So, I have a Duel Programmer for my heating, CH and HW. I have a room thermostat that is hardwired to the programmer to control CH. The HW is simply a “HW” button on the programmer that needs to be pressed to demand HW.
I want to use a Z-Wave battery operated thermostat that and a device to replace my Programmer. I guess that device needs to be 2 part - 1 controlled via the thermostat and 2 being an On/Off type switch , both integrated by HA,
What do I need to search for in terms of the replacement for my programmer, what is the device called or the search term I need to use here and/or in Google.
I can control my house with any MQTT client, without having to resort to HA.
It also makes it relatively easy to use with other controllers. I can switch from HA to OpenHab or something else without having to check for compatability.
understood Graham, however my preference is a single managed system, using hass.io , I’ve PMd you a question on this which was a detailed one and lengthy
