Heater-Cooler accessory type support
Currently only climate is supported. I want heater-cooler support as I do not use a thermostat.
Heater-cooler accessory type also support additional configuration not available in climate like air swing/oscillation and fan speed.
Errr yes climate supports air swing, oscillation and fan speed.
Home assistant needs to support a new homekit accessory type, currently climate is mapped to Thermostat and it needs to offer HeaterCooler as an additional option Apple Developer Documentation
Climate supports both heating an cooling.
No, what I’m saying is that climate could be mapped to 2 types of Homekit services: Thermostat or HeaterCooler. Homeassistant only supports exposing climate as Thermostat, but it would be great if we could choose which HK service to use when exposing it.
Services in HK related to climate:
Additional characteristics HeaterCooler supports on top of Thermostat (fan & swing):
Hope this helps to clarify the request.
I second this request.
The reasons are
  1. heater-cooler integrates fan swing and fan speed better
  2. Siri. We use an air conditioner for both heating and cooling. Unlike a thermostat, it’s normally turned off until bedtime or you are staying in the room. So when I tell Siri to “turn on the bedroom air-conditioner (name of the device)”, a heater-cooler would default to the last mode setting, whereas if it’s a thermostat Siri will say “cooling the house…” and turn to cooling mode in the winter! You would have to specify “turn on heater in the bedroom” otherwise results are kind of unpredictable and messes up all the presets.
This would be wonderful. We have Daikin heat pumps whose fan speed and swing settings are presently not exposed properly to HomeKit.
Adding my vote to support this. I’m using Mitsubishi2MQTT on our heat pumps and would love to have full control of all the modes, fans, and vanes. I tried using MQTTThing in Homebridge, which does use the Heater Cooler setting, but I’m having other configuration issues with it.
Are there any updates on this?
I just spent a few hours working around this issue by splitting my device into a Fan entity and a Climate entity. It would be nice to natively support HeaterCooler for devices shared from HA to homekit. (HomeKit Bridge)
This thread seems to confuse homekit and home assistant.
The current homekit bridge in Home assistant only supports thermostat, not heater-cooler, in homekit
So your request is to fix climate support in the homekit bridge integration?
Would like to check is this still not possible? Checking the doc looks like it’s always mapped to Thermostat, and beside the lack of fan support, does Thermostat support heat_cool mode with low and high thresholds?
I also support this, having proper heater-cooler accessory instead of thermostat for air conditioner is crucial, the fan speed integration as a fan is no ideal and the lack of swing/oscillation is a bummer.
I appreciate all the hard work on the HomeKit bridge integration and I wish we could see a heater cooler device in the future :pray:t3:
