Heat based zigbee fire alarm?
So I bought a Heiman zigbee (optical) smoke detector for my garage. Which in itself seems to work very well.
However, it gets very humid in the garage from time to time, and as I expected, this triggers the smoke detector.
I haven’t been able to find a temperature style zigbee fire alarm for use in such conditions.
Suggestions?
What conditions? I expect that simple zigbee temperature sensor can detect if your garage temp is suddenly raising.
…humid conditions where an optical sensor is no good.
Yes, I could probably set up a normal temperature sensor. I just wish I knew more about how heat based fire detectors are programmed to behave (that is how would a fire affect the ambient room temperature?).
Worth noting that it is a quite large garage (two cars) with a tall ceiling.
I see… Some sensitivity adjustment would help to not detect “fog”. Temp sensing works well, but it’s not detecting initial state. Let’s say you have some wires starting a fire, smoke detector would give alarm quite immediately giving you a chance to save almost everything. Temp sensor trickers when you have strong fire already on.
I just discovered that there is such a zigbee heat fire detector from the brand Frient: Intelligent Heat Alarm - Zigbee heat and fire detector for smart home - frient
Don’t know if you have bought them or have issues. But the Frient lineup seems to have issues with Zigbee native. Pairing is a “nightmare” but will work when paired. Zigbee2MQTT seems more reliable.
Frient Smoke Detector / ZHA - #55 by Tuxforce
