Hi, I put together an automation that turns on the hallway light in case my young kids get up and need to use the bathroom at night.
I have it doing the following:
When one of two motion sensors are triggered, and if the hallway light is off, if one of the sensors reads 5 lux or below and it is between 11pm and 5am, then it will turn the hallway light on to 1%.
Then it waits 5 minutes until after both sensors no longer sense motion, then it turns the hallway lights off.
The problem I am having is that even during those hours, after we put the kids to bed and leave the hallway, it turns the lights off (runs the second part of the automation) - so that portion is not basing on the conditions of the earlier part of the automation.
SO, do I need to put the same conditions in for the second part of that script? Or is there a better way to write this one? The YAML is below. Thank you in advance for any suggestions you may have.
-David
alias: Upstairs Hallway Light Nightlight
description: ""
- type: occupied
platform: device
device_id: 68faaf0f5a59cb30107c523211b8999b
entity_id: binary_sensor.signify_netherlands_b_v_sml003_occupancy
domain: binary_sensor
- type: occupied
platform: device
device_id: c1b63420a875d0684491d17dc34c277a
entity_id: binary_sensor.signify_netherlands_b_v_sml003_occupancy_2
condition:
- condition: and
conditions:
- condition: device
type: is_off
device_id: 6ec14e2f80a802049b7f8ddb81cf18b2
entity_id: light.upstairs_hallway_lights
domain: light
- type: is_illuminance
condition: device
entity_id: sensor.signify_netherlands_b_v_sml003_illuminance
domain: sensor
below: 5
- condition: time
after: "23:00:00"
before: "05:00:00"
enabled: true
- type: turn_on
domain: light
brightness_pct: 1
- wait_for_trigger:
- type: not_occupied
platform: device
for:
hours: 0
minutes: 5
seconds: 0
- wait_for_trigger:
platform: device
for:
hours: 0
minutes: 5
seconds: 0
- type: turn_off
domain: light
mode: single
Oh, and one other part - I currently have this as a separate automation, unless it makes more sense to add it to the one above, but when either motion detector is tripped, and when the master bedroom is closed (door sensor), it turns a switch on so we know one of the kids is up.
Thanks!!
alias: Master Bedroom notification light
description: ""
- type: occupied
platform: device
- type: occupied
platform: device
condition:
- condition: and
conditions:
- condition: device
type: is_off
domain: light
- type: is_not_open
condition: device
device_id: c13bd69b3d14a51fbd090b8fa67278c4
entity_id: binary_sensor.lumi_lumi_sensor_magnet_aq2_opening
- condition: time
after: "22:00:00"
before: "05:00:00"
weekday:
- sat
- fri
- thu
- wed
- tue
- mon
- sun
- type: turn_on
device_id: 2f38853dd14a6815e0962791aa95badb
entity_id: switch.signify_netherlands_b_v_lom010_switch
domain: switch
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- type: turn_off
domain: switch
mode: single
Are you saying that you leave the hallway light on at full power after putting them to bed and it turns off, which it shouldnât?
FYI, you donât need the âcondition: andâ under the condition section, as it defaults to checking all conditions.
But Iâd recommend putting the two wait_for_triggers into one,
- wait_for_trigger:
- condition: and
conditions:
platform: device
for:
hours: 0
minutes: 5
seconds: 0
platform: device
for:
hours: 0
minutes: 5
seconds: 0
Also not sure if that before and after would work in the time condition, as its saying less than 5 AND more than 23. Try:
- condition: template
value_template: "{{5<now().hour<=23}}"
Yes, correct. When we put them to bed, we leave the hallway light on, until we go to bed. I donât want anything triggering (either on or off) until the hallway light is turned off at night and the light level is low.
Your suggestions makes sense, though - I will give that a try!
Thanks so much!!
Whoops, the time template should actually be
value_template: "{{now().hour<5 or now().hour>=23}}"
I believe your automation may be triggering before you turn on the hallway light to put them to bed, so itâs turning off after 5min of unoccupied.
Maybe replace the âdevice⌠is_offâ in the condition section with (the below check is based on a scale of 0-256, not 0-100 percent)
- condition: numeric_state
attribute: brightness
below: 5
When I use the following code (copied from your example), I get this error message:
Message malformed: required key not provided @ data['action'][1]['wait_for_trigger'][0]['platform']
- wait_for_trigger:
- condition: and
conditions:
platform: device
for:
hours: 0
minutes: 5
seconds: 0
platform: device
for:
hours: 0
minutes: 5
seconds: 0
Not sure what that meansâŚ
Thanks!!
-David
OK, seems like it doesnât like:
- condition: and
conditions:
I was able to remove the second âwait for triggerâ but canât add the Condition AND
Please let me know if you have any ideas.
Thanks!
I usually use templates, but yeah it apparently doesnât like âandâ under wait_for_trigger.
This should work:
- wait_for_trigger:
value_template: >-
{{states.binary_sensor.signify_netherlands_b_v_sml003_occupancy.state=='off' &&
as_timestamp(now())-as_timestamp(states.binary_sensor.signify_netherlands_b_v_sml003_occupancy.last_changed)>300
&& states.binary_sensor.signify_netherlands_b_v_sml003_occupancy_2.state=='off' &&
as_timestamp(now())-as_timestamp(states.binary_sensor.signify_netherlands_b_v_sml003_occupancy_2.last_changed)>300}}
checks that both sensors are unoccupied (off) and have been for at least 300 seconds (5min)
Argh, it still isnât liking that. Here is my full updated code as of right now. This has all the changes minus the last one you gave meâŚ
description: ""
- type: occupied
platform: device
- type: occupied
platform: device
condition:
below: 5
condition: device
domain: sensor
below: 5
value_template: "{{now().hour<5 or now().hour>=23}}\""
- type: turn_on
domain: light
brightness_pct: 1
- wait_for_trigger:
platform: device
for:
hours: 0
minutes: 5
seconds: 0
platform: device
for:
hours: 0
minutes: 5
seconds: 0
- type: turn_off
domain: light
mode: single
template didnât like &&, had to switch to âandâ.
here is full revisions (removed an extra quotation you added in time template too)
description: ""
- type: occupied
platform: device
- type: occupied
platform: device
condition:
below: 5
condition: device
domain: sensor
below: 5
- type: turn_on
domain: light
brightness_pct: 1
- wait_for_trigger:
value_template: >-
{{states.binary_sensor.signify_netherlands_b_v_sml003_occupancy.state=='off' and
and states.binary_sensor.signify_netherlands_b_v_sml003_occupancy.state=='off' and
as_timestamp(now())-as_timestamp(states.binary_sensor.signify_netherlands_b_v_sml003_occupancy.last_changed)>300}}
- type: turn_off
domain: light
mode: single
OK, no errors there. That looks goodâŚthank you so much for this! Iâll let it run and make sure it works as intended.
One last question for you. I would like to put the indicator light in on this same automation, if possible - instead of making it a separate automation. Would you suggest that, or just leave it as itâs own automation?
This part would turn on a switch for 30 seconds in the master bedroom, only when the master bedroom door sensor is closed, and when the above automation runs. It is just so we know when the kids get up at night.
description: ""
- type: occupied
platform: device
- type: occupied
platform: device
condition:
- condition: and
conditions:
- condition: device
type: is_off
domain: light
- type: is_not_open
condition: device
- condition: time
after: "22:00:00"
before: "05:00:00"
weekday:
- sat
- fri
- thu
- wed
- tue
- mon
- sun
- type: turn_on
domain: switch
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- type: turn_off
domain: switch
mode: single
Iâm sure this part is more complex than it needs to be, especially since it is currently its own automation.
Thanks again.
You can simply insert it into former automation (all transplanted code is contained within the âifâ action)
description: ""
- type: occupied
platform: device
- type: occupied
platform: device
condition:
below: 5
condition: device
domain: sensor
below: 5
- type: turn_on
domain: light
brightness_pct: 1
- if:
- type: is_not_open
condition: device
then:
- type: turn_on
domain: switch
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- type: turn_off
domain: switch
- wait_for_trigger:
value_template: >-
- type: turn_off
domain: light
mode: single
Because itâs and
and not &&
I would also strongly suggest you avoid using all these device triggers and conditions and rather use entities and states directly. It will be a lot cleaner, simpler and more maintainable. There are various posts on that particular topic if you want to know more.
Troon
(Troon)
May 4, 2023, 7:04am
14
Agreed. So, for example, this:
- type: occupied
platform: device
- type: occupied
platform: device
becomes this:
- platform: state
entity_id:
- binary_sensor.signify_netherlands_b_v_sml003_occupancy
- binary_sensor.signify_netherlands_b_v_sml003_occupancy_2
to: 'on'
Hmmm, I will paste my code below, but something is broken now - the motion detectors trigger, but the lights donât turn on. Any help would be appreciated!!
description: ""
- platform: state
entity_id:
to: "on"
condition:
below: 5
condition: device
domain: sensor
below: 5
- type: turn_on
domain: light
brightness_pct: 1
- if:
- type: is_not_open
condition: device
then:
- type: turn_on
domain: switch
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- type: turn_off
domain: switch
- wait_for_trigger:
value_template: >-
and
and
and
- type: turn_off
domain: light
mode: single
Troon
(Troon)
May 4, 2023, 8:43am
16
Look at the automation trace and see whatâs stopping it. My guess is the illuminance sensor is above 5 as itâs the daytime; and itâs also not between 23:00 and 05:00.
xiport
May 4, 2023, 11:33pm
17
I guess the problem with the first condition is that when the light is off, there is no brightness attribute, so this wonât ever trigger unless the hall light is on at 1%.
Change the numeric_state condition back to your original is_off condition and itâll bring your code back to the way it originally worked before, but with some updated parts and the second automation added in.
Without knowing all the events that are happening in your house, itâs hard to figure out how to stop your original problem of âturning off the hall lights when you want them to stay on.â I still think you were triggering the automation before you turned on the hall lights to put them to bed, so the numeric_state attribute condition could be used to check if you split the code into two automations (one to turn on the lights, one to turn off), or using a bunch of if-else.
Like the guy above said, would have to look at the traces and full logbook and know what calls are being made to manually turn on your lights, etc.
