I have recently bought a HeatIt Z-Dim device, which replaced a Fibaro Dimmer 2. I have some issues with it. I keep getting dead node. When it does work most commands are delayed, they also seem to delay the other Z-Wave dimmer I have (TBK plug).
I use a HeatIt Scene controller (node 16), which triggers a scene to turn on all lights, which include the HeatIt Z-Dim (node 17) and the TBK dimmer (node 14). What I notice is that the Z-Wave devices are turned on (or off) seconds later (more than 5 seconds). I also see that the Z-Dim (node 17) will turn on and then the TBK (node 14) will turn on quickly after. I guess that the Z-Wave mesh might be disturbed somehow, or that there is something wring with Z-Dim (node 17) and that TBK (node 14) is connected to the HA “further out” the Z-dim (node 17) in the mesh network.
I have tried to exclude the Z-Dim, but it won’t.
I have not set up a secure key, but have assumed that new versions of HA has done this automatically.
How can I resolve this, making the Z-Dim appear correctly (and not die)?
Is the delay commands related to taking out the Fibaro Dimmer (node 8) of the system (I did not exclude it)?
Below is the OZW logs:
2020-04-05 10:26:43.840 Detail, Node017, Queuing (Send) MeterCmd_Get (Node=17): 0x01, 0x0a, 0x00, 0x13, 0x11, 0x03, 0x32, 0x01, 0x00, 0x25, 0x52, 0xb0
2020-04-05 10:26:43.840 Detail, Node017, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_METER
2020-04-05 10:26:43.840 Detail, Node017, Queuing (Send) MeterCmd_Get (Node=17): 0x01, 0x0a, 0x00, 0x13, 0x11, 0x03, 0x32, 0x01, 0x10, 0x25, 0x53, 0xa1
2020-04-05 10:26:43.840 Info, Node017, CentralScene RequestState: 4
2020-04-05 10:26:43.840 Info, Node017, CentralScene: Not a StaticRequest
2020-04-05 10:26:43.841 Detail, Node017, Queuing (Query) Query Stage Complete (Dynamic)
2020-04-05 10:26:43.841 Info, Node017, Processing (Send) Nonce Request message (Callback ID=0x50, Expected Reply=0x04)
2020-04-05 10:26:43.841 Info, Node017, Sending (Send) message (Callback ID=0x50, Expected Reply=0x04) - Nonce_Get(SwitchBinaryCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x11, 0x02, 0x98, 0x40, 0x05, 0x02:
2020-04-05 10:26:43.848 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:26:43.848 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:26:43.948 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x02, 0x00, 0xeb
2020-04-05 10:26:43.949 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2020-04-05 10:26:43.949 Info, Node017, Request RTT 107 Average Request RTT 330
2020-04-05 10:26:44.029 Detail, Node017, Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x11, 0x0a, 0x98, 0x80, 0x14, 0xc8, 0xd6, 0x36, 0x9b, 0x65, 0xd0, 0x6f, 0xbb, 0x00, 0x2c
2020-04-05 10:26:44.030 Info, Node017, Received SecurityCmd_NonceReport from node 17
2020-04-05 10:26:44.030 Info, Node017, Sending (Send) message (Callback ID=0x54, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=17): 0x01, 0x09, 0x00, 0x13, 0x11, 0x02, 0x25, 0x02, 0x25, 0x54, 0xa0
2020-04-05 10:26:44.043 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:26:44.044 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:26:44.179 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x54, 0x00, 0xbd
2020-04-05 10:26:44.179 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x54 received (expected 0x54)
2020-04-05 10:26:44.179 Info, Node017, Request RTT 339 Average Request RTT 334
2020-04-05 10:26:44.179 Detail, Expected callbackId was received
2020-04-05 10:26:44.255 Detail, Node017, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x11, 0x02, 0x98, 0x40, 0xbb, 0x00, 0x81
2020-04-05 10:26:44.255 Info, Node017, Received SecurityCmd_NonceGet from node 17
2020-04-05 10:26:44.256 Info, NONCES: 0x03, 0xf3, 0x40, 0x28, 0x4d, 0xa6, 0xb2, 0xd8
2020-04-05 10:26:44.256 Info, NONCES: 0x61, 0x7b, 0xe6, 0x9a, 0xa5, 0x9f, 0xd4, 0x81
2020-04-05 10:26:44.256 Info, NONCES: 0x43, 0x3c, 0x5e, 0x53, 0x6d, 0xdb, 0x3b, 0x0a
2020-04-05 10:26:44.256 Info, NONCES: 0x26, 0xc3, 0x4a, 0x68, 0xb2, 0x01, 0xa2, 0x2f
2020-04-05 10:26:44.256 Info, NONCES: 0xbb, 0x04, 0xd3, 0x5c, 0x27, 0x9a, 0x7c, 0x5d
2020-04-05 10:26:44.256 Info, NONCES: 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2020-04-05 10:26:44.256 Info, Node017, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x11, 0x0a, 0x98, 0x80, 0xbb, 0x04, 0xd3, 0x5c, 0x27, 0x9a, 0x7c, 0x5d, 0x05, 0x01, 0x56:
2020-04-05 10:26:44.267 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:26:44.267 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:26:44.396 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x01, 0x00, 0xe8
2020-04-05 10:26:44.396 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2020-04-05 10:26:44.396 Info, Node017, Request RTT 556 Average Request RTT 445
2020-04-05 10:26:44.486 Detail, Node017, Received: 0x01, 0x1f, 0x00, 0x04, 0x00, 0x11, 0x17, 0x98, 0x81, 0x5a, 0xf4, 0x6f, 0xa2, 0x5b, 0x83, 0x18, 0x63, 0x53, 0x7c, 0x01, 0x85, 0xbb, 0x6d, 0x40, 0xa8, 0x42, 0xf0, 0x6f, 0xbf, 0x77, 0xbb, 0x00, 0x00
2020-04-05 10:26:44.487 Info, Raw: 0x98, 0x81, 0x5a, 0xf4, 0x6f, 0xa2, 0x5b, 0x83, 0x18, 0x63, 0x53, 0x7c, 0x01, 0x85, 0xbb, 0x6d, 0x40, 0xa8, 0x42, 0xf0, 0x6f, 0xbf, 0x77, 0xbb
2020-04-05 10:26:44.487 Detail, Node017, Decrypted Packet: 0x00, 0x25, 0x03, 0xff
2020-04-05 10:26:44.487 Info, Node017, Response RTT 647 Average Response RTT 725
2020-04-05 10:26:44.487 Info, Node017, Received SwitchBinary report from node 17: level=On
2020-04-05 10:26:44.487 Detail, Node017, Initial read of value
2020-04-05 10:26:44.487 Detail, Node017, Expected reply and command class was received
2020-04-05 10:26:44.487 Detail, Node017, Message transaction complete
2020-04-05 10:26:44.487 Detail, Node017, Removing current message
2020-04-05 10:26:44.488 Detail, Node017, Notification: ValueChanged
2020-04-05 10:26:44.502 Detail,
2020-04-05 10:26:44.502 Info, Node017, Processing (Send) Nonce Request message (Callback ID=0x51, Expected Reply=0x04)
2020-04-05 10:26:44.502 Info, Node017, Sending (Send) message (Callback ID=0x51, Expected Reply=0x04) - Nonce_Get(SwitchMultilevelCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x11, 0x02, 0x98, 0x40, 0x05, 0x02:
2020-04-05 10:26:44.510 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:26:44.511 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:26:44.628 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x02, 0x00, 0xeb
2020-04-05 10:26:44.628 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2020-04-05 10:26:44.628 Info, Node017, Request RTT 125 Average Request RTT 285
2020-04-05 10:26:44.710 Detail, Node017, Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x11, 0x0a, 0x98, 0x80, 0x1a, 0x83, 0xc6, 0xdd, 0x33, 0x80, 0xa0, 0x38, 0xbb, 0x00, 0xf8
2020-04-05 10:26:44.710 Info, Node017, Received SecurityCmd_NonceReport from node 17
2020-04-05 10:26:44.710 Info, Node017, Sending (Send) message (Callback ID=0x55, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=17): 0x01, 0x09, 0x00, 0x13, 0x11, 0x02, 0x26, 0x02, 0x25, 0x55, 0xa2
2020-04-05 10:26:44.724 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:26:44.724 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:26:44.859 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x55, 0x00, 0xbc
2020-04-05 10:26:44.859 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x55 received (expected 0x55)
2020-04-05 10:26:44.859 Info, Node017, Request RTT 356 Average Request RTT 320
2020-04-05 10:26:44.859 Detail, Expected callbackId was received
2020-04-05 10:26:44.935 Detail, Node017, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x11, 0x02, 0x98, 0x40, 0xbb, 0x00, 0x81
2020-04-05 10:26:44.936 Info, Node017, Received SecurityCmd_NonceGet from node 17
2020-04-05 10:26:44.936 Info, NONCES: 0x03, 0xf3, 0x40, 0x28, 0x4d, 0xa6, 0xb2, 0xd8
2020-04-05 10:26:44.936 Info, NONCES: 0x61, 0x7b, 0xe6, 0x9a, 0xa5, 0x9f, 0xd4, 0x81
2020-04-05 10:26:44.936 Info, NONCES: 0x43, 0x3c, 0x5e, 0x53, 0x6d, 0xdb, 0x3b, 0x0a
2020-04-05 10:26:44.936 Info, NONCES: 0x26, 0xc3, 0x4a, 0x68, 0xb2, 0x01, 0xa2, 0x2f
2020-04-05 10:26:44.936 Info, NONCES: 0xbb, 0x04, 0xd3, 0x5c, 0x27, 0x9a, 0x7c, 0x5d
2020-04-05 10:26:44.936 Info, NONCES: 0x01, 0x20, 0x21, 0xc8, 0x77, 0xef, 0xe5, 0x79
2020-04-05 10:26:44.936 Info, NONCES: 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2020-04-05 10:26:44.936 Info, Node017, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x11, 0x0a, 0x98, 0x80, 0x01, 0x20, 0x21, 0xc8, 0x77, 0xef, 0xe5, 0x79, 0x05, 0x01, 0x36:
2020-04-05 10:26:44.947 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:26:44.947 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:26:45.076 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x01, 0x00, 0xe8
2020-04-05 10:26:45.076 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2020-04-05 10:26:45.076 Info, Node017, Request RTT 574 Average Request RTT 447
2020-04-05 10:26:45.167 Detail, Node017, Received: 0x01, 0x21, 0x00, 0x04, 0x00, 0x11, 0x19, 0x98, 0x81, 0x2f, 0x7c, 0x3d, 0x90, 0xc8, 0x4b, 0xb5, 0x0f, 0x6f, 0x26, 0x28, 0x03, 0x75, 0xe6, 0x01, 0xd5, 0xa2, 0x9b, 0xe8, 0x6d, 0xba, 0x8a, 0xf2, 0xbb, 0x00, 0xec
2020-04-05 10:26:45.168 Info, Raw: 0x98, 0x81, 0x2f, 0x7c, 0x3d, 0x90, 0xc8, 0x4b, 0xb5, 0x0f, 0x6f, 0x26, 0x28, 0x03, 0x75, 0xe6, 0x01, 0xd5, 0xa2, 0x9b, 0xe8, 0x6d, 0xba, 0x8a, 0xf2, 0xbb
2020-04-05 10:26:45.168 Detail, Node017, Decrypted Packet: 0x00, 0x26, 0x03, 0x20, 0x20, 0x00
2020-04-05 10:26:45.168 Info, Node017, Response RTT 666 Average Response RTT 695
2020-04-05 10:26:45.168 Info, Node017, Received SwitchMultiLevel report: level=32
2020-04-05 10:26:45.168 Detail, Node017, Initial read of value
2020-04-05 10:26:45.168 Detail, Node017, Expected reply and command class was received
2020-04-05 10:26:45.168 Detail, Node017, Message transaction complete
2020-04-05 10:26:45.168 Detail, Node017, Removing current message
2020-04-05 10:26:45.169 Detail, Node017, Notification: ValueChanged
2020-04-05 10:26:45.182 Detail,
2020-04-05 10:26:45.183 Info, Node017, Processing (Send) Nonce Request message (Callback ID=0x52, Expected Reply=0x04)
2020-04-05 10:26:45.183 Info, Node017, Sending (Send) message (Callback ID=0x52, Expected Reply=0x04) - Nonce_Get(MeterCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x11, 0x02, 0x98, 0x40, 0x05, 0x02:
2020-04-05 10:26:45.190 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:26:45.190 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:26:45.309 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x02, 0x00, 0xeb
2020-04-05 10:26:45.309 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2020-04-05 10:26:45.309 Info, Node017, Request RTT 126 Average Request RTT 286
2020-04-05 10:26:45.389 Detail, Node017, Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x11, 0x0a, 0x98, 0x80, 0x99, 0x77, 0x5a, 0x90, 0x6e, 0x73, 0xe0, 0x25, 0xbb, 0x00, 0xad
2020-04-05 10:26:45.390 Info, Node017, Received SecurityCmd_NonceReport from node 17
2020-04-05 10:26:45.390 Info, Node017, Sending (Send) message (Callback ID=0x56, Expected Reply=0x04) - MeterCmd_Get (Node=17): 0x01, 0x0a, 0x00, 0x13, 0x11, 0x03, 0x32, 0x01, 0x00, 0x25, 0x56, 0xb4
2020-04-05 10:26:45.403 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:26:45.404 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:26:45.539 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x56, 0x00, 0xbf
2020-04-05 10:26:45.539 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x56 received (expected 0x56)
2020-04-05 10:26:45.539 Info, Node017, Request RTT 356 Average Request RTT 321
2020-04-05 10:26:45.539 Detail, Expected callbackId was received
2020-04-05 10:26:45.615 Detail, Node017, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x11, 0x02, 0x98, 0x40, 0xb9, 0x00, 0x83
2020-04-05 10:26:45.615 Info, Node017, Received SecurityCmd_NonceGet from node 17
2020-04-05 10:26:45.616 Info, NONCES: 0x03, 0xf3, 0x40, 0x28, 0x4d, 0xa6, 0xb2, 0xd8
2020-04-05 10:26:45.616 Info, NONCES: 0x61, 0x7b, 0xe6, 0x9a, 0xa5, 0x9f, 0xd4, 0x81
2020-04-05 10:26:45.616 Info, NONCES: 0x43, 0x3c, 0x5e, 0x53, 0x6d, 0xdb, 0x3b, 0x0a
2020-04-05 10:26:45.616 Info, NONCES: 0x26, 0xc3, 0x4a, 0x68, 0xb2, 0x01, 0xa2, 0x2f
2020-04-05 10:26:45.616 Info, NONCES: 0xbb, 0x04, 0xd3, 0x5c, 0x27, 0x9a, 0x7c, 0x5d
2020-04-05 10:26:45.616 Info, NONCES: 0x01, 0x20, 0x21, 0xc8, 0x77, 0xef, 0xe5, 0x79
2020-04-05 10:26:45.616 Info, NONCES: 0x89, 0xf0, 0xa7, 0xbf, 0x4c, 0xb2, 0x3e, 0x83
2020-04-05 10:26:45.616 Info, NONCES: 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2020-04-05 10:26:45.616 Info, Node017, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x11, 0x0a, 0x98, 0x80, 0x89, 0xf0, 0xa7, 0xbf, 0x4c, 0xb2, 0x3e, 0x83, 0x05, 0x01, 0xd8:
2020-04-05 10:26:45.627 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:26:45.627 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:26:45.756 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x01, 0x00, 0xe8
2020-04-05 10:26:45.756 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2020-04-05 10:26:45.756 Info, Node017, Request RTT 573 Average Request RTT 447
2020-04-05 10:26:45.913 Detail, Node017, Received: 0x01, 0x2a, 0x00, 0x04, 0x00, 0x11, 0x22, 0x98, 0x81, 0x3b, 0xb7, 0x42, 0x75, 0x1a, 0x07, 0x17, 0xd4, 0x1d, 0x07, 0x42, 0x11, 0x23, 0x32, 0x9e, 0x69, 0x2f, 0x4d, 0x44, 0x37, 0xa6, 0x02, 0xc7, 0x89, 0x6a, 0xfc, 0x22, 0xb0, 0x68, 0xa7, 0x2b, 0xe2, 0xb9, 0x00, 0x71
2020-04-05 10:26:45.914 Info, Raw: 0x98, 0x81, 0x3b, 0xb7, 0x42, 0x75, 0x1a, 0x07, 0x17, 0xd4, 0x1d, 0x07, 0x42, 0x11, 0x23, 0x32, 0x9e, 0x69, 0x2f, 0x4d, 0x44, 0x37, 0xa6, 0x02, 0xc7, 0x89, 0x6a, 0xfc, 0x22, 0xb0, 0x68, 0xa7, 0x2b, 0xe2, 0xb9
2020-04-05 10:26:45.914 Detail, Node017, Decrypted Packet: 0x00, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2020-04-05 10:26:45.914 Info, Node017, Response RTT 731 Average Response RTT 713
2020-04-05 10:26:45.914 Detail, Node017, Refreshed Value: old value=false, new value=false, type=bool
2020-04-05 10:26:45.914 Detail, Node017, Changes to this value are not verified
2020-04-05 10:26:45.914 Info, Node017, Received Meter report from node 17: Energy=0.00kWh
2020-04-05 10:26:45.914 Detail, Node017, Refreshed Value: old value=0.00, new value=0.00, type=decimal
2020-04-05 10:26:45.914 Detail, Node017, Expected reply and command class was received
2020-04-05 10:26:45.915 Detail, Node017, Message transaction complete
2020-04-05 10:26:45.915 Detail, Node017, Removing current message
2020-04-05 10:26:45.915 Detail, Node017, Notification: ValueChanged
2020-04-05 10:26:45.927 Detail, Node017, Notification: ValueChanged
2020-04-05 10:26:45.938 Detail,
2020-04-05 10:26:45.938 Info, Node017, Processing (Send) Nonce Request message (Callback ID=0x53, Expected Reply=0x04)
2020-04-05 10:26:45.938 Info, Node017, Sending (Send) message (Callback ID=0x53, Expected Reply=0x04) - Nonce_Get(MeterCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x11, 0x02, 0x98, 0x40, 0x05, 0x02:
2020-04-05 10:26:45.945 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:26:45.945 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:26:46.049 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x02, 0x00, 0xeb
2020-04-05 10:26:46.049 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2020-04-05 10:26:46.049 Info, Node017, Request RTT 112 Average Request RTT 279
2020-04-05 10:26:46.129 Detail, Node017, Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x11, 0x0a, 0x98, 0x80, 0x7c, 0x28, 0xf1, 0x62, 0x19, 0x3d, 0x9c, 0xd0, 0xbb, 0x00, 0xfe
2020-04-05 10:26:46.130 Info, Node017, Received SecurityCmd_NonceReport from node 17
2020-04-05 10:26:46.130 Info, Node017, Sending (Send) message (Callback ID=0x57, Expected Reply=0x04) - MeterCmd_Get (Node=17): 0x01, 0x0a, 0x00, 0x13, 0x11, 0x03, 0x32, 0x01, 0x10, 0x25, 0x57, 0xa5
2020-04-05 10:26:46.143 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:26:46.143 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:26:46.280 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x57, 0x00, 0xbe
2020-04-05 10:26:46.280 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x57 received (expected 0x57)
2020-04-05 10:26:46.280 Info, Node017, Request RTT 343 Average Request RTT 311
2020-04-05 10:26:46.280 Detail, Expected callbackId was received
2020-04-05 10:26:46.355 Detail, Node017, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x11, 0x02, 0x98, 0x40, 0xb8, 0x00, 0x82
2020-04-05 10:26:46.355 Info, Node017, Received SecurityCmd_NonceGet from node 17
2020-04-05 10:26:46.356 Info, NONCES: 0x03, 0xf3, 0x40, 0x28, 0x4d, 0xa6, 0xb2, 0xd8
2020-04-05 10:26:46.356 Info, NONCES: 0x61, 0x7b, 0xe6, 0x9a, 0xa5, 0x9f, 0xd4, 0x81
2020-04-05 10:26:46.356 Info, NONCES: 0x43, 0x3c, 0x5e, 0x53, 0x6d, 0xdb, 0x3b, 0x0a
2020-04-05 10:26:46.356 Info, NONCES: 0x26, 0xc3, 0x4a, 0x68, 0xb2, 0x01, 0xa2, 0x2f
2020-04-05 10:26:46.356 Info, NONCES: 0xbb, 0x04, 0xd3, 0x5c, 0x27, 0x9a, 0x7c, 0x5d
2020-04-05 10:26:46.356 Info, NONCES: 0x01, 0x20, 0x21, 0xc8, 0x77, 0xef, 0xe5, 0x79
2020-04-05 10:26:46.356 Info, NONCES: 0x89, 0xf0, 0xa7, 0xbf, 0x4c, 0xb2, 0x3e, 0x83
2020-04-05 10:26:46.356 Info, NONCES: 0xb3, 0x29, 0x55, 0x6c, 0x0b, 0x07, 0x7d, 0x7f
2020-04-05 10:26:46.357 Info, Node017, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x11, 0x0a, 0x98, 0x80, 0xb3, 0x29, 0x55, 0x6c, 0x0b, 0x07, 0x7d, 0x7f, 0x05, 0x01, 0x57:
2020-04-05 10:26:46.366 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:26:46.367 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:26:46.496 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x01, 0x00, 0xe8
2020-04-05 10:26:46.496 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2020-04-05 10:26:46.496 Info, Node017, Request RTT 558 Average Request RTT 434
2020-04-05 10:26:46.590 Detail, Node017, Received: 0x01, 0x26, 0x00, 0x04, 0x00, 0x11, 0x1e, 0x98, 0x81, 0xb3, 0xfb, 0xf7, 0xa6, 0x0e, 0xf0, 0x97, 0x6c, 0x5c, 0x8b, 0x04, 0x80, 0xc5, 0xe2, 0xf3, 0xc7, 0x2c, 0x2f, 0x6c, 0xb3, 0x7a, 0x0f, 0x39, 0x02, 0x8e, 0x7b, 0xb3, 0x44, 0xb9, 0x00, 0xbe
2020-04-05 10:26:46.590 Info, Raw: 0x98, 0x81, 0xb3, 0xfb, 0xf7, 0xa6, 0x0e, 0xf0, 0x97, 0x6c, 0x5c, 0x8b, 0x04, 0x80, 0xc5, 0xe2, 0xf3, 0xc7, 0x2c, 0x2f, 0x6c, 0xb3, 0x7a, 0x0f, 0x39, 0x02, 0x8e, 0x7b, 0xb3, 0x44, 0xb9
2020-04-05 10:26:46.590 Detail, Node017, Decrypted Packet: 0x00, 0x32, 0x02, 0x21, 0x52, 0x08, 0x34, 0x00, 0x00, 0x00, 0x00
2020-04-05 10:26:46.590 Info, Node017, Response RTT 653 Average Response RTT 683
2020-04-05 10:26:46.590 Detail, Node017, Refreshed Value: old value=false, new value=false, type=bool
2020-04-05 10:26:46.590 Detail, Node017, Changes to this value are not verified
2020-04-05 10:26:46.591 Info, Node017, Received Meter report from node 17: Power=21.00W
2020-04-05 10:26:46.591 Detail, Node017, Initial read of value
2020-04-05 10:26:46.591 Detail, Node017, Expected reply and command class was received
2020-04-05 10:26:46.591 Detail, Node017, Message transaction complete
2020-04-05 10:26:46.591 Detail, Node017, Removing current message
2020-04-05 10:26:46.591 Detail, Node017, Notification: ValueChanged
2020-04-05 10:26:46.602 Detail, Node017, Notification: ValueChanged
2020-04-05 10:26:46.619 Detail, Node014, Query Stage Complete (Dynamic)
2020-04-05 10:26:46.619 Detail, Node014, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2020-04-05 10:26:46.619 Detail, Node014, QueryStage_Configuration
2020-04-05 10:26:46.619 Detail, Node014, QueryStage_Complete
2020-04-05 10:26:46.619 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2020-04-05 10:26:46.620 Warning, CheckCompletedNodeQueries all=0, deadFound=1 sleepingOnly=0
2020-04-05 10:26:46.620 Detail, Node014, Notification: NodeQueriesComplete
2020-04-05 10:26:46.623 Detail, Node017, Query Stage Complete (Dynamic)
2020-04-05 10:26:46.623 Detail, Node017, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2020-04-05 10:26:46.623 Detail, Node017, QueryStage_Configuration
2020-04-05 10:26:46.623 Detail, Node017, QueryStage_Complete
2020-04-05 10:26:46.623 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2020-04-05 10:26:46.623 Warning, CheckCompletedNodeQueries all=0, deadFound=1 sleepingOnly=1
2020-04-05 10:26:46.623 Info, Node query processing complete except for sleeping nodes.
2020-04-05 10:26:46.623 Detail, Node017, Notification: NodeQueriesComplete
2020-04-05 10:26:46.625 Detail, contrlr, Notification: AwakeNodesQueried
2020-04-05 10:27:11.860 Detail, Node017, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x11, 0x02, 0x98, 0x40, 0xb5, 0x00, 0x8f
2020-04-05 10:27:11.860 Info, Node017, Received SecurityCmd_NonceGet from node 17
2020-04-05 10:27:11.861 Info, NONCES: 0x93, 0xd9, 0x2a, 0xc1, 0x54, 0x81, 0x42, 0x43
2020-04-05 10:27:11.861 Info, NONCES: 0x61, 0x7b, 0xe6, 0x9a, 0xa5, 0x9f, 0xd4, 0x81
2020-04-05 10:27:11.861 Info, NONCES: 0x43, 0x3c, 0x5e, 0x53, 0x6d, 0xdb, 0x3b, 0x0a
2020-04-05 10:27:11.861 Info, NONCES: 0x26, 0xc3, 0x4a, 0x68, 0xb2, 0x01, 0xa2, 0x2f
2020-04-05 10:27:11.861 Info, NONCES: 0xbb, 0x04, 0xd3, 0x5c, 0x27, 0x9a, 0x7c, 0x5d
2020-04-05 10:27:11.861 Info, NONCES: 0x01, 0x20, 0x21, 0xc8, 0x77, 0xef, 0xe5, 0x79
2020-04-05 10:27:11.861 Info, NONCES: 0x89, 0xf0, 0xa7, 0xbf, 0x4c, 0xb2, 0x3e, 0x83
2020-04-05 10:27:11.861 Info, NONCES: 0xb3, 0x29, 0x55, 0x6c, 0x0b, 0x07, 0x7d, 0x7f
2020-04-05 10:27:11.861 Info, Node017, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x11, 0x0a, 0x98, 0x80, 0x93, 0xd9, 0x2a, 0xc1, 0x54, 0x81, 0x42, 0x43, 0x05, 0x01, 0x8f:
2020-04-05 10:27:11.871 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:27:11.872 Detail, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:27:12.007 Detail, Received: 0x01, 0x05, 0x00, 0x13, 0x01, 0x00, 0xe8
2020-04-05 10:27:12.007 Detail, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2020-04-05 10:27:12.102 Detail, Node017, Received: 0x01, 0x2a, 0x00, 0x04, 0x00, 0x11, 0x22, 0x98, 0x81, 0x73, 0x2a, 0xfe, 0x0c, 0xd9, 0x28, 0x1b, 0x58, 0x9c, 0x92, 0x08, 0xb5, 0xdb, 0x41, 0x8d, 0x70, 0x09, 0xb7, 0x73, 0x62, 0x40, 0x5e, 0x45, 0x93, 0x2f, 0xd6, 0x64, 0x2c, 0x26, 0xc4, 0x76, 0xa6, 0xb8, 0x00, 0x6a
2020-04-05 10:27:12.102 Info, Raw: 0x98, 0x81, 0x73, 0x2a, 0xfe, 0x0c, 0xd9, 0x28, 0x1b, 0x58, 0x9c, 0x92, 0x08, 0xb5, 0xdb, 0x41, 0x8d, 0x70, 0x09, 0xb7, 0x73, 0x62, 0x40, 0x5e, 0x45, 0x93, 0x2f, 0xd6, 0x64, 0x2c, 0x26, 0xc4, 0x76, 0xa6, 0xb8
2020-04-05 10:27:12.103 Detail, Node017, Decrypted Packet: 0x00, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2020-04-05 10:27:12.103 Detail, Node017, Refreshed Value: old value=false, new value=false, type=bool
2020-04-05 10:27:12.103 Detail, Node017, Changes to this value are not verified
2020-04-05 10:27:12.103 Info, Node017, Received Meter report from node 17: Energy=0.00kWh
2020-04-05 10:27:12.103 Detail, Node017, Refreshed Value: old value=0.00, new value=0.00, type=decimal
2020-04-05 10:27:12.103 Detail, Node017, Notification: ValueChanged
2020-04-05 10:27:12.114 Detail, Node017, Notification: ValueChanged
2020-04-05 10:27:39.133 Detail, Queuing (Controller) Remove Device
2020-04-05 10:27:39.134 Info, Remove Device
2020-04-05 10:27:39.134 Detail, contrlr, Queuing (Command) ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x58, 0x68
2020-04-05 10:27:39.134 Detail, Notification: ControllerCommand - Starting
2020-04-05 10:27:39.135 Detail,
2020-04-05 10:27:39.135 Info, contrlr, Sending (Command) message (Callback ID=0x58, Expected Reply=0x4b) - ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x58, 0x68
2020-04-05 10:27:39.139 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4b, 0x58, 0x01, 0x00, 0x00, 0xea
2020-04-05 10:27:39.139 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2020-04-05 10:27:39.139 Info, REMOVE_NODE_STATUS_LEARN_READY
2020-04-05 10:27:39.139 Detail, Node001, Expected callbackId was received
2020-04-05 10:27:39.139 Detail, Node001, Expected reply was received
2020-04-05 10:27:39.139 Detail, Node001, Message transaction complete
2020-04-05 10:27:39.140 Detail, contrlr, Removing current message
2020-04-05 10:27:39.140 Detail, Notification: ControllerCommand - Waiting
2020-04-05 10:27:39.141 Info, WriteNextMsg Controller nothing to do
2020-04-05 10:28:22.222 Detail, Node017, AdvanceQueries queryPending=0 queryRetries=0 queryStage=ProtocolInfo live=1
2020-04-05 10:28:22.222 Detail, Node017, QueryStage_Probe
2020-04-05 10:28:22.222 Info, Node017, NoOperation::Set - Routing=true
2020-04-05 10:28:22.222 Detail, Node017, Queuing (NoOp) NoOperation_Set (Node=17): 0x01, 0x09, 0x00, 0x13, 0x11, 0x02, 0x00, 0x00, 0x25, 0x59, 0x8a
2020-04-05 10:28:22.223 Detail, Node017, Queuing (Query) Query Stage Complete (Probe)
2020-04-05 10:28:22.223 Info, Node017, Sending (NoOp) message (Callback ID=0x59, Expected Reply=0x13) - NoOperation_Set (Node=17): 0x01, 0x09, 0x00, 0x13, 0x11, 0x02, 0x00, 0x00, 0x25, 0x59, 0x8a
2020-04-05 10:28:22.231 Detail, Node017, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-05 10:28:22.232 Detail, Node017, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-05 10:28:22.287 Detail, Node017, Received: 0x01, 0x05, 0x00, 0x13, 0x59, 0x00, 0xb0
2020-04-05 10:28:22.287 Detail, Node017, ZW_SEND_DATA Request with callback ID 0x59 received (expected 0x59)
2020-04-05 10:28:22.287 Info, Node017, Request RTT 63 Average Request RTT 248
2020-04-05 10:28:22.287 Detail, Expected callbackId was received
2020-04-05 10:28:22.287 Detail, Expected reply was received
2020-04-05 10:28:22.287 Detail, Message transaction complete
2020-04-05 10:28:22.288 Detail, Node017, Removing current message
2020-04-05 10:28:22.288 Detail, Node017, Notification: Notification - NoOperation
