Heating Automation Fine Tuning help
Hoping someone can help me bottom out what the issue is with this automation. I don’t believe that it’s far away from working, but don’t think I have the ‘And / Or’ rules set right?
- id: '1662749121139'
  alias: Raise Tester 2
  description: ''
  - platform: time
    at: 06:00:00
  - platform: time
    at: '16:00:00'
  - platform: state
    entity_id:
    - person.me
    to: home
  - platform: state
    entity_id:
    - person.wife
    to: home
  condition:
  - condition: or
    conditions:
    - condition: time
      before: 09:00:00
      after: 06:00:00
    - condition: time
      before: '21:00:00'
      after: '16:00:00'
    - condition: and
      conditions:
      - condition: state
        entity_id: person.me
        state: home
      - condition: or
        conditions:
        - condition: state
          entity_id: person.wife
          state: home
  - service: climate.set_temperature
      temperature: 20
      entity_id: climate.test_stat
  mode: single
- id: '1662749734218'
  alias: Lower Test 2
  description: ''
  - platform: time
    at: 06:00:00
  - platform: time
    at: '16:00:00'
  - platform: state
    entity_id:
    - person.me
    to: not_home
  - platform: state
    entity_id:
    - person.wife
    to: not_home
  condition:
  - condition: and
    conditions:
    - condition: state
      state: not_home
    - condition: state
      state: not_home
    - condition: or
      conditions:
      - condition: time
        before: 09:00:00
        after: 06:00:00
      - condition: time
        before: '21:00:00'
        after: '16:00:00'
      temperature: 17
The concept is that the heating should set the temperature to 25degC when either me or my Wife is at home within the given time frames. However, should we both leave the house (not_home) the temp should set to a lower temp. If the one of us returns, then the heating should return to the higher temperature.
If, at any of the Trigger times, neither of us are in, the Temperature target should go to the lower temperature.
The automation is not far away. It does as it should when leaving and entering the house. But, for some reason when neither of us are in at any of the Trigger times, the temperature is still set to the higher temp (rather than the lower).
I suspect I have the And / Or Rules wrong…but can’t work out what.
For information, this query is a follow on from my last post that finity kindly assisted me with.
https://community.home-assistant.io/t/heating-automation-improvement-help/457844
Many Thanks in advance
Probably my advanced age, but I’m finding this a little hard to follow.
It doesn’t matter who is home, so I would start with an input-boolean flag which had its own automation to turn it on and off as people come and go. This gives the heating automation a very simple trigger:
someone is home - yes
turn on the heating
someone is home - no
turn off the heating
Times can then be added as conditions.
