Heating Plans for Rooms?
maybe this is of any help to you: I am running a similar set-up. HM-CC-RT-DN and (except for the kitchen) HM-TC-IT-WM-W-EU.
There are two heating plans, one for normal working weeks and one for staying at home. Based on two helpers, the respective plan is activated. Currently the helpers are set manually, but my intention is to trigger these based on a google calendar.
alias: ui_hz_SetHeating
description: ""
  - platform: state
    entity_id:
      - input_select.hz_season
      - input_select.hz_homemode
    for:
      hours: 0
      minutes: 0
      seconds: 10
condition: []
  - choose:
      - conditions:
          - condition: state
            entity_id: input_select.hz_season
            state: Summer
        sequence:
          - data:
              device_id: a8fb8fd303a200bbfdcaa857bf087940
              channel: 2
              parameter: MANU_MODE
              value: "4.5"
              value_type: double
              rx_mode: WAKEUP
            action: homematicip_local.set_device_value
          - data:
              device_id: 8c302fe6e3683d646cf67606159d6469
              channel: 2
              value: "4.5"
              value_type: double
              rx_mode: WAKEUP
          - data:
              device_id: 17ab12711493f6b870bfb17bce2ff58a
              channel: 2
              value: "4.5"
              value_type: double
              rx_mode: WAKEUP
          - data:
              device_id: f0a0bc130124c8eb2091f5116e073ba3
              channel: 4
              value: "4.5"
              value_type: double
              rx_mode: WAKEUP
      - conditions:
          - condition: state
            state: Winter
          - condition: state
            entity_id: input_select.hz_homemode
            state: Verreist
        sequence:
          - data:
              channel: 2
              value: "17"
              value_type: double
              rx_mode: WAKEUP
          - data:
              channel: 2
              value: "17"
              value_type: double
              rx_mode: WAKEUP
          - data:
              channel: 2
              value: "17"
              value_type: double
              rx_mode: WAKEUP
          - data:
              channel: 4
              value: "17"
              value_type: double
              rx_mode: WAKEUP
      - conditions:
          - condition: state
            state: Winter
          - condition: state
            state: Daheim
        sequence:
          - data:
              paramset_key: MASTER
              paramset:
                WEEK_PROGRAM_POINTER: 1
            action: homematicip_local.put_paramset
          - data:
              channel: 2
              parameter: AUTO_MODE
              value_type: boolean
              rx_mode: WAKEUP
              value: "1"
          - data:
              paramset:
          - data:
              channel: 2
              value_type: boolean
              rx_mode: WAKEUP
              value: "1"
          - data:
              paramset:
          - data:
              channel: 2
              value_type: boolean
              rx_mode: WAKEUP
              value: "1"
          - data:
              channel: 4
              value_type: boolean
              rx_mode: WAKEUP
              value: "1"
      - conditions:
          - condition: state
            state: Winter
          - condition: state
            state: Automatik
        sequence:
          - data:
              paramset:
                WEEK_PROGRAM_POINTER: 0
          - data:
              channel: 2
              value_type: boolean
              rx_mode: WAKEUP
              value: "1"
          - data:
              paramset:
          - data:
              channel: 2
              value_type: boolean
              rx_mode: WAKEUP
              value: "1"
          - data:
              paramset:
          - data:
              channel: 2
              value_type: boolean
              rx_mode: WAKEUP
              value: "1"
          - data:
              channel: 4
              value_type: boolean
              rx_mode: WAKEUP
              value: "1"
mode: single
Thank you very much, very cool! I have a few weeks off soon, during which I also plan to switch from FHEM to Home Assistant. I will gladly take your code as a suggestion :slight_smile:
and even easier it gets once you discover the unignore feature :crazy_face: :
https://github.com/SukramJ/hahomematic/discussions/1708
I will have a look later :blush:
