Hello all can somebody help me how to control this device in HA
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.10.3",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Brussels",
"os_name": "Linux",
"os_version": "5.15.72",
"supervisor": "2022.10.0",
"host_os": "Home Assistant OS 9.2",
"docker_version": "20.10.17",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"smartthinq_sensors": {
"version": "0.24.2",
"requirements": [
"pycountry>=20.7.3",
"xmltodict>=0.12.0",
"cchardet>=2.1.7"
"hacs": {
"version": "1.27.2",
"requirements": [
"aiogithubapi>=22.2.4"
"adaptive_lighting": {
"version": "1.1.0",
"requirements": []
"integration_manifest": {
"domain": "tuya",
"name": "Tuya",
"documentation": "https://www.home-assistant.io/integrations/tuya",
"requirements": [
"tuya-iot-py-sdk==0.6.6"
"dependencies": [
"ffmpeg"
"codeowners": [
"@Tuya",
"@zlinoliver",
"@frenck"
"config_flow": true,
"iot_class": "cloud_push",
"dhcp": [
"macaddress": "105A17*"
"macaddress": "10D561*"
"macaddress": "1869D8*"
"macaddress": "381F8D*"
"macaddress": "508A06*"
"macaddress": "68572D*"
"macaddress": "708976*"
"macaddress": "7CF666*"
"macaddress": "84E342*"
"macaddress": "D4A651*"
"macaddress": "D81F12*"
"loggers": [
"tuya_iot"
"is_built_in": true
"data": {
"endpoint": "https://openapi.tuyaeu.com",
"auth_type": 0,
"country_code": "32",
"app_type": "tuyaSmart",
"mqtt_connected": true,
"disabled_by": null,
"disabled_polling": false,
"name": "Hottub \u2668\ufe0f\u2668\ufe0f",
"model": "Heatbump",
"category": "ktkzq",
"product_id": "qibn9aspvoaaubbh",
"product_name": "\u70ed\u6cf5\u63a7\u5236\u5668",
"online": true,
"sub": false,
"time_zone": "+01:00",
"active_time": "2021-10-18T14:46:02+00:00",
"create_time": "2021-10-18T14:46:02+00:00",
"update_time": "2022-06-27T11:14:07+00:00",
"function": {
"switch": {
"type": "Boolean",
"value": {}
"temp_set": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": 7,
"max": 60,
"scale": 0,
"step": 1
"mode": {
"type": "Enum",
"value": {
"range": [
"hot",
"cold"
"status_range": {
"switch": {
"type": "Boolean",
"value": {}
"temp_set": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": 7,
"max": 60,
"scale": 0,
"step": 1
"temp_current": {
"type": "Integer",
"value": {
"unit": "\u2103",
"min": -30,
"max": 150,
"scale": 0,
"step": 1
"mode": {
"type": "Enum",
"value": {
"range": [
"hot",
"cold"
"status": {
"switch": true,
"temp_set": 37,
"temp_current": 33,
"mode": "hot"
"home_assistant": {
"name_by_user": null,
"disabled": false,
"entities": []
