Hi everyone,
EDIT : After days of debbuging, I managed to fix the issue.
Replacing the default broker (HBMQTT) by Mosquitto broker for Hass.io fixed all my troubles - and speeded up time of response for a few MQTT-powered switched I use.
I have a big issue with my HASS.io + HomeAssistant 0.60 install.
After a HomeAssistant restart, everything works perfectly for about 24 hours or so.
After that, Home Assistant slows down up to the point of being unusable.
I can still SSH into it without any delay, FTP works also normally as well.
But
- the frontend is so slow that it eventually times out before I can reach it
- when calling services without passing by the frontend (triggered by an automation, a press on one of my FLIC bluetooth button,…) lights and devices takes up to 1 minute to turn on.
Restarting HomeAssistant fixes the issue, for 24 hours.
I already tried to make a fresh install of HassIO, without success.
Actually, I’m a bit lost regarding what to try to fix this. I have absolutely no idea of what change in my config might have triggered this issue.
Could it be an hardware issue with the Pi?
When I check in my log file, I have tons of error like this one:
2017-12-30 13:00:02 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
I searched the forum, but found nothing (except a bug in a previous version of Home Assistant)
What could I do?
Have a nice day & thanks for your help !
