I am trying to get started with MQTT in Home Assistant, but I am running into trouble. So far I have:
- Installed the Mosquitto MQTT broker add-on
- Set up a new user called “mqttuser”
- Flashed Tasmota on a 3-relay light switch
- Configured MQTT in Tasmota
It seems like it is connecting to Home Assistant, but auto discovery is not working and neither is manually creating a switch entity in the config file.
MQTT Add-On Log:
[19:34:49] INFO: Setup mosquitto configuration
[19:34:49] WARNING: SSL not enabled - No valid certs found!
[19:34:49] INFO: No local user available
[19:34:49] INFO: Initialize Hass.io Add-on services
[19:34:49] INFO: Initialize Home Assistant discovery
[19:34:49] INFO: Start Mosquitto daemon
1590546889: mosquitto version 1.6.3 starting
1590546889: Config loaded from /etc/mosquitto.conf.
1590546889: Loading plugin: /usr/share/mosquitto/auth-plug.so
1590546889: ├── Username/password checking enabled.
1590546889: |-- *** auth-plug: startup
1590546889: ├── TLS-PSK checking enabled.
1590546889: └── Extended authentication not enabled.
1590546889: Opening ipv4 listen socket on port 1883.
1590546889: Opening ipv6 listen socket on port 1883.
1590546889: Opening websockets listen socket on port 1884.
1590546889: Warning: Mosquitto should not be run as root/administrator.
1590546889: New connection from 192.168.1.21 on port 1883.
[INFO] found mqttuser on Home Assistant
1590546890: New client connected from 192.168.1.21 as mqtt-explorer-a2fcf87a (p2, c1, k60, u'mqttuser').
1590546896: New connection from 192.168.1.11 on port 1883.
1590546896: New client connected from 192.168.1.11 as DVES_7F0E2B (p2, c1, k30, u'mqttuser').
1590546992: New connection from 172.30.32.1 on port 1883.
[WARN] Not found homeassistant on local database
1590546993: Socket error on client <unknown>, disconnecting.
MQTT Configuration:
logins: []
anonymous: false
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
Tasmota Console (while attempting manual config):
03:34:55 MQT: Attempting connection...
03:34:55 MQT: Connected
03:34:55 MQT: tele/SW_LRoom/LWT = Online (retained)
03:34:55 MQT: cmnd/SW_LRoom/POWER =
03:35:39 MQT: tele/SW_LRoom/STATE = {"Time":"2020-05-27T03:35:39","Uptime":"0T00:50:09","UptimeSec":3009,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":4,"POWER1":"ON","POWER2":"OFF","POWER3":"OFF","Wifi":{"AP":1,"SSId":"NetworkOT_Downstairs","BSSId":"B6:FB:E4:AB:C9:E3","Channel":11,"RSSI":98,"Signal":-51,"LinkCount":1,"Downtime":"0T00:00:03"}}```
Any ideas what I’m doing wrong?
