Heat Pump Optimizer blueprints
Heat Pump Optimizer is a custom integration (HACS) that plans heat-pump
space heating and hot water 24 hours ahead against hourly electricity
prices and a self-learning model of your house, publishing the plan on
sensors for your own automations to act on.
Three blueprints, one per worked example in the documentation:
  1. Charge an EV from grid headroom — starts a charger switch while the
    Cost Power Headroom sensor (min(main fuse, capacity threshold) −
    current house draw, clamped at zero, in kW) sits above your start
    threshold, stops it below your stop threshold.
    https://raw.githubusercontent.com/tvofi/heatpump_optimizer/main/blueprints/automation/charge_ev_from_grid_headroom.yaml
  2. Economy mode through the evening price peak — switches the optimizer’s
    operating mode when the current electricity price crosses your
    expensive threshold, and back when it falls. Economy rides out
    expensive hours up to 1.5 °C below the comfort floor (never below
    15 °C); auto hands full optimization back.
    https://raw.githubusercontent.com/tvofi/heatpump_optimizer/main/blueprints/automation/economy_mode_on_price_peak.yaml
  3. Notify when a manual plan takes over — raises a persistent
    notification while an apply_manual_plan override pins the heating
    slots, with the expiry time from the plan sensor’s manual_override
    attribute.
    https://raw.githubusercontent.com/tvofi/heatpump_optimizer/main/blueprints/automation/notify_on_manual_plan.yaml
Import any of them from Settings → Automations & Scenes → Blueprints →
Import Blueprint. Each blueprint takes the sensor and the thresholds as
inputs, so nothing is hard-coded to the default entity ids. The same
examples as inline YAML, with the sensor’s availability rules spelled out:
Hello tvofi,
Thanks for contributing to the community with a new Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
