Heating control in city-heating house
Hi everyone,
It’s my first post here and I hope I’m not doing anything wrong.
I just settled in a house and I had a home assistant before in my appartment, mostly for lights, camera and widgets. Now that I can do whatever I want on my setup and wallls, I’d like to be able to completely control the heating of my house through home assistant.
It’s a dutch house with city heating (stadverwarming). Floor heating downstairs and several other heaters around the house.
There is a honeywell thermostat connected to a main valve for the complete system (24v valve, could be easy to automate this one with a relay) (Link to the product). Each radiator has a thermostatic head in M30 form and the floor heating has a circulating pump in addition to the thermostatic head. I’m aiming at reducing our electricity and heating cost by switching off the heating when we don’t need it and the pump as well.
To control the pump, I purchased some SonOff devices.
But I’m looking for thermostats that can fit on the radiators and report the room temperature to hass and also regulate the temperature in the room. I’d prefer something working well with hass and not through another app or cloud service, but not mandatory.
I did some research and saw that there is Netatmo and Tado. What do you think about them, are you using them, and is there any other good product around ?
Standard M30 actuators connected to sonoff basics with tasmota firmware, then connect temp sensor like a dht22 to the sonoffs. Put all sonoffs for the actuators in a group in home assistant and if any sonoffs in the group is on then run the boiler/pump using automation. Use generic thermostat to control the sonoffs.
Have a look here
