I just upgraded from 0.36 to 0.39 and the UI for the heating set temperature has changed from a slider to an up/down number.
My problem is that I press up to go from 16 to 20 for example, and it then jumps back to 16 and then counts up really slowly, sending a message for each temperature point (at 0.5 deg intervals) between 16 and 20.
The slider used to just send one message once it was set and this worked well.
Does anyone else have this problem? Is there a way to fix this behaviour?
