Having trouble creating service for custom integration
I have a custom integration im trying to create services for but it’s been difficult finding updated docs that follow the current best practices. I have one sensor and two services I’d like to register that save presistent data somewhere. This is what I have so far:
async def async_setup(hass: HomeAssistant, config: ConfigType):
    store = Store(hass, version=1, key=DOMAIN)
    await store.async_load()
    async def ignore_tracking_number(call: ServiceCall) -> None:
        _LOGGER.debug('Received ignore_tracking_number', call.data)
        tracking_number = call.data['tracking_number']
        ignored_tracking_numbers = store.get('ignored_tracking_numbers', [])
        if tracking_number not in ignored_tracking_numbers:
            ignored_tracking_numbers.append(tracking_number)
            await store.async_save({"ignored_tracking_numbers": ignored_tracking_numbers})
            _LOGGER.debug(f'Updated ignored_tracking_numbers: {ignored_tracking_numbers}')
        else:
            _LOGGER.debug('Tracking number is already ignored')
        return {'ignored_tracking_numbers': ignored_tracking_numbers}
    hass.services.async_register(DOMAIN, 'ignore_tracking_number', ignore_tracking_number)
    async def unignore_tracking_number(call: ServiceCall) -> None:
        _LOGGER.debug('Received unignore_tracking_number', call.data)
        ignored_tracking_numbers = store.get("ignored_tracking_numbers", [])
        tracking_number = call.data["tracking_number"]
        if tracking_number in ignored_tracking_numbers:
            ignored_tracking_numbers.remove(tracking_number)
            _LOGGER.debug(f"Updated ignored_tracking_numbers: {ignored_tracking_numbers}")
        else:
            _LOGGER.debug(f"Tracking number {tracking_number} is not currently ignored")
        return {"ignored_tracking_numbers": ignored_tracking_numbers}
    hass.services.async_register(DOMAIN, 'unignore_tracking_number', unignore_tracking_number)
async def async_setup_platform(
    config: ConfigType,
    add_entities: AddEntitiesCallback,
    discovery_info: DiscoveryInfoType | None = None
    hass.data[DOMAIN] = {}
    add_entities([TrackingNumberEntity(config, hass)], True)
The entity is made but the services dont register. I also have a schema for the services but have no idea where to put this
SERVICE_SCHEMA = vol.Schema({
    vol.Required("tracking_number"): cv.string,
    vol.Required("entity_id"): cv.string,
Do you have a services.yaml file?
hey yes my servies file is:
ignore_tracking_number:
  description: Add Tracking Number to Ignored List
  fields:
    tracking_number:
      description: Tracking Number
      example: '1234567890'
      required: true
    entity_id:
      description: Entity ID
      example: sensor.user_gmail_com_tracking_numbers
      required: true
unignore_tracking_number:
  description: Remove Tracking Number from Ignored List
  fields:
    tracking_number:
      required: true
    entity_id:
      required: true
then i try to make the service call from the custom card:
this.hass.callService(
  'tracking_numbers',
    entity_id: 'sensor.entity_id',
    tracking_number: 'xxx'
and i get sent back:
Service tracking_numbers.ignore_tracking_number not found
