C][ethernet:376]: DNS2: 0.0.0.0
[16:23:16][C][ethernet:397]: MAC Address: C8:F0:9E:CE:9B:87
[16:23:16][C][ethernet:402]: Is Full Duplex: YES
[16:23:16][C][ethernet:407]: Link Speed: 100
[16:23:16][C][ethernet:224]: Power Pin: 5
[16:23:16][C][ethernet:226]: MDC Pin: 23
[16:23:16][C][ethernet:227]: MDIO Pin: 18
[16:23:16][C][ethernet:228]: Type: IP101
[16:23:16][C][ethernet:229]: PHY addr: 1
[16:23:16][C][mdns:115]: mDNS:
[16:23:16][C][mdns:116]: Hostname: gl-s10-bt-proxy-ce9b84
[16:23:16][C][ota:097]: Over-The-Air Updates:
[16:23:16][C][ota:098]: Address: gl-s10-bt-proxy-ce9b84.local:3232
[16:23:16][C][api:138]: API Server:
[16:23:16][C][api:139]: Address: gl-s10-bt-proxy-ce9b84.local:6053
[16:23:16][C][api:141]: Using noise encryption: YES
[16:23:26][D][api:102]: Accepted 192.168.20.36
[16:23:26][W][component:204]: Component api took a long time for an operation (0.05 s).
[16:23:26][W][component:205]: Components should block for at most 20-30ms.
[16:23:26][D][api.connection:1031]: Home Assistant 2023.9.3 (192.168.20.36): Connected successfully
[16:23:27][I][bluetooth_proxy:282]: [0] [4C:BA:D7:64:9D:05] Connecting v3 without cache
[16:23:27][D][esp32_ble_tracker:214]: Pausing scan to make connection...
[16:23:27][I][esp32_ble_client:064]: [0] [4C:BA:D7:64:9D:05] 0x00 Attempting BLE connection
[16:23:27][I][bluetooth_proxy:278]: [1] [C8:CC:44:C6:94:E0] Connecting v3 with cache
[16:23:27][I][bluetooth_proxy:278]: [2] [D6:D1:7A:A9:54:BC] Connecting v3 with cache
[16:23:37][I][esp32_ble_client:081]: [0] [4C:BA:D7:64:9D:05] Disconnecting.
[16:23:37][I][esp32_ble_client:064]: [1] [C8:CC:44:C6:94:E0] 0x01 Attempting BLE connection
[16:23:37][D][esp-idf:000]: W (46479) BT_L2CAP: L2CAP - LE - cannot start new connection at conn st: 1
[16:23:47][I][esp32_ble_client:081]: [1] [C8:CC:44:C6:94:E0] Disconnecting.
[16:23:47][I][esp32_ble_client:064]: [2] [D6:D1:7A:A9:54:BC] 0x01 Attempting BLE connection
[16:23:47][D][esp-idf:000]: W (56539) BT_L2CAP: L2CAP - LE - cannot start new connection at conn st: 1
[16:23:57][D][esp-idf:000]: W (66522) BT_APPL: gattc_conn_cb: if=3 st=0 id=3 rsn=0x100
[16:23:57][D][esp-idf:000]: W (66527) BT_APPL: gattc_conn_cb: if=4 st=0 id=4 rsn=0x100
[16:23:57][D][esp-idf:000]: W (66528) BT_APPL: gattc_conn_cb: if=5 st=0 id=5 rsn=0x100
[16:23:57][D][esp-idf:000]: W (66536) BT_APPL: gattc_conn_cb: if=3 st=0 id=259 rsn=0x2
[16:23:57][D][esp-idf:000]: W (66539) BT_APPL: gattc_conn_cb: if=4 st=0 id=260 rsn=0x2
[16:23:57][D][esp-idf:000]: W (66540) BT_APPL: gattc_conn_cb: if=5 st=0 id=261 rsn=0x2
[16:23:57][W][esp32_ble_client:134]: [0] [] Connection failed, status=133
[16:23:57][W][esp32_ble_client:134]: [1] [] Connection failed, status=133
[16:23:57][I][bluetooth_proxy:278]: [0] [C8:CC:44:C6:94:E0] Connecting v3 with cache
[16:23:57][I][esp32_ble_client:064]: [0] [C8:CC:44:C6:94:E0] 0x01 Attempting BLE connection
[16:23:57][I][esp32_ble_client:144]: [0] [C8:CC:44:C6:94:E0] Connected
[16:23:57][I][esp32_ble_client:144]: [2] [D6:D1:7A:A9:54:BC] Connected
[16:23:57][D][esp32_ble_tracker:246]: Starting scan...
[16:23:58][I][bluetooth_proxy:278]: [1] [FD:A4:66:1B:45:4B] Connecting v3 with cache
[16:23:58][D][esp32_ble_tracker:214]: Pausing scan to make connection...
[16:23:58][I][esp32_ble_client:064]: [1] [FD:A4:66:1B:45:4B] 0x01 Attempting BLE connection
[16:23:58][I][esp32_ble_client:144]: [1] [FD:A4:66:1B:45:4B] Connected
[16:23:58][D][esp32_ble_tracker:246]: Starting scan...
[16:24:05][I][esp32_ble_client:081]: [0] [C8:CC:44:C6:94:E0] Disconnecting.
[16:24:05][D][esp-idf:000]: W (75385) BT_HCI: hci cmd send: disconnect: hdl 0x0, rsn:0x13
[16:24:05][D][esp-idf:000]: W (75388) BT_APPL: gattc_conn_cb: if=3 st=0 id=3 rsn=0x16
[16:24:05][D][esp-idf:000]: W (75390) BT_APPL: gattc_conn_cb: if=4 st=0 id=4 rsn=0x16
[16:24:05][D][esp-idf:000]: W (75391) BT_APPL: gattc_conn_cb: if=5 st=0 id=5 rsn=0x16
[16:24:05][D][esp-idf:000]: W (75414) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x16
[16:24:07][I][esp32_ble_client:081]: [1] [FD:A4:66:1B:45:4B] Disconnecting.
[16:24:07][D][esp-idf:000]: W (76458) BT_HCI: hci cmd send: disconnect: hdl 0x2, rsn:0x13
[16:24:07][D][esp-idf:000]: W (76461) BT_APPL: gattc_conn_cb: if=3 st=0 id=259 rsn=0x16
[16:24:07][D][esp-idf:000]: W (76463) BT_APPL: gattc_conn_cb: if=4 st=0 id=260 rsn=0x16
[16:24:07][D][esp-idf:000]: W (76465) BT_APPL: gattc_conn_cb: if=5 st=0 id=261 rsn=0x16
[16:24:07][D][esp-idf:000]: W (76472) BT_HCI: hcif disc complete: hdl 0x2, rsn 0x16
[16:24:07][W][bluetooth_proxy:246]: [2] [D6:D1:7A:A9:54:BC] Connection already established
[16:24:15][I][esp32_ble_client:081]: [2] [D6:D1:7A:A9:54:BC] Disconnecting.
[16:24:15][D][esp-idf:000]: W (85307) BT_HCI: hci cmd send: disconnect: hdl 0x1, rsn:0x13
[16:24:15][D][esp-idf:000]: W (85311) BT_APPL: gattc_conn_cb: if=3 st=0 id=515 rsn=0x16
[16:24:15][D][esp-idf:000]: W (85315) BT_APPL: gattc_conn_cb: if=4 st=0 id=516 rsn=0x16
[16:24:15][D][esp-idf:000]: W (85317) BT_APPL: gattc_conn_cb: if=5 st=0 id=517 rsn=0x16
[16:24:15][D][esp-idf:000]: W (85321) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x16
[16:24:47][I][bluetooth_proxy:282]: [0] [66:03:91:B3:5A:C0] Connecting v3 without cache
[16:24:47][D][esp32_ble_tracker:214]: Pausing scan to make connection...
[16:24:47][I][bluetooth_proxy:282]: [1] [5F:04:29:FB:1E:DA] Connecting v3 without cache
[16:24:47][I][esp32_ble_client:064]: [0] [66:03:91:B3:5A:C0] 0x01 Attempting BLE connection
[16:24:47][I][bluetooth_proxy:282]: [2] [4B:EA:1A:B5:6F:BA] Connecting v3 without cache
[16:24:57][I][esp32_ble_client:081]: [0] [66:03:91:B3:5A:C0] Disconnecting.
[16:24:57][I][esp32_ble_client:064]: [1] [5F:04:29:FB:1E:DA] 0x01 Attempting BLE connection
[16:24:57][D][esp-idf:000]: W (126501) BT_L2CAP: L2CAP - LE - cannot start new connection at conn st: 1
[16:24:57][I][esp32_ble_client:064]: [2] [4B:EA:1A:B5:6F:BA] 0x01 Attempting BLE connection
[16:24:57][D][esp-idf:000]: W (126523) BT_L2CAP: L2CAP - LE - cannot start new connection at conn st: 1
[16:25:17][D][esp-idf:000]: W (146529) BT_APPL: gattc_conn_cb: if=3 st=0 id=3 rsn=0x100
[16:25:17][D][esp-idf:000]: W (146535) BT_APPL: gattc_conn_cb: if=4 st=0 id=4 rsn=0x100
[16:25:17][D][esp-idf:000]: W (146536) BT_APPL: gattc_conn_cb: if=5 st=0 id=5 rsn=0x100
[16:25:17][D][esp-idf:000]: W (146543) BT_APPL: gattc_conn_cb: if=3 st=0 id=259 rsn=0x2
[16:25:17][D][esp-idf:000]: W (146546) BT_APPL: gattc_conn_cb: if=4 st=0 id=260 rsn=0x2
[16:25:17][D][esp-idf:000]: W (146547) BT_APPL: gattc_conn_cb: if=5 st=0 id=261 rsn=0x2
[16:25:17][W][esp32_ble_client:134]: [0] [] Connection failed, status=133
[16:25:17][W][esp32_ble_client:134]: [1] [] Connection failed, status=133
[16:26:55][I][bluetooth_proxy:282]: [0] [40:CA:63:3B:AE:C7] Connecting v3 without cache
[16:26:55][I][esp32_ble_client:064]: [0] [40:CA:63:3B:AE:C7] 0x00 Attempting BLE connection
[16:26:55][D][esp-idf:000]: W (245132) BT_L2CAP: L2CAP - LE - cannot start new connection at conn st: 1
[16:27:05][I][esp32_ble_client:081]: [0] [40:CA:63:3B:AE:C7] Disconnecting.
[16:27:46][I][bluetooth_proxy:282]: [1] [40:CA:63:36:FB:DD] Connecting v3 without cache
[16:27:46][I][esp32_ble_client:064]: [1] [40:CA:63:36:FB:DD] 0x00 Attempting BLE connection
[16:27:46][D][esp-idf:000]: W (296037) BT_L2CAP: L2CAP - LE - cannot start new connection at conn st: 1
[16:27:51][I][ota:117]: Boot seems successful, resetting boot loop counter.
[16:27:51][D][esp32.preferences:114]: Saving 1 preferences to flash...
[16:27:51][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[16:27:56][I][esp32_ble_client:081]: [1] [40:CA:63:36:FB:DD] Disconnecting.
