Header missing and no url extension fix it!?
out of the blue the header with the edit pen is gone and i am stuck now.
I frequently updated HA even if i did not use it activly just to have it running with current versions, but now i am not able to use HA because i cannot change anything - the layout is like burned in without any edit funcionality.
Can anybody tell me how to change settings in HA if the edit button is gone!?
I tired several url extensions but they do nothing or i see no change.
?edit=1
?disable_km
?disable_ch
Thanks for help
KR
Daniel
Appending that to your dashboard url should work.
I just tested with a couple of my dashboards and it worked.
Are you logged in as a user with administrator privileges?
Do you have advanced mode enabled in your profile?
you are my hero!
It was the user, seems like i used a standard user without admin privileges.
Thanks for solving that fast.
With the other user i can edit as it should be.
KR
Daniel
