After some researches, I found the template sensors…
template:
- sensor:
- name: "Time heater on"
unique_id: time_heating
device_class: 'duration'
unit_of_measurement: min
state_class: total_increasing
state: >
{% if is_state('sensor.heater', 'heat') %}
{{ (as_timestamp(now()) - as_timestamp('2023-05-01T06:54:44.000Z'))/60}}
{% else %}
{{ this.state }}
{% endif %}
I dont’ know yet why, but yesterday, it seemed to work. Now, it gives me absurd results.
The dev mod gives me the result of
{{ (as_timestamp(now()) - as_timestamp(‘2023-05-01T06:54:44.000Z’))/60}}
when the heater’s state is ‘heat’
The logs give me this error
Error adding entities for domain sensor with platform template
Error while setting up template platform for sensor
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 583, in state
numerical_value = float(value) # type:ignore[arg-type]
ValueError: could not convert string to float: 'unavailable'
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 471, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 749, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 849, in add_to_platform_finish
await self.async_added_to_hass()
File "/usr/src/homeassistant/homeassistant/components/template/sensor.py", line 224, in async_added_to_hass
await super().async_added_to_hass()
File "/usr/src/homeassistant/homeassistant/helpers/template_entity.py", line 409, in async_added_to_hass
await self._async_template_startup()
File "/usr/src/homeassistant/homeassistant/helpers/template_entity.py", line 380, in _async_template_startup
result_info.async_refresh()
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 974, in async_refresh
self._refresh(None)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1154, in _refresh
self.hass.async_run_hass_job(self._job, event, updates)
File "/usr/src/homeassistant/homeassistant/core.py", line 618, in async_run_hass_job
hassjob.target(*args)
File "/usr/src/homeassistant/homeassistant/helpers/template_entity.py", line 349, in _handle_results
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 590, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 654, in _async_write_ha_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 596, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 585, in state
raise ValueError(
ValueError: Sensor sensor.time_heating has device class 'duration', state class 'total_increasing' unit 'min' and suggested precision 'None' thus indicating it has a numeric value; however, it has the non-numeric value: 'unavailable' (<class 'str'>)
well, I’m quite stucked into nowhere ![:expressionless: :expressionless:](https://community.home-assistant.io/images/emoji/twitter/expressionless.png?v=12)
if someone has any clue, I’d be glad to give it a try
thanks
