Evening all.
I am having trouble running Node-Red on the latest version of Openmediavault (7), as a docker container.
I am using the following docker compose file:
services:
node-red:
image: nodered/node-red:latest
user: 1001:100
environment:
- TZ=Europe/London
ports:
- "1880:1880"
volumes:
- /srv/dev-disk-by-uuid-85c4513d-cfd9-4134-ad11-5d6552e81a81/appdata/node-red/data:/data
but keep getting this docker error when I try to run it:
node-red-1 | node:fs:3035
node-red-1 | binding.copyFile(
node-red-1 | ^
node-red-1 |
node-red-1 | Error: EACCES: permission denied, copyfile '/usr/src/node-red/node_modules/node-red/settings.js' -> '/data/settings.js'
node-red-1 | at Object.copyFileSync (node:fs:3035:11)
node-red-1 | at copyFile (/usr/src/node-red/node_modules/fs-extra/lib/copy/copy-sync.js:64:6)
node-red-1 | at onFile (/usr/src/node-red/node_modules/fs-extra/lib/copy/copy-sync.js:50:25)
node-red-1 | at getStats (/usr/src/node-red/node_modules/fs-extra/lib/copy/copy-sync.js:42:44)
node-red-1 | at Object.copySync (/usr/src/node-red/node_modules/fs-extra/lib/copy/copy-sync.js:32:10)
node-red-1 | at Object.<anonymous> (/usr/src/node-red/node_modules/node-red/red.js:148:20)
node-red-1 | at Module._compile (node:internal/modules/cjs/loader:1469:14)
node-red-1 | at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
node-red-1 | at Module.load (node:internal/modules/cjs/loader:1288:32)
node-red-1 | at Module._load (node:internal/modules/cjs/loader:1104:12) {
node-red-1 | errno: -13,
node-red-1 | code: 'EACCES',
node-red-1 | syscall: 'copyfile',
node-red-1 | path: '/usr/src/node-red/node_modules/node-red/settings.js',
node-red-1 | dest: '/data/settings.js'
node-red-1 | }
node-red-1 |
node-red-1 | Node.js v20.17.0
node-red-1 | ^
node-red-1 |
node-red-1 | }
node-red-1 |
END OF LINE
Any pointers, on how to get things running, would be much appreciated.
