Hi! I install HA to debian (supervisor installed) and i have connect to the host 3 HDD.
I installed and set hdparm use the man:
https://wiki.archlinux.org/title/Hdparm
But logs i can see it (all hdd was umount):
in the logs you can see 1 HDD but in all logs - i have all 3 HDD.
Aug 21 15:46:01 debian hassio_supervisor[791]: 2024-08-21 15:46:01.012 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/sdb2 - /dev/disk/by-id/ata-ST1000LM049-2GH172_WGS1ZATR-part2
Aug 21 15:46:01 debian hassio_supervisor[791]: 2024-08-21 15:46:01.010 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/sdb1 - /dev/disk/by-id/ata-ST1000LM049-2GH172_WGS1ZATR-part1
Aug 21 15:45:59 debian lvm[808902]: PV /dev/sdb1 not used.
Aug 21 15:45:59 debian kernel: sdb: sdb1 sdb2
Aug 21 15:45:58 debian hassio_supervisor[791]: 2024-08-21 15:45:58.994 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/sdb2 - /dev/disk/by-id/ata-ST1000LM049-2GH172_WGS1ZATR-part2
Aug 21 15:45:58 debian hassio_supervisor[791]: 2024-08-21 15:45:58.993 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/sdb1 - /dev/disk/by-id/ata-ST1000LM049-2GH172_WGS1ZATR-part1
Aug 21 15:34:30 debian sudo[805969]: user : TTY=pts/3 ; PWD=/home/user ; USER=root ; COMMAND=/usr/sbin/tune2fs -l /dev/sdb1
Aug 21 15:34:22 debian sudo[805938]: user : TTY=pts/3 ; PWD=/home/user ; USER=root ; COMMAND=/usr/sbin/tune2fs -l /dev/sdb2
Aug 21 15:34:17 debian sudo[805918]: user : TTY=pts/3 ; PWD=/home/user ; USER=root ; COMMAND=/usr/sbin/tune2fs -l /dev/sdb
Aug 21 15:23:59 debian smartd[736698]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 38 to 37
Aug 21 15:23:59 debian smartd[736698]: Device: /dev/sdb [SAT], SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 62 to 63
Aug 21 15:21:05 debian sudo[803796]: user : TTY=pts/1 ; PWD=/home/user ; USER=root ; COMMAND=/usr/sbin/hdparm -Y /dev/sdb
Aug 21 15:19:11 debian sudo[803436]: user : TTY=pts/1 ; PWD=/home/user ; USER=root ; COMMAND=/usr/sbin/hdparm -S 60 /dev/sdb
Aug 21 15:12:11 debian sudo[802211]: user : TTY=pts/3 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/dstat -D sdd,sdc,sdb
Aug 21 15:04:20 debian sudo[800765]: user : TTY=pts/1 ; PWD=/home/user ; USER=root ; COMMAND=/usr/sbin/hdparm -B /dev/sdb
Aug 21 14:45:43 debian hassio_supervisor[791]: 2024-08-21 14:45:43.506 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/sdb2 - /dev/disk/by-id/ata-ST1000LM049-2GH172_WGS1ZATR-part2
Aug 21 14:45:43 debian hassio_supervisor[791]: 2024-08-21 14:45:43.501 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/sdb1 - /dev/disk/by-id/ata-ST1000LM049-2GH172_WGS1ZATR-part1
Aug 21 14:45:41 debian lvm[796732]: PV /dev/sdb1 not used.
Aug 21 14:45:41 debian kernel: sdb: sdb1 sdb2
Aug 21 14:45:41 debian hassio_supervisor[791]: 2024-08-21 14:45:41.489 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/sdb2 - /dev/disk/by-id/ata-ST1000LM049-2GH172_WGS1ZATR-part2
Aug 21 14:45:41 debian hassio_supervisor[791]: 2024-08-21 14:45:41.488 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/sdb1 - /dev/disk/by-id/ata-ST1000LM049-2GH172_WGS1ZATR-part1
Aug 21 14:30:40 debian hassio_supervisor[791]: 2024-08-21 14:30:40.787 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/sdb2 - /dev/disk/by-id/ata-ST1000LM049-2GH172_WGS1ZATR-part2
Aug 21 14:30:40 debian hassio_supervisor[791]: 2024-08-21 14:30:40.781 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/sdb1 - /dev/disk/by-id/ata-ST1000LM049-2GH172_WGS1ZATR-part1
Aug 21 14:30:38 debian lvm[791477]: PV /dev/sdb1 not used.
Aug 21 14:30:38 debian kernel: sdb: sdb1 sdb2
Aug 21 14:30:38 debian hassio_supervisor[791]: 2024-08-21 14:30:38.757 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/sdb2 - /dev/disk/by-id/ata-ST1000LM049-2GH172_WGS1ZATR-part2
Aug 21 14:30:38 debian hassio_supervisor[791]: 2024-08-21 14:30:38.751 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/sdb1 - /dev/disk/by-id/ata-ST1000LM049-2GH172_WGS1ZATR-part1
Aug 21 14:24:00 debian smartd[736698]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 39 to 38
Aug 21 14:24:00 debian smartd[736698]: Device: /dev/sdb [SAT], SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 61 to 62
The HDD (all) can`t spinoff.
If i do:
sudo docker stop hassio_supervisor
The hdd has no input output operation.
Can i add to excludes for scans HDD use name the device or UUID?
