Dear all,
I am currently using the ‘Thermostat card’ but now I have seen on the following picture that you can also display the ‘preset modes’, but I can’t do that. I am using KNX and it is a KNX thermostat. I can select the preset modes in the Thermastat Card, but I can’t manage to display them in the photo, nor do I see the heating symbol, does anyone have any idea? I use Mushroom climate-card
In the option of your card, you have the “control of temperature” that should be tickled, as you can change the desired temperature.
At the same level but on the left, you have a list “themostat modes”. You select all the modes you want to be able to select, and you should have now a button to select the mode you wish to use.
There are a lot of possibilities with this card, do not hesitate to test to have the best result for you
