For those who want to know HDD temp (+ all HDD S.M.A.R.T data attributes) and are using HASS.IO I’ve created simple addon that monitors disk temp using smartctl. Addons schedules CRON and provide data in HA via sensor.hdd_temp.
In my case hddtemp integration did not work because I’m on RPI4 booting form SD card and then switching to SSD. Home assistant is not aware of sda disk.
[Thu Oct 8 16:53:00 CEST 2020][Info] Sensor value: 0)°
[Thu Oct 8 16:53:00 CEST 2020][Info] Sensor update response code: 200
[Thu Oct 8 16:54:00 CEST 2020][Info] Sensor value: 0)°
[Thu Oct 8 16:54:00 CEST 2020][Info] Sensor update response code: 200
[Thu Oct 8 16:55:00 CEST 2020][Info] Sensor value: 0)°
[Thu Oct 8 16:55:00 CEST 2020][Info] Sensor update response code: 200
[Thu Oct 8 16:56:00 CEST 2020][Info] Sensor value: 0)°
[Thu Oct 8 16:56:00 CEST 2020][Info] Sensor update response code: 200
Was looking for possibility of jamesachambers performance test which is not possible (or at least easy) to proceed on HassOS
But start with test is restarting my RPi. Is it normal?
And not always show the score:
Category Test Result
HDParm Disk Read MB/s
HDParm Cached Disk Read MB/s
DD Disk Write 143 MB/s
FIO 4k random read IOPS ( KB/s)
FIO 4k random write IOPS ( KB/s)
IOZone 4k read 9324 KB/s
IOZone 4k write 15390 KB/s
IOZone 4k random read 6279 KB/s
IOZone 4k random write 6340 KB/s
Score:
Compare with previous benchmark results at:
21-02-08 13:11:55 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'startup' with 'before' is deprecated. Please report this to the maintainer of HDD Tools
21-02-08 13:11:55 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'devices' use a deprecated format, the new format uses a list of paths only. Please report this to the maintainer of HDD Tools
This addon has stopped working since Supervisor 2021.02.11. It seems something has changed in the permissions, if I enter the docker and I execute the command manually I get:
ash-5.1# smartctl -a /dev/sda
smartctl 7.2 2020-12-30 r5155 [aarch64-linux-5.4.83-v8] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
Read Device Identity failed: Operation not permitted
If someone is interested, I’ve pushed some code to the addon and now, version 0.50, it must be working again.
If someone finds some problem, please open an issue in the repo.
Sorry but unfortunately I keep getting this error:
[Fri Oct 15 11:03:22 CEST 2021] [INFO] Init run
[Fri Oct 15 11:03:23 CEST 2021] [INFO] Sensor value: null °
[Fri Oct 15 11:03:23 CEST 2021] [INFO] Sensor update response code: 200
[Fri Oct 15 11:03:23 CEST 2021] [INFO] Cron tab SMART update
[Fri Oct 15 11:03:23 CEST 2021] [INFO] Cron tab database update ENABLED
[Fri Oct 15 11:03:23 CEST 2021] [INFO] Updating drives database …
[Fri Oct 15 11:03:26 CEST 2021] [INFO] /usr/share/smartmontools/drivedb.h updated from branches / RELEASE_7_2_DRIVEDB
[Fri Oct 15 11:03:26 CEST 2021] [INFO] Apply cron tab
[Fri Oct 15 11:03:26 CEST 2021] [INFO] Device / dev / sda found - starting CRON
[Fri Oct 15 11:04:01 CEST 2021] [INFO] Sensor value: null °
[Fri Oct 15 11:04:01 CEST 2021] [INFO] Sensor update response code: 200
i use HASSIO on rapsberry PI4 with SSD, can you help?
thank you very much
