Having Trouble understanding value_templates
I’m on the latest version of HA running on a RP4. I had the following and it was working. As I added more weather items they all started showing up unknown instead of the data. Reverting back did not solve the problem and WeatherTemp continued to show up as unknown.
  - state_topic: "CumulusMX/Test"
    value_template: '{{ value_json["temp"] }}'
    unit_of_measurement: "°F"
MQTT Explorer is showing me this:
If I remove value template, and go check the WeatherTemp entity it shows me this:
I can’t figure out what I’m doing wrong with the value_template
    icon: mdi:thermometer-water
    value_template: '{{ value_json["Dew"] }}'
    name: "Weather Inside Temp"
    value_template: '{{ value_json["intemp"] }}'
    unique_id: uniqueid__weather_intemp_f
    name: "1Weather Wind Direction"
    icon: mdi:weather-windy
    value_template: '{{ value_json["wdir"] }}'
    unit_of_measurement: "°"
I did realize that, I assumed that because I saw updates from the MQTT plugin screen that I should also see them from the entities.
Separate mqtt.yaml
Not seeing anything related in the logs either.
I figured it out!
my formatting of the mqtt output from Cumulus MX was off.
{"topics":[
        "topic": "CumulusMX/Interval",
        "data": "{
                    \"time\":\"<#timehhmmss>\"
                    ,\"temp\":<#temp rc=y>
                    ,\"humidity\":<#hum>
                    ,\"wgust\":<#wgust rc=y>
        "retain": false
