HC-SR04 sensor is giving wild readings
I flashed Tasmota to a D1 Mini. I have the distance sensor mounted to my garage ceiling pointing down above where I park my vehicle in my garage.
I’ve got the trigger pin set to SR04 Tri on D6 and the echo pin set to SR04 Ech but I’m getting very wild readings especially when my vehicle is parked.
Everything seems to settle down a bit when my space is empty.
I’m wondering if there is some configuration I can add to help with this or I’ve even seen references to soldering a capacitor across certain pins to help.
I arrived home at 4:00 PM and left home at about 6:10 on the graph shown above.
There was no activity in the garage during this time.
Thanks in advance.
