Recently i made the move from openhab to HA. I am pretty much setup back to how i was when using openhab regarding automations and entities apart from my heating setup. Could anyone help me translate this rule to a HA Automation please?
rule "Living Room heating"
when
Item Living_Room_Temp_Setpoint changed or
Item Living_Room_Temperature changed
then
var Number cur_temp = Living_Room_Temperature.state as Number
var Number setpoint = Living_Room_Temp_Setpoint.state as Number
val Number hysteresis = 0.2
if (cur_temp < (setpoint - hysteresis) ){
if (Living_Room_Radiator_Valve.state != ON) {Living_Room_Radiator_Valve.sendCommand(ON)}
else if(cur_temp > setpoint + hysteresis) {
if (Living_Room_Radiator_Valve.state != OFF) {Living_Room_Radiator_Valve.sendCommand(OFF)}
end
Basically if anyone can’t tell the rule is triggered when the living room current temp or the setpoint changes. It then compares them and if current temp is 0.2 degrees over the setpoint it turns the radiator valve off. If the current temperature is 0.2 degrees below the setpoint it turns the radiator on. I looked into the threshold helper but you can’t set it to compare 2 entities. It just looks for upper and lower limits of a entity/sensor.
In Home Assistant, the Generic Thermostat integration is designed for controlling heating/cooling based on target and ambient temperatures. It also allows you to specify hysteresis (a.k.a.‘deadband’), plus it can easily be displayed in the UI using the Thermostat card.
This is how my entities are set up.
Current temperature sensor.living_room_temperature
Setpoint input_number.living_room_target_temperature
Radiator switch.living_room_radiator
Ive already tried this, the target temperature cant be linked to an entity, only a number that can be altered with the gauge on the thermostat card. Im planning to setup helpers that specify a different temperature for different times on the day, ie MORNING, DAY, EVENING and NIGHT. Send this data to the corresponding target temperature in each room, then the automation above will do the rest. If you know of a way i can link an entity to the target temperature in the generic_thermostat please let me know.
You’re approaching it in the opposite direction of how it’s normally done in Home Assistant. You don’t (and can’t) make the target temperature an entity. You set the target temperature with climate.set_temperature.
To set a different target temperature, based on time-of-day, you can use an automation with Time Triggers or a State Trigger monitoring the Schedule integration. You can even use Local Calendar for scheduling but it’s probably more scheduling flexibility than most people need for controlling heating.
Sorry I just had a light bulb moment and understand what you mean now. So I create time of day triggers with different temperatures for each room. Then use the climate.set_temperature to the send that temperature to the Living_Room_Thermostat entity and Bedroom_Thermostat entity etc which will in turn change the target temperature in the generic_thermostat?
