I have been running ESPHome for a while and was using it to monitor the state of my home battery. A few months back, my code just stopped working (the LEDs do nothing) and I haven’t managed to work out what’s wrong with it.
Could someone please cast their eye over the code below and let me know what I’m doing wrong?
Just a couple of notes:
- I am getting valid metrics from HA for the state of the battery.
- I can’t get the LED ring to light up at all, unless I use the On/Off switch that’s in the Integrations view within HA (which proves that my wiring is correct).
I suspect my Lambda function is wonky somehow…
TIA
esphome:
friendly_name: PowerWall-Charge
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "3uPrg7z24b0acogeYdAa5PGZwLYMpFtWLIbkxvIb89g="
ota:
password: "5181bf54d8269ffe1e21d25dce844299"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Powerwall-Charge"
password: "cbGiviI5u1o4"
captive_portal:
light:
- platform: neopixelbus
type: GRB
variant: WS2812
pin: GPIO14
num_leds: 24 #change this to the number of LEDS in your strip
name: "NeoPixel LED Ring"
effects:
- addressable_lambda:
lambda: |-
const int leds_to_use=it.size(); // you can change that if you don't want all the leds to be used
float battery_percentage = id(powerwall_charge).state;
if (isnan(battery_percentage)) {
battery_percentage = 0;
// number of leds that are drawn with full brightness
int full_leds = int(leds_to_use*battery_percentage/100.0);
// set those leds to the current_color of the light
if (id(powerwall_status).state){
Color blue(0,0,255);
it[0] = blue;
else {
Color blue_low(0,127,127);
it[0] = blue_low;
Color red(204,0,0);
it.range(1, 6) = red;
Color orange(255,165,0);
it.range(6,12) = orange;
Color yellow(255,255,0);
it.range(12,18) = yellow;
Color green(0,255,0);
it.range(18,24) = green;
//set the remaing leds to black
if (full_leds+1 < leds_to_use) {
it.range(full_leds+1, leds_to_use) = ESPColor::BLACK; // change the color to something else if you want
- platform: homeassistant
name: "Tesla Powerwall Charge"
entity_id: sensor.powerwall_charge
binary_sensor:
name: "Tesla Powerwall Charge State"
entity_id: binary_sensor.powerwall_charging
