Currently I am looking for a heating solution compatible with home assistant. There are a lot of products on the market and I don’t understand which are reliable and comfortable in usage. So I’m asking for your advise.
This is a setup for flat.
I will have three electrical floor heating zones.
Gas boliler BOSCH WBN 6000-24C RN compatible with opentherm protocol is already installed.
Also there are five radiators connected to the boiler.
I want to achieve centralized solution to control temperature in all my rooms.
In my plans is to develop opentherm master for a boiler which will take into account floors, valves and outside temperatures to select optimal boiler mode.
If you know proprietary solution it would be perfect.
I took a look at Danfoss Link but it is very closed system. And there is no way I can integrate it somewhere else.
I am using Plugwise Adam which has an integration in HA. Plugwise offers room thermostats, valves for your radiators and switches for floor heating.
Works like a charm.
If your radiators thermostat are in every room you could use Danfoss ally Zigbee Thermostats, but that of course depends on if you have a Zigbee network (or want one) I use them and they work really well
