Having troubles with Lovelace interface and Honeywell TH6320ZW2003 Thermostat
Hello forum!
I’m very new to home automation, Home Assistant, and Z-Wave networks, but I’m a lifelong nerd…
I’ve successfully connected 5 dimmer switches and 1 Honeywell thermostat (I think). The issue I’m having is that the Lovelace control panel doesn’t update when I send commands through the touchscreen interface.
Example: if I press the power, heat, or cool button, the thermostat LCD changes and the HVAC system responds accordingly, confirming the thermostat received the command. However the state does not change on the Lovelace control panel.
I’m a noob… What am I doing wrong? Let me know what other information about my setup may be required to resolve this dilemma.
Thanks in advance!
