Having trouble starting zigbee2mqtt
I’m trying to setup zigbee2mqtt for the first time and I’m running into problems. Here’s my log file and my configuration.yaml file:
[18:39:06] INFO: Preparing to start...
[18:39:06] INFO: Socat not enabled
[18:39:07] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2024-10-15 18:39:09] info: 	z2m: Logging to console, file (filename: log.log)
[2024-10-15 18:39:09] info: 	z2m: Starting Zigbee2MQTT version 1.40.2 (commit #unknown)
[2024-10-15 18:39:09] info: 	z2m: Starting zigbee-herdsman (2.1.3)
[2024-10-15 18:39:10] error: 	zh:zstack:znp: Failed to determine if path is valid: 'Error: spawn udevadm ENOENT'
[2024-10-15 18:39:10] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231219140307-if00","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-10-15 18:39:10] info: 	zh:zstack:znp: Serialport opened
[2024-10-15 18:39:10] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-10-15 18:39:11] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-10-15 18:39:11] error: 	z2m: Error while starting zigbee-herdsman
[2024-10-15 18:39:11] error: 	z2m: Failed to start zigbee
[2024-10-15 18:39:11] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-10-15 18:39:11] error: 	z2m: Exiting...
[2024-10-15 18:39:11] error: 	z2m: Error: Error: Not supported, cannot set
/app/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264
  var er = new ERR_STREAM_WRITE_AFTER_END();
Error: write after end
    at writeAfterEnd (/app/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264:12)
    at DerivedLogger.Writable.write (/app/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:300:21)
    at DerivedLogger.log (/app/node_modules/winston/lib/winston/logger.js:231:12)
    at Logger.log (/app/lib/util/logger.ts:198:25)
    at Logger.info (/app/lib/util/logger.ts:211:14)
    at Znp.onPortClose (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:96:16)
    at Object.onceWrapper (node:events:632:26)
    at SerialPort.emit (node:events:529:35)
    at port.close.then.closing (/app/node_modules/@serialport/stream/dist/index.js:242:18)
Configuration.yaml
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  server: mqtt://localhost:1883
serial:
  port: >-
I also tried using port: /dev/ttyACM0 as that is the device path but I’m getting the same error.
Thanks for any help
How are your running z2m? Addon? Docker? Whatever?
What is the output of
ls -l /dev/ttyACM0
I figured out the problem. I had to update the firmware of my sonos to the latest version. I was multiple versions behind. Once I did that I was able to get setup.
