Heatit product line
Hi. I was looking into the Device Database of Open Z-Wave http://www.openzwave.net/device-database and I couldnt find https://www.heatit.com/ product line. So I wrote them an email and asked if they in any way work to integrate their products with Home Assistant or Open Z-Wave. Their answer, translated from norwegian was:
“We do not collaborate with Home Assistant directly, if they want to integrate our units, we are happy to send units to them.”
So it seems like they would like to but dont know how. Do you have any suggestions on how I should answer them?
Br
Staffan
Now I found this on https://github.com/OpenZWave/open-zwave
So the Open Z- Wave project considers them sponsored by Heatit already, but hey dont list their devices.
Now I actually found some Heatit products in the Open Z-Wave device Database. They are listed under ThermoFloor AS wich is the norwegian company that makes the Heatit product line. So the floor thermostat products are there, just not the Heatit Z-Smoke fire alarm, that I was looking for. It is a rather new product so maybe it gets added in the future.
Is it really ThermoFloor who makes the Heatit product line ?
Heatit Z-DIN 616 product is exactly the same as ZIF5028 from Logic Group
https://www.heatit.com/z-wave/heatit-z-din-616/
It would not surprice me if it is different brandings of a chinese origin as many products today, but I think they hold the brand Heatit at least. The guy who answered me had Thermofloor in his email adress line.
My “Heatit DIN 616” seems to identify in Home assistant as “Logic Soft” and that is an old name for
Logic Group devices (e.g former Logic Soft and Logic Home Control).
So I’m pretty sure Heatit is a branded product from Logic Group
Danish, yea seems plausible. Anyway, hassio/ozw did not recognice the Heatit Z-Smoke unit but I could make it work. I tried to understand how to make xml-files for ozw to include in their repository but it was to complicated for me. If there was a more noob-adapted guide I would add my devices to the database with pull requests.
Has anyone tried to integrate the wifi version of the heatit thermostat?
Regards
Johan
I’m also interested in integrating “Heatit Wi-Fi” to home assistant. I have 4 of those floor thermostats. Anyone knows?
Heatit WiFi will likely not be supported in HA - the API is not open, I’ve been told by the heatit support. Maybe next generation.
Yes i know, i was told the same. But i was thinking that maybe someone reverse engineered the API which should be possible since it works with Alexa and google home.
I looked into the network traffic and saw that they are using mqtts (encrypted) to communicate with home base. Really boring that they do not allow integration. Totally wasted money for me.
Thanks for heads up. I guess they dont want my money.
Guess this is a bit late here, but I read on the webpage the Heatit wifi6 has an open API. Anyone tried to configure this?
I don’t have their product yet, but asked from their support about status of the open API as it is not documented anywhere. They sent me reply “It’s ready” and 400 lines yaml.
So in case somebody wants to implement it I recommend to ask it from them. I don’t want to paste the whole document here.
openapi: 3.0.0
servers:
  # Added by API Auto Mocking Plugin
  - description: Local HTTP API
    url: https://{API Url}
    variables:
      API Url:
        default: "192.168.104.118"
        description: Base Url to API
info:
  version: "6.0.0"
  title: WiFi 6
  description: The API documentation for WiFi 6 thermostat
  contact:
    url: https://heatit.com/contact
    email: [email protected]
  termsOfService: https://heatit.com/terms-of-use-private
externalDocs:
  description: Heatit's documents page
  url: http://documents.heatit.com
Interesting. Just went with a Wifi6 in the cabin for simplicity, but now regretting somewhat as Z-Wave or Zigbee would probably be easier in the long run.
After more and more devices we’ve replace could be replaced with something that has “smart” capabilities, I’m now looking into getting everything gathered in HA for a better overview, and more automation.
There are so many apps, and all of them want you to define rooms, places and automations etc. It’s ridiculous how everyone think you want them as the automation hub.
But HeatIt seems to be doing the right thing with their products, like f.ex Shelly, easily skipping their automation system and using it for your own;
“ When used with Wi-Fi, the thermostat can communicate over a local API, allowing the user to integrate it with a local gateway, server, controller that offers such a service, without the need to connect it to the cloud.”
Heatit Wifi6 thermostat documents, Swagger and Yaml for OpenAPI found from here: https://documents.heatit.com/5430542/heatit-wifi6-white-ral-9003
…and for all Heatit products: https://documents.heatit.com/
I have made the HA “Heatit WiFi6” -integration for my own use. I am also releasing it freely available to public. The integration communicates directly with the device, without a public cloud.
https://github.com/mattik-gh/heatit_wifi6
Use at your own risk. There is no guarantee that it will work for you without any problems. If anyone wants to further develop it, they are free to fork the repo and continue development. Please leave a comment of the original code source and release also improved versions use for everyone. Thanks.
I think I won’t put much more effort into this integration, as long as it works for me.
Br, Matti
Great!
I’ll test it on my setup. :+1:
Just installed it and tested. Got my thermostat showing.
I haven’t had time to investigate too much with HACS, but is there an easy way to get that link that automatically adds the repo to Home Assistant?
Also, I have the thermostat set to use floor sensor, but the default view in Home Assistant is air temp, and I can’t seem to change it.
Might be an error on my side, but I only get one entity, and no kWh etc. listed in HA, but that should maybe not be the case (yet) either?
