Did you ever manage to resolve this?
I’m having that same issue… tox fails on typing tests, log extracts below.
I followed the instructions on https://developers.home-assistant.io/docs/en/development_environment.html
What I’ve tried:
- running my tests towards the intact dev branch, as is, without doing any changes
- running as a user
- running as user with sudo
- running as root
- tried on Ubuntu 18.04 WSL, AND Ubuntu Server 18.04 x86
Results
SKIPPED: py35: InterpreterNotFound: python3.5
py36: commands succeeded
SKIPPED: py37: InterpreterNotFound: python3.7
SKIPPED: py38: InterpreterNotFound: python3.8
lint: commands succeeded
pylint: commands succeeded
ERROR: typing: commands failed
cov: commands succeeded
Logs:
typing inst-nodeps: /home/karim/test2/home-assistant/.tox/.tmp/package/1/homeassistant-0.89.0.dev0.zip
typing installed: aiohttp==3.5.4,asn1crypto==0.24.0,astral==1.9.2,astroid==2.1.0,async-timeout==3.0.1,asynctest==0.12.2,atomicwrites==1.3.0,attrs==18.2.0,bcrypt==3.1.5,certifi==2018.11.29,cffi==1.12.1,chardet==3.0.4,coverage==4.5.2,coveralls==1.2.0,cryptography==2.5,docopt==0.6.2,entrypoints==0.3,flake8==3.7.5,flake8-docstrings==1.3.0,flake8-polyfill==1.0.2,homeassistant==0.89.0.dev0,idna==2.8,idna-ssl==1.1.0,isort==4.3.4,Jinja2==2.10,lazy-object-proxy==1.3.1,MarkupSafe==1.1.0,mccabe==0.6.1,mock-open==1.3.1,more-itertools==6.0.0,multidict==4.5.2,mypy==0.660,mypy-extensions==0.4.1,packaging==19.0,pluggy==0.8.1,py==1.8.0,pycodestyle==2.5.0,pycparser==2.19,pydocstyle==3.0.0,pyflakes==2.1.0,PyJWT==1.6.4,pylint==2.2.2,pyparsing==2.3.1,pytest==4.2.1,pytest-aiohttp==0.3.0,pytest-cov==2.6.1,pytest-sugar==0.9.2,pytest-timeout==1.3.3,python-slugify==1.2.6,pytz==2018.9,PyYAML==3.13,requests==2.21.0,requests-mock==1.5.2,ruamel.yaml==0.15.88,six==1.12.0,snowballstemmer==1.2.1,termcolor==1.1.0,typed-ast==1.2.0,typing-extensions==3.7.2,Unidecode==1.0.23,urllib3==1.24.1,voluptuous==0.11.5,voluptuous-serialize==2.1.0,wrapt==1.11.1,yarl==1.3.0
typing run-test-pre: PYTHONHASHSEED='1987861804'
typing runtests: commands[0] | /bin/bash -c 'mypy homeassistant/*.py homeassistant/{auth,util}/ homeassistant/helpers/{__init__,aiohttp_client,area_registry,condition,deprecation,dispatcher,entity_values,entityfilter,icon,intent,json,location,signal,state,sun,temperature,translation,typing}.py'
homeassistant/monkey_patch.py:66: note: unused 'type: ignore' comment
homeassistant/__main__.py:375: warning: Returning Any from function declared to return "int"
ERROR: InvocationError for command '/bin/bash -c mypy homeassistant/*.py homeassistant/{auth,util}/ homeassistant/helpers/{__init__,aiohttp_client,area_registry,condition,deprecation,dispatcher,entity_values,entityfilter,icon,intent,json,location,signal,state,sun,temperature,translation,typing}.py' (exited with code 1)
