Hayward pool heater with custom component
Hi everyone!
I’m happy to share that I got my Hayward pool heat pump connected to Home Assistant.
I used a Wemos D1 mini with a TTL to RS485 adapter and wrote a custom ESPHome component to interface with it, pulling sensor data and controlling settings like temperature and mode.
This is the device:
And here are some screenshots from Home Assistant.
The project is fully documented here: Hayward heat pump - connecting to ESPHome and HomeAssistant | Leontin Chiru
The new components is in the hayward branch of my esphome fork.
This branch also has some changes to the modbus component that I made.
If anyone has a similar heat pump, please give it a try.
The yaml configuration needed to use it:
uart:
  tx_pin: 1
  rx_pin: 3
  baud_rate: 9600
logger:
  baud_rate: 0
external_components:
  - source:
    type: git
    url: https://github.com/cleontin/esphome
    ref: hayward
  components: [ modbus, hayward ]
modbus:
  flow_control_pin: 2
  role: server
hayward:
  accept_broadcast: true
  server_address: 2
time:
  platform: homeassistant
I’m looking forward for any type of feedback.
Thanks!
Awesome project! I’m a little curious if this will work with some of their other heat pump models. I’ve got a summit
Hi Mike
This should work with models that have the option to add an external control panel with a four wire interface (modbus).
Looking at the Summit model, I think it does not suport an external control panel but it does have remote control input via terminals P and S. From the diagrams, it seems like you can connect a relay to the P and S terminals and use it to switch between the pool and spa profiles, allowing for some level of control.
Hi! If anyone is interested I created custom component which does not require esphome fork: GitHub - grandalos/hayward: ESPHome external component for Hayward heat pumps with PC1002 over RS485, with climate control and schedule support · GitHub
this is still experimental release but feel free to test it
Hey Leontin,
Awesome work btw, I pushed forward and made a PCB to tidy things up alittle, happy to share the file once I can prove it all works
When I try to flash the D1 Mini, I’m getting a schema issue error in ESPHome. Claude is suggesting it is due to ESPHome 2026.3.3 changes.
This is kind of above my level, but does your github need updating to reflect these changes and that is why its failing? Or is it something I can change my side?
INFO ESPHome 2026.3.3
INFO Reading configuration /config/esphome/hayward-heatpump.yaml...
ERROR Unexpected exception while reading configuration:
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/esphome/esphome/__main__.py", line 1925, in <module>
    sys.exit(main())
  File "/esphome/esphome/__main__.py", line 1916, in main
    return run_esphome(sys.argv)
  File "/esphome/esphome/__main__.py", line 1895, in run_esphome
    config = read_config(
  File "/esphome/esphome/config.py", line 1323, in read_config
    res = load_config(command_line_substitutions, skip_external_update)
  File "/esphome/esphome/config.py", line 1180, in load_config
    return _load_config(command_line_substitutions, skip_external_update)
  File "/esphome/esphome/config.py", line 1168, in _load_config
    return validate_config(config, command_line_substitutions, skip_external_update)
  File "/esphome/esphome/config.py", line 1059, in validate_config
    target_platform = core_config.preload_core_config(config, result)
  File "/esphome/esphome/core/config.py", line 404, in preload_core_config
    if _is_target_platform(domain):
  File "/esphome/esphome/core/config.py", line 354, in _is_target_platform
    return get_component(name, True).is_target_platform
  File "/esphome/esphome/loader.py", line 235, in get_component
    return _lookup_module(domain, exception)
  File "/esphome/esphome/loader.py", line 211, in _lookup_module
    module = importlib.import_module(f"esphome.components.{domain}")
  File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 999, in exec_module
  File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
  File "/data/external_components/50eec081/esphome/components/hayward/__init__.py", line 339, in <module>
    cv.Optional(s[CONF_KEY], default={}): switch.switch_schema(
TypeError: switch_schema() missing 1 required positional argument: 'class_'
Had a play and with the help of Claude. I think I’ve managed to get it flashed correctly.
Still waiting on the RS485 to TTL component to arrive to test with heatpump but can now see entities in Home Assistant
Had to fork it to make the changes, but to not take away from @cleontin will remove if/when he updates his repository
Ended up making these changes to line 339
cv.Optional(s[CONF_KEY], default={}): switch.switch_schema(switch.Switch,
and line 359
cv.Optional(s[CONF_KEY], default={}): climate._CLIMATE_SCHEMA.extend(cv.COMPONENT_SCHEMA).extend(
Hey Tandarra,
Thanks for using this and for the list of changes. I’ve been trying to figure out how to get this to compile with the new esphome. I’ll include your changes soon.
I’m also planning to re-work this component. It should live on a repo of it’s own, not a full clone of esphome. And I’ll be trying to make it work with the standard modbus, since some of the changes I needed are already there.
I’ll update here when I manage to get that done.
Your board looks nice. It would be a great improvement for what I have right now, and maybe the perfect start for me into ordering custom PCBs. It would be nice if you could share it here or in github.
Its the first PCB I have made so isn’t perfect.
I used easyeda.com to design online - EasyEDA(Standard) - A Simple and Powerful Electronic Circuit Design Tool
It uses a library of custom components from users and components from LCSC which then can be taken over to JLCPCB to manufacture.
One of the components I think the mini buck converter has its GND set to the wrong pad or I simply couldn’t figure out how to change polarity and connect the track correctly, so the simple fix is to change pins on the JST connector physically. I’m sure you will see the issue when you load it up
But have a look and let me know what you think, fix it up and I’ll delete my repository once yours is updated to not confuse anyone.
First of all, thank you very much to all of your for sharing your works, it looks very promising !
I have a very similar heat pump which is manufactured by PHNIX. The exact brand is PPP model Prime 18, probably just another clone. The touch screen interface is exactly the same as the Hayward, and the PCB also looks pretty similar (model name 2AC32I26WO1) :
Mine even offers external screw terminals to wire an external RS485 device without opening the mainboard housing :slight_smile: (although there is no 12V there, but that's not really a problem as my ESP is a few meters away in the pool house with an external power supply).
I will use an ESP32 with a MAX3485 module. This last one works with 3.3V and doesn't have the RE/DE pins, it's supposed to be handled automatically.
I gave it a quick try with @grandalos version above, as it didn't require a custom ESPHome nor RE/DE pins, but it didn't work. The ESP did receive some packets, but always ended with this error "Dropping partial frame with x bytes after timeout".
I plan to also give a try to @cleontin version, but I am not sure that it can work for me as I have a different RS485 module without the RE/DE pins. By the way I also saw that you are working on a new version with the standard ESPHome modbus, did you had any progress with that already ?
Last question, I read that the standard RS485 wiring should include a 120 ohm terminal resistance at each end, between the A and B wires, did you use that ? My cabling is a bit longer than yours, somewhere like 4-5 meters, so maybe I get those errors because I am missing the resistance. I Just ordered some so give it a try.
Have a good one !
Most modules have 120 ohm onboard with a solder pads to enable/disable.
Also, some "MAX3485" modules don't actually use that chip at all but MS2548 that is actually 5V IC.
Some modules also have TX/RX swapped.
Thank you very much @Karosm , I didn't pay attention but indeed my module has such solder pads, it was written on the back of the module :sweat_smile: I am gonna give it a try. Do you think that I should put an other resistor on the heat pump side as well ?
Here are the the pictures of my MAX3485, it seems to be named TTL485 V2.0
It's unbelievable what you can do with IA those days ! I got the code fully written and working with all adresses from the documented protocol, working fine with the latest ESPHome version :tada:
One trap that made me lose a lot of time, on the MAX3485 you have to wire the GPIO used for TX to the RXD pin, and the GPIO used for RX to the TXD pin. It sounded like the opposite was logic to me, but I was wrong. I also soldered the 120 ohm internal resistor of the MAX3485.
After that I wired everything on the other side the 2 RS485 A+ and B- , but also the GND coming from my heat pump.
Here is the code that I have generated thanks to Google AI. I didn't check the sensors yet and there are many controls that you should probably not touch at all without risking to break your heat pump, but at the moment I just wanted to map everything possible and clean up later.
This is just the first step for me, I don't plan to use the code as it is, but I just wanted to share it here already because I am so excited :partying_face:
PS: I had to add the value 46 in the map table of H12 Type de Compresseur because my compressor model was not listed in the protocol documentation
PS 2: sorry I was talking to Google in french, so all the sensors were translated :stuck_out_tongue:
substitutions:
  friendly_name: "ESP32 PAC"
esphome:
  friendly_name: esp32-pac
  comment: "DIY ESP32 for PAC Modbus"
  compile_process_limit: 1
esp32:
  board: esp32dev
  framework:
    type: esp-idf
wifi:
  networks:
    - ssid: "xxxxxx"
      password: "xxxxxx0"
  fast_connect: true
  ap:
    ssid: ${friendly_name}
    ap_timeout: 1min
captive_portal:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxx"
ota:
  - platform: esphome
    password: "xxxxxxxx"
logger:
  level: DEBUG
uart:
  - id: modbus_bus
    tx_pin: GPIO17
    rx_pin: GPIO16
    baud_rate: 9600
    stop_bits: 1
    data_bits: 8
    parity: NONE
modbus:
  uart_id: modbus_bus
modbus_controller:
  - id: phnix_pac
    address: 1
    modbus_id: mx_modbus
    update_interval: 10s
# --- COMMANDES ET PARAMÈTRES INTERRUPTEURS (Read / Write) -----------
switch:
  - platform: modbus_controller
    name: "PAC Marche/Arrêt"
    register_type: holding
    address: 1011           # 1011 (3F3h) : 0=OFF / 1=ON
    bitmask: 1
    name: "H01 Rémargage Automatique Désactivé"
    address: 1018           # 1018 (3FAh) : 0=Non (Redémarre) / 1=Oui
    bitmask: 1
    name: "F17 Activer Mode Silence Temporisé"
    address: 1072           # 1072 (430h) : 0=Non / 1=Oui
    bitmask: 1
    name: "F18 Régulation Manuelle Vitesse Ventilateur"
    address: 1073           # 1073 (431h) : 0=Non / 1=Oui
    bitmask: 1
# --- SÉLECTEURS DE MODE ET DE CONFIGURATION (Read / Write) ----------
select:
    name: "Mode de Fonctionnement"
    address: 1012           # 1012 (3F4h)
    value_type: U_WORD
    optionsmap:
      "Refroidissement": 0
      "Chauffage": 1
      "Automatique": 2
    name: "H02 Restriction Modes"
    address: 1019           # 1019 (3FBh)
    value_type: U_WORD
    optionsmap:
      "Froid Seul": 0
      "Chaud et Froid Auto": 1
      "Chaud Seul": 2
    name: "H12 Type de Compresseur"
    address: 1026           # 1026 (402h)
    value_type: U_WORD
    optionsmap:
      "Tout ou Rien (ON OFF)": 0
      "TNB220FLHMC_TUV": 1
      "SNB172FJGMC_TUV": 2
      "MNB36FAAMC_TUV": 3
      "TNB306FPGMC_TUV": 4
      "TNB220FUEMC_UL": 5
      "MNB36FAUMC-L_UL": 6
      "TNB306FVPMC_UL": 7
      "SNB150FGAMC": 8
      "SNB140FCAMC": 9
      "MNB36FABMC": 10
      "MNB42FFDMC": 11
      "UNKNOWN": 46
    name: "F01 Configuration Moteur Ventilateur"
    address: 1048           # 1048 (418h)
    value_type: U_WORD
    optionsmap:
      "Mono Vitesse (Max)": 0
      "Bi-Vitesse": 1
      "AC": 2
      "1x DC (Inverter)": 3
      "2x DC": 4
      "EC": 5
    name: "F10 Sonde Référence Régulation Ventilateur"
    address: 1061           # 1061 (425h) : 0=Sonde Batterie / 1=Ambiant
    value_type: U_WORD
    optionsmap:
      "Température Coil (Batterie)": 0
      "Température Ambiante": 1
    address: 1076           # 1076 (434h)
    value_type: U_WORD
    optionsmap:
      "Normal": 0
      "Silencieux": 1
    name: "F20 Fonction Port AI-DI 11"
    address: 1077           # 1077 (435h)
    value_type: U_WORD
    optionsmap:
      "Détection PWM": 0
      "Sonde Antigel Tuyauterie": 1
    name: "P01 Mode Fonctionnement Pompe à Eau"
    address: 1081           # 1081 (439h)
    value_type: U_WORD
    optionsmap:
      "Normal": 0
      "Spécial": 1
      "Intervalle": 2
    name: "D06 Mode de Dégivrage"
    address: 1106           # 1106 (452h)
    value_type: U_WORD
    optionsmap:
      "Normal": 0
      "Économique": 1
    name: "E01 Mode Détendeur Électronique (EEV)"
    address: 1116           # 1116 (45Ch)
    value_type: U_WORD
    optionsmap:
      "Manuel": 0
      "Automatique": 1
      "Auxiliaire": 2
    name: "H03 Unité de Température"
    address: 1145           # 1145 (479h)
    value_type: U_WORD
    optionsmap:
      "Celsius (°C)": 0
      "Fahrenheit (°F)": 1
# --- AJUSTEMENTS ET CONFIGURATIONS NUMÉRIQUES (Read / Write) --------
number:
    name: "Consigne Température Actuelle"
    address: 1013           # 1013 (3F5h) - TEMP1
    value_type: U_WORD
    unit_of_measurement: "°C"
    mode: BOX
    min_value: 15
    max_value: 40
    step: 1
    multiply: 10
    name: "H06 Fréquence Min Compresseur Chaud"
    address: 1020           # 1020 (3FCh) : 0-60Hz
    value_type: U_WORD
    unit_of_measurement: "Hz"
    mode: BOX
    name: "H07 Fréquence Min Compresseur Froid"
    address: 1021           # 1021 (3FDh) : 0-60Hz
    value_type: U_WORD
    mode: BOX
    name: "H08 Fréquence Max Compresseur Chaud"
    address: 1022           # 1022 (3FEh) : 0-120Hz
    value_type: U_WORD
    mode: BOX
    name: "H09 Fréquence Max Compresseur Froid"
    address: 1023           # 1023 (3FFh) : 0-120Hz
    value_type: U_WORD
    mode: BOX
    name: "H10 Temporisation Arrêt sur Consigne Atteinte"
    address: 1024           # 1024 (400h) : 0-120min
    value_type: U_WORD
    unit_of_measurement: "min"
    mode: BOX
    name: "H14 Cycle Ajustement Fréquence par 0.2C"
    address: 1028           # 1028 (404h) : 0-255s
    value_type: U_WORD
    unit_of_measurement: "s"
    mode: BOX
    name: "H15 Seuil Protection Surintensité Compresseur"
    address: 1029           # 1029 (405h) - DIGI5 (0.1A)
    value_type: U_WORD
    unit_of_measurement: "A"
    mode: BOX
    multiply: 10
    name: "H33 Fréquence Max Compresseur Mode Silence"
    address: 1047           # 1047 (417h) : 0-120Hz
    value_type: U_WORD
    mode: BOX
    name: "F11 Devoir de Marche Max Ventilateur"
    address: 1062           # 1062 (426h) : 50%-100%
    value_type: U_WORD
    unit_of_measurement: "%"
    mode: BOX
    name: "P02 Intervalle de Marche Pompe à Eau"
    address: 1082           # 1082 (43Ah) : 0-60min
    value_type: U_WORD
    mode: BOX
    name: "P03 Durée de Marche Pompe à Eau"
    address: 1083           # 1083 (43Bh) : 0-30min
    value_type: U_WORD
    mode: BOX
    name: "D03 Cycle de Dégivrage"
    address: 1104           # 1104 (450h) : 45min d'usine
    value_type: U_WORD
    mode: BOX
    name: "D04 Durée Max de Dégivrage"
    address: 1105           # 1105 (451h) : 8min d'usine
    value_type: U_WORD
    mode: BOX
    name: "E02 Surchauffe cible EEV"
    address: 1117           # 1117 (45Dh) - TEMP1 (-20 à 20C)
    value_type: S_WORD
    mode: BOX
    multiply: 10
    name: "E03 Ouverture Initiale EEV"
    address: 1118           # 1118 (45Eh) : 0-500 steps
    value_type: U_WORD
    unit_of_measurement: "steps"
    mode: BOX
    name: "R01 Réglage Entrée Eau en Froid"
    address: 1135           # 1135 (46Fh) - TEMP1
    value_type: S_WORD
    mode: BOX
    multiply: 10
    name: "R02 Réglage Entrée Eau en Chaud"
    address: 1136           # 1136 (470h) - TEMP1
    value_type: S_WORD
    mode: BOX
    multiply: 10
    name: "R04 Différentiel Redémarrage PAC"
    address: 1138           # 1138 (472h) - TEMP1 (0 à 10C)
    value_type: S_WORD
    mode: BOX
    multiply: 10
# --- SONDES ET CAPTEURS DE MESURE EN LECTURE SEULE -------------------
    name: "Température Entrée Eau Actuelle"
    address: 1016           # 1016 (3F8h) : Température référence d'entrée d'eau
    value_type: S_WORD
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    name: "T01 Température Aspiration Gazeuse"
    address: 2045           # 2045 (7FDh) : Température d'aspiration du gaz
    value_type: S_WORD
    filters:
      - multiply: 0.1
    name: "T02 Température Entrée Eau (Copie)"
    address: 2046           # 2046 (7FEh) : Deuxième lecture entrée d'eau
    value_type: S_WORD
    filters:
      - multiply: 0.1
    name: "T03 Température Sortie Eau"
    address: 2047           # 2047 (7FFh) : Température de l'eau rejetée
    value_type: S_WORD
    filters:
      - multiply: 0.1
    name: "T04 Température Évaporateur (Coil)"
    address: 2048           # 2048 (800h) : Température de la batterie d'échange
    value_type: S_WORD
    filters:
      - multiply: 0.1
    name: "T05 Température Ambiante"
    address: 2049           # 2049 (801h) : Sonde d'air extérieur
    value_type: S_WORD
    filters:
      - multiply: 0.1
    name: "T06 Température Refoulement (Exhaust)"
    address: 2050           # 2050 (802h) : Gaz comprimé en sortie de compresseur
    value_type: S_WORD
    filters:
      - multiply: 0.1
    name: "T08 Sortie Moteur Ventilateur AC"
    address: 2052           # 2052 (804h) : Statut ou puissance de ventilation AC
    value_type: U_WORD
    name: "T11 Surchauffe Réelle (Superheat)"
    address: 2060           # 2060 (80Ch) : Valeur de surchauffe calculée
    value_type: S_WORD
    filters:
      - multiply: 0.1
    name: "O07 Fréquence Compresseur Courante"
    address: 2021           # 2021 (7E5h) : Vitesse réelle de l'inverter
    value_type: U_WORD
    name: "O08 Courant Compresseur"
    address: 2022           # 2022 (7E6h) : Intensité en Ampères
    value_type: U_WORD
    filters:
      - multiply: 0.1
    name: "O09 Température Module IPM"
    address: 2023           # 2023 (7E7h) : Température des composants de puissance
    value_type: S_WORD
    name: "Puissance Actuelle Consommée"
    address: 2055           # 2055 (807h) : Énergie estimée (courbe de performance)
    value_type: U_WORD
    unit_of_measurement: "kW"
    filters:
      - multiply: 0.1
    name: "T12 Vitesse Ventilateur DC"
    address: 2061           # 2061 (80Dh) : Vitesse du ventilateur principal
    value_type: U_WORD
    unit_of_measurement: "RPM"
    name: "O06 Ouverture Détendeur EEV"
    address: 2020           # 2020 (7E4h) : Nombre de pas d'ouverture de la vanne
    value_type: U_WORD
    name: "Version de la Carte Contrôleur"
    address: 2083
    value_type: U_WORD
    name: "Code du Logiciel Interne (Firmware)"
    address: 2084
    value_type: U_WORD
# --- ÉTATS LOGIQUES ET ALARMES DE PANNES EXHAUSTIFS (Read Only) -----
binary_sensor:
    name: "Statut Physique Marche/Arrêt Écran"
    address: 2011           # 2011 (7DBh)
    bitmask: 0x0001
  # --- Décodage du Registre de Sorties Relais Actives 2019 (7E3h) ---
    name: "Relais : Compresseur"
    address: 2019
    bitmask: 0x0001         # bit0
    name: "Relais : Ventilateur Haute Vitesse"
    address: 2019
    bitmask: 0x0002         # bit1
    name: "Relais : Ventilateur Basse Vitesse"
    address: 2019
    bitmask: 0x0004         # bit2
    name: "Relais : Pompe de Circulation Eau"
    address: 2019
    bitmask: 0x0008         # bit3
    name: "Relais : Vanne 4 Voies (Dégivrage)"
    address: 2019
    bitmask: 0x0010         # bit4
  # --- Décodage des Entrées Capteurs Sécurités Physiques 2034 (7F2h) ---
    name: "Sécurité : Pressostat Haute Pression (HP)"
    address: 2034
    bitmask: 0x0001         # bit0 : S01
    name: "Sécurité : Pressostat Basse Pression (LP)"
    address: 2034
    bitmask: 0x0002         # bit1 : S02
    name: "Sécurité : Capteur de Débit d'Eau"
    address: 2034
    bitmask: 0x0004         # bit2 : S03
    name: "Sécurité : Commutateur On/Off Distant"
    address: 2034
    bitmask: 0x0008         # bit3 : S04
  # --- REGISTRE DE PANNES 1 : Adresse 2074 (81Ah) ----------------------
    name: "Panne : Capteur Température Entrée Eau (P01)"
    address: 2074
    device_class: problem
    name: "Panne : Capteur Température Sortie Eau (P02)"
    address: 2074
    name: "Panne : Capteur Température Ambiante (P04)"
    address: 2074
    name: "Panne : Capteur Température Batterie (P05)"
    address: 2074
    name: "Panne : Capteur Température Aspiration (P07)"
    address: 2074
    name: "Panne : Capteur Température Refoulement (P081)"
    address: 2074
    bitmask: 0x0020         # bit5
    name: "Alarme : Protection Surintensité Compresseur (E051)"
    address: 2074
    bitmask: 0x0040         # bit6
    name: "Alarme : Sécurité Haute Pression Gaz (E01)"
    address: 2074
    bitmask: 0x0080         # bit7
    name: "Alarme : Sécurité Basse Pression Gaz (E02)"
    address: 2074
    bitmask: 0x0100         # bit8
    name: "Alarme : Manque Débit d'Eau (E03)"
    address: 2074
    bitmask: 0x0200         # bit9
    name: "Alarme : Antigel Hiver Primaire (E19)"
    address: 2074
    bitmask: 0x0400         # bit10
    name: "Alarme : Antigel Hiver Secondaire (E29)"
    address: 2074
    bitmask: 0x0800         # bit11
    name: "Alarme : Protection Antigel Échangeur (E07)"
    address: 2074
    bitmask: 0x1000         # bit12
    name: "Alarme : Surchauffe Refoulement Circuit 1"
    address: 2074
    bitmask: 0x2000         # bit13
    name: "Alarme : Écart T° Entrée/Sortie trop haut (E06)"
    address: 2074
    bitmask: 0x4000         # bit14
    name: "Statut : Cycle de Dégivrage en Cours"
    address: 2074
    bitmask: 0x8000         # bit15
  # --- REGISTRE DE PANNES 2 : Adresse 2075 (81Bh) ----------------------
    name: "Panne : Verrouillage Surcharge Compresseur (>3 fois)"
    address: 2075
    name: "Panne : Verrouillage Haute Pression (>3 fois)"
    address: 2075
    name: "Panne : Verrouillage Basse Pression (>3 fois)"
    address: 2075
    name: "Panne : Verrouillage Débit d'Eau (>3 fois)"
    address: 2075
    name: "Panne : Verrouillage Antigel (>3 fois)"
    address: 2075
    name: "Panne : Verrouillage Surchauffe Refoulement (>3 fois)"
    address: 2075
    name: "Alerte : Driver MOP Avertissement (F01)"
    address: 2075
    name: "Panne : Carte Convertisseur Inverter Hors-ligne (F02)"
    address: 2075
    name: "Panne : Protection Matérielle Module IPM (F03)"
    address: 2075
    name: "Panne : Échec de Démarrage du Compresseur (F04)"
    address: 2075
    name: "Panne : Perte de Phase d'Entrée Convertisseur (F17)"
    address: 2075
    name: "Panne : Échec Échantillonnage Courant IPM (F18)"
    address: 2075
    name: "Panne : Protection Surchauffe Convertisseur (F20)"
    address: 2075
    name: "Panne : Surtension Bus DC Convertisseur (F07)"
    address: 2075
    name: "Panne : Sous-tension Bus DC Convertisseur (F08)"
    address: 2075
    name: "Panne : Sous-tension d'Entrée"
    address: 2075
  # --- REGISTRE DE PANNES 3 : Adresse 2076 (81Ch) ----------------------
    name: "Panne : Surtension d'Entrée"
    address: 2076
    name: "Panne : Échec Échantillonnage Tension"
    address: 2076
    name: "Panne : Échec Liaison DSP et PFC (F12)"
    address: 2076
    name: "Panne : Capteur Température Radiateur HS (F19)"
    address: 2076
    name: "Panne : Anomalie Tension V15V (F28)"
    address: 2076
    name: "Panne : Échec Étage PFC (F27)"
    address: 2076
    name: "Panne : Surchauffe Module IPM (F15)"
    address: 2076
    name: "Panne : Protection Faiblesse Magnétique (F16)"
    address: 2076
    name: "Avertissement : Surintensité d'Entrée (F24)"
    address: 2076
    name: "Avertissement : Surchauffe Convertisseur (F22)"
    address: 2076
    name: "Panne : Protection Globale Surintensité Entrée"
    address: 2076
    name: "Avertissement : Erreur EEPROM (F25)"
    address: 2076
    name: "Panne : Alerte Protection IPM"
    address: 2076
    name: "Panne : Driver Moteur Ventilateur DC HS"
    address: 2076
    name: "Panne : Défaut Capteur Pression (PP)"
    address: 2076
    name: "Panne : Surintensité Majeure Entrée (F26)"
    address: 2076
  # --- REGISTRE DE PANNES 4 : Adresse 2077 (81Dh) ----------------------
    name: "Protection : Antigel Actif"
    address: 2077
    name: "Protection : Antigel Actif en Mode Chauffage"
    address: 2077
    name: "Panne : Perte Signal Retour Moteur EC"
    address: 2077
    name: "Panne : Dysfonctionnement Moteur Ventilateur 1"
    address: 2077
    name: "Panne : Dysfonctionnement Moteur Ventilateur 2"
    address: 2077
    name: "Panne : Échec Communication Moteur Ventilateur DC"
    address: 2077
I think that I am done with the modbus configuration for my heat pump. I used a very straight forward approach as suggested by Google AI, without any modification to the way modbus is implemented into ESPHome, nor any specific method like @grandalos who use some caching for commands to replicate his oem behaviour. Note that I also have an Aquatemp module on the RS485 which was sold with my heat pump, and it still works perfectly on the top of the ESPHome.
So for those interested, here is my code (partially in french and english). The code is spread over 3 posts due to the forum message lenght limitation :
EDIT: sorry the code is just too long, the forum forbids me to post more than 2 messages following each other, so here is only the first part with the uart connecionion
uart:
  - id: modbus_bus
    tx_pin: GPIO17
    rx_pin: GPIO16
    baud_rate: 9600
    stop_bits: 1
    data_bits: 8
    parity: NONE
modbus:
  uart_id: modbus_bus
modbus_controller:
  - id: phnix_pac
    address: 1
switch:
    bitmask: 1
    device_class: switch
    name: "H01 Désactiver redémarrage automatique"
    bitmask: 1
    entity_category: config
    icon: mdi:restart-off
    name: "Programme Silencieux"
    bitmask: 1
    icon: mdi:fan-clock
    name: "F18 Régulation manuelle vitesse ventilateur"
    bitmask: 1
    disabled_by_default: true
    name: "Programme 1 - Démarrage Auto"
    address: 1158           # 1158
    bitmask: 1
    icon: mdi:calendar-start
    name: "Programme 1 - Arrêt Auto"
    address: 1159           # 1159
    bitmask: 1
    icon: mdi:calendar-end
    name: "Programme 2 - Démarrage Auto"
    address: 1160           # 1160
    bitmask: 1
    name: "Programme 2 - Arrêt Auto"
    address: 1161           # 1161
    bitmask: 1
select:
    name: "Mode de fonctionnement"
    value_type: U_WORD
    optionsmap:
      "Chauffage": 1
      "Automatique": 2
    icon: mdi:heat-pump-outline
    name: "H02 Modes disponibles"
    value_type: U_WORD
    optionsmap:
      "Froid Seul": 0
      "Chaud et Froid": 1
      "Chaud Seul": 2
    icon: mdi:sun-snowflake-variant
    name: "H12 Type de compresseur"
    value_type: U_WORD
    optionsmap:
      "MNB36FAAMC_TUV": 3
      "TNB220FUEMC_UL": 5
      "TNB306FVPMC_UL": 7
      "SNB150FGAMC": 8
      "SNB140FCAMC": 9
      "MNB36FABMC": 10
      "MNB42FFDMC": 11
      "UNKNOWN": 46
    name: "H16 Refrigerant type"
    address: 1030           # 1030
    value_type: U_WORD
    optionsmap:
      "R410A": 0
      "R407C": 1
      "R32": 2
      "R290": 3
    name: "F01 Fan motor configuration"
    value_type: U_WORD
    optionsmap:
      "Single speed (High)": 0
      "Dual speed": 1
      "AC": 2
      "DC-1 (Inverter)": 3
      "DC-2": 4
      "EC": 5
    name: "F10 Fan speed regulation temp. source"
    value_type: U_WORD
    optionsmap:
      "Coil": 0
      "Abient": 1
    name: "Mode du ventilateur"
    address: 1076           # 1076 (434h) : 0=OFF / 1=ON
    value_type: U_WORD
    optionsmap:
      "Automatique": 0
      "Silencieux": 1
    icon: mdi:fan
    name: "F20 Function for AI-DI 11 port"
    value_type: U_WORD
    optionsmap:
      "PWM detect": 0
      "Antifreeze T° sensor": 1
    icon: mdi:midi-port
    name: "P01 Mode fonctionnement pompe à eau"
    value_type: U_WORD
    optionsmap:
      "Normal": 0
      "Spécial": 1
      "Intervalle": 2
    name: "D06 Mode de dégivrage"
    value_type: U_WORD
    optionsmap:
      "Normal": 0
      "Économique": 1
    name: "E01 EEV mode"
    value_type: U_WORD
    optionsmap:
      "Manual": 0
      "Auto": 1
      "Auxiliary": 2
    name: "H03 Unité de température"
    value_type: U_WORD
    optionsmap:
      "Celsius (°C)": 0
    icon: mdi:temperature-celsius
number:
    name: "Consigne de température"
    value_type: U_WORD
    device_class: temperature
    mode: BOX
    min_value: 15
    max_value: 35
    step: 0.5
    multiply: 10
#    on_value:
#      then:
#        - climate.control:
#            id: pac_climate
#            target_temperature: !lambda "return x;"
    name: "H06 Minimum compressor frequency in heating"
    value_type: U_WORD
    device_class: frequency
    mode: BOX
    min_value: 0
    max_value: 120
    step: 1
    name: "H07 Minimum compressor frequency in cooling"
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 120
    step: 1
    name: "H08 Maximum compressor frequency in heating"
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 120
    step: 1
    name: "H09 Maximum compressor frequency in cooling"
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 120
    step: 1
    name: "H10 Temporisation arrêt lorsque consigne atteinte"
    value_type: U_WORD
    device_class: duration
    mode: BOX
    min_value: 0
    max_value: 120
    step: 1
    name: "H11 Auto mode delay before rechecking inlet temperature"
    address: 1025           # 1025
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 255
    step: 1
    name: "H13 Compressor defrost frequency"
    address: 1027           # 1027 : 0-120Hz
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 120
    step: 1
    name: "H14 Cycle ajustement fréquence par 0.2C"
    address: 1028           # 1028 (404h) : 0-255min
    value_type: U_WORD
    mode: BOX
    min_value: 1
    max_value: 255
    step: 1
    name: "H15 Seuil protection surintensité compresseur"
    value_type: U_WORD
    device_class: current
    mode: BOX
    min_value: 1
    max_value: 24.5
    step: 0.1
    multiply: 10
    name: "H17 Cooling start compensation low ambient temp."
    address: 1031           # 1031
    value_type: S_WORD
    mode: BOX
    min_value: 5
    max_value: 35
    step: 1
    multiply: 10
    name: "H18 Cooling stop compensation low ambient temp."
    address: 1032           # 1032
    value_type: S_WORD
    mode: BOX
    min_value: 5
    max_value: 35
    step: 1
    multiply: 10
    name: "H19 Cooling max. frequency low ambient temp."
    address: 1033           # 1033
    value_type: U_WORD
    mode: BOX
    min_value: 20
    max_value: 100
    step: 1
    name: "H20 Cooling start compensation high ambient temp."
    address: 1034           # 1034
    value_type: S_WORD
    mode: BOX
    min_value: 5
    max_value: 55
    step: 1
    multiply: 10
    name: "H21 Cooling stop compensation high ambient temp."
    address: 1035           # 1035
    value_type: S_WORD
    mode: BOX
    min_value: 5
    max_value: 55
    step: 1
    multiply: 10
    name: "H22 Cooling stop frequency high ambient temp."
    address: 1036           # 1036
    value_type: U_WORD
    mode: BOX
    min_value: 20
    max_value: 100
    step: 1
    name: "H23 Heating start compensation low ambient temp."
    address: 1037           # 1037
    value_type: S_WORD
    mode: BOX
    min_value: -15
    max_value: 45
    step: 1
    multiply: 10
    name: "H24 Heating stop compensation low ambient temp."
    address: 1038           # 1038
    value_type: S_WORD
    mode: BOX
    min_value: -5
    max_value: 45
    step: 1
    multiply: 10
    name: "H25 Heating max. frequency low ambient temp."
    address: 1039           # 1039
    value_type: U_WORD
    mode: BOX
    min_value: 20
    max_value: 100
    step: 1
    name: "H26 Heating start compensation high ambient temp."
    address: 1040           # 1040
    value_type: S_WORD
    mode: BOX
    min_value: -15
    max_value: 55
    step: 1
    multiply: 10
    name: "H27 Heating stop compensation high ambient temp."
    address: 1041           # 1041
    value_type: S_WORD
    mode: BOX
    min_value: -15
    max_value: 55
    step: 1
    multiply: 10
    name: "H28 Heating max. frequency high ambient temp."
    address: 1042           # 1042
    value_type: U_WORD
    mode: BOX
    min_value: 20
    max_value: 100
    step: 1
    name: "H29 Max. pressure sensor value"
    address: 1043           # 1043
    value_type: U_WORD
    unit_of_measurement: "bar"
    device_class: pressure
    mode: BOX
    min_value: -100
    max_value: 100
    step: 1
    multiply: 0.001
    name: "H30 Min. pressure sensor value"
    address: 1044           # 1044
    value_type: U_WORD
    mode: BOX
    min_value: -100
    max_value: 100
    step: 1
    multiply: 0.001
    name: "H31 Ambient temp. start overheat compensation"
    address: 1045           # 1045
    value_type: S_WORD
    mode: BOX
    min_value: -15
    max_value: 15
    step: 1
    multiply: 10
    name: "H32 Ambient temp. stop overheat compensation"
    address: 1046           # 1046
    value_type: S_WORD
    mode: BOX
    min_value: -15
    max_value: 15
    step: 1
    multiply: 10
    name: "H33 Fréquence max. Compresseur Mode Silence"
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 120
    step: 1
    name: "F02 Temperature for max. fan speed in cooling"
    address: 1049           # 1049
    value_type: S_WORD
    mode: BOX
    min_value: -15
    max_value: 60
    step: 1
    multiply: 10
    name: "F02-bar Pressure for max. fan speed in cooling"
    address: 1050           # 1044
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 10
    step: 1
    multiply: 0.001
    name: "F03 Temperature for min. fan speed in cooling"
    address: 1051          # 1051
    value_type: S_WORD
    mode: BOX
    min_value: -15
    max_value: 60
    step: 1
    multiply: 10
    name: "F03-bar Pressure for min. fan speed in cooling"
    address: 1052           # 1052
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 10
    step: 1
    multiply: 0.001
    name: "F04 Temperature for stopping fan in cooling"
    address: 1053           # 1053
    value_type: S_WORD
    mode: BOX
    min_value: -15
    max_value: 60
    step: 1
    multiply: 10
    name: "F04-bar Pressure for fan stopping in cooling"
    address: 1054           # 1054
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 10
    step: 1
    multiply: 0.001
    name: "F05 Temperature for max. fan speed in heating"
    address: 1055           # 1055
    value_type: S_WORD
    mode: BOX
    min_value: -15
    max_value: 60
    step: 1
    multiply: 10
    name: "F05-bar Pressure for max. fan speed in heating"
    address: 1056           # 1056
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 10
    step: 1
    multiply: 0.001
    name: "F06 Temperature for min. fan speed in heating"
    address: 1057           # 1057
    value_type: S_WORD
    mode: BOX
    min_value: -15
    max_value: 60
    step: 1
    multiply: 10
    name: "F06-bar Pressure for min. fan speed in heating"
    address: 1058           # 1058
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 10
    step: 1
    multiply: 0.001
    name: "F07 Temperature for fan stopping in heating"
    address: 1059           # 1059
    value_type: S_WORD
    mode: BOX
    min_value: -15
    max_value: 60
    step: 1
    multiply: 10
    name: "F07-bar Pressure for fan stopping in heating"
    address: 1060           # 1060
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 10
    step: 1
    multiply: 0.001
    name: "F11 Max. duty ratio in heating"
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 100
    step: 1
    name: "F11-r Max. fan speed in heating"
    address: 1063           # 1063
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 1300
    step: 1
    multiply: 100
    name: "F12 Max. duty ratio in cooling"
    address: 1064           # 1064
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 100
    step: 1
    name: "F12-r Min. fan speed in cooling"
    address: 1065           # 1065
    value_type: U_WORD
    mode: BOX
    min_value: 300
    max_value: 1300
    step: 1
    multiply: 100
    name: "F13 Min. duty ratio in heating"
    address: 1066           # 1066
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 100
    step: 1
    name: "F13-r Min. fan speed in heating"
    address: 1067           # 1067
    value_type: U_WORD
    mode: BOX
    min_value: 300
    max_value: 1300
    step: 1
    multiply: 100
  # --- TIMERS MODE SILENCIEUX (Heures uniquement) ---
    address: 1068
    internal: true
    value_type: U_WORD
    address: 1069
    internal: true
    value_type: U_WORD
#  - platform: modbus_controller
#    name: "Début du programme Silencieux"
#    register_type: holding
#    address: 1068           # 1068 : 0-23h
#    value_type: U_WORD
#    unit_of_measurement: "h"
#    mode: BOX
#    min_value: 0
#    max_value: 23
#    step: 1
#    name: "Fin du programme Silencieux"
#    address: 1069           # 1069 : 0-23h
#    mode: BOX
#    min_value: 0
#    max_value: 23
#    step: 1
    name: "F16 Silent mode duty ratio"
    address: 1070           # 1070
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 100
    step: 1
    name: "F16-r Silent mode fan speed"
    address: 1071           # 1071
    value_type: U_WORD
    mode: BOX
    min_value: 300
    max_value: 1300
    step: 1
    multiply: 100
    name: "F19 AC fan rated duty ratio"
    address: 1074           # 1074
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 100
    step: 1
    name: "F19-r DC-EC fan rated speed"
    address: 1075           # 1069
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 1300
    step: 1
    multiply: 100
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 60
    step: 1
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 30
    step: 1
    name: "P04 Water pump advance compressor time"
    address: 1084           # 1084
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 10
    step: 1
    name: "D01 Start defrosting temperature"
    address: 1101           # 1101
    value_type: S_WORD
    mode: BOX
    min_value: -30
    max_value: 5
    step: 1
    multiply: 10
    name: "D01-bar Start defrosting pressure"
    address: 1102           # 1102
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 10
    step: 1
    multiply: 0.001
    name: "D02 Stop defrosting temperature"
    address: 1103           # 1103
    value_type: S_WORD
    mode: BOX
    min_value: 0
    max_value: 30
    step: 1
    multiply: 10
    name: "D03 Defrosting Cycle"
    value_type: U_WORD
    mode: BOX
    min_value: 30
    max_value: 90
    step: 1
    name: "D04 Max. defrosting time"
    value_type: U_WORD
    mode: BOX
    min_value: 1
    max_value: 20
    step: 1
    name: "D07 Ambient temp. to start slide defrosting"
    address: 1107           # 1107
    value_type: S_WORD
    mode: BOX
    min_value: -20
    max_value: 10
    step: 1
    multiply: 10
    name: "D09 Difference of ambient temp. after starting slide defrosting"
    address: 1108           # 1108
    value_type: S_WORD
    device_class: temperature_delta
    mode: BOX
    min_value: 0
    max_value: 30
    step: 1
    multiply: 10
    name: "D08 Difference of coil temp. after starting slide defrosting"
    address: 1109           # 1109
    value_type: S_WORD
    mode: BOX
    min_value: 0
    max_value: 50
    step: 1
    multiply: 10
    name: "D08-bar Difference of pressure after starting slide defrosting"
    address: 1110           # 1110
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 10
    step: 1
    multiply: 0.001
    name: "D10 Coil temp. to stop slide defrosting"
    address: 1111           # 1111
    value_type: S_WORD
    mode: BOX
    min_value: -30
    max_value: 5
    step: 1
    multiply: 10
    name: "D10-bar Pressure to stop slide defrosting"
    address: 1112           # 1112
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 10
    step: 1
    multiply: 0.001
    name: "E02 EEV Target super heat"
    value_type: S_WORD
    mode: BOX
    min_value: -20
    max_value: 20
    step: 1
    multiply: 10
    name: "E03 EEV initial opening"
    value_type: U_WORD
    mode: BOX
    min_value: 0
    max_value: 500
    step: 1
    name: "E04 EEV min. opening"
    address: 1119           # 1119
    value_type: U_WORD
    mode: BOX
    min_value: 10
    max_value: 500
    step: 1
