I have a question. I’m using the Google light theme and use the custom mini graph card. That all works very well. But I want to change the title header from the normal cards the same as mini graph.
see the image. I want it like the way from RPI that you can see the title is with an grey background.
At system monitoring it’s a part of the card.
Can someone help me?
Thanks for your reply.
But I think I’m not explaining it correct.
I’ve changed my screenshot. So what I want is more the same sort off title as RPI for the Systemmonitoring
But for systemmonitoring it uses the entity card. So I think I have to change something in the theme or not?
Uhm well i’m confused and i don’t get it…
No it is not the entity card that has the correct title.
What you see by RPI that’s how I want all the title options. But that’s with the card of Horizonstack an the others are entity cards. So that’s why I didn’t understood why the mini graph card has to be changed.
