I have an automation that should check
- Weekday 8am to 4pm
- Someone is home
- One of two temp sensors is less than 19
if this is true it should fire up the heating.
As you can see one of these sensors is below 19C and has been since 8am
Looking at the automation it hasn’t fired since Thursday morning but not sure why it hasn’t kicked in today. I have just ran it manually and it has all worked and the heating has kicked in so the logic appears sound which suggests a problem with the triggers?
The automation is
alias: House Temp - Day - Heat
description: ''
- platform: numeric_state
entity_id: sensor.temp6_temperature
below: '19'
entity_id: sensor.kitchen_temperature
below: '19'
condition:
- condition: time
after: '08:00'
before: '16:00'
weekday:
- mon
- tue
- wed
- thu
- fri
- condition: state
entity_id: group.anyone_home
state: home
- service: climate.set_temperature
device_id: abc123
temperature: 22
mode: single
with the group being setup as
group:
anyone_home:
entities:
- person.bill
- person.ted
Is there anything that looks wrong with this automation / is there anything I can do to work out why it hasn’t kicked in?
Looking at the show trace details from the automation shows a run through the code at 03:52 (which stopped because the time didn’t meet the criteria) but nothing else
