hdmi_cec has stopped working for me and actually crashes HA during startup if it’s enabled.
I have tried limiting the configuration to only this with the same result:
homeassistant:
latitude: !secret home_latitude
longitude: !secret home_longitude
elevation: !secret home_elevation
unit_system: !secret unit_system
time_zone: !secret time_zone
http:
api_password: !secret http_password
base_url: !secret http_base_url
ssl_key: !secret http_ssl_key
ssl_certificate: !secret http_ssl_certificate
frontend:
config:
logger:
hdmi_cec: !include cfg/hdmi_cec.yaml
cfg/hdmi_cec.yaml:
devices:
tv: 0.0.0.0
yamaha: 1.0.0.0
teliatv: 1.4.0.0
This is the relevant output from journalctl after a homeassistant restart:
Apr 20 12:40:44 razberry systemd[1]: Starting Home Assistant...
Apr 20 12:40:50 razberry hass[14799]: INFO:homeassistant.loader:Loaded hdmi_cec from homeassistant.components.hdmi_cec
Apr 20 12:40:51 razberry hass[14799]: INFO:homeassistant.setup:Setting up hdmi_cec
Apr 20 12:40:51 razberry hass[14799]: DEBUG:homeassistant.components.hdmi_cec:Parsing config {'yamaha': '1.0.0.0', 'teliatv': '1.4.0.0', 'tv': '0.0.0.0'}
Apr 20 12:40:51 razberry hass[14799]: DEBUG:homeassistant.components.hdmi_cec:Parsed devices: {'yamaha': <pycec.network.PhysicalAddress object at 0x7.....b0>, 'teliatv': <pycec.network.PhysicalAddress object at 0x7.....d0>, 'tv': <pycec.network.PhysicalAddress object at 0x7.....70>}
Apr 20 12:40:51 razberry systemd[1]: homeassistant.service: main process exited, code=killed, status=11/SEGV
Apr 20 12:40:51 razberry systemd[1]: Unit homeassistant.service entered failed state.
hdmi_cec has worked before, and it doesn’t matter if all I have in the config is just hdmi_cec:
or something more complex.
I am not sure what has caused this change. My libcec installation is the same as from when it worked, and I can use cec-client
from the command line without problems.
echo scan | cec-client -s -d 1
shows a list of all devices as it should.
Any ideas on what might be wrong, or how to further debug this?
HomeAssistant 0.42.4 on Raspberry3
