I have upgrades from a very old HA and having trouble setting up my mqtt hvac thermostat.
I get the reading from a sensor in my Livingroom, and turning on a relay to turn my heat on. But I can not get it to come on when I raise the temperature I’m missing something but can not figure out what.
climate:
- platform: mqtt
modes:
- "off"
- "cool"
- "fan_only"
swing_modes:
- "on"
- "off"
fan_modes:
- "high"
- "medium"
- "low"
power_command_topic: "study/ac/power/set"
mode_command_topic: "study/ac/mode/set"
temperature_command_topic: "cmnd/furnace/POWER"
current_temperature_topic: "Home/LivingRoom/temp"
fan_mode_command_topic: "study/ac/fan/set"
swing_mode_command_topic: "study/ac/swing/set"
precision: 1.0
I’m not sure if the cmnd/furnace/POWER is in the right place I tried all, when I put it in the power_command_topic: the relay will turn on when I turn on the heat, but will not when raising the temperature. hope some one can help me see what I’m missing. Thanks
I put the Code in the brackets but it said it still wasn’t.
