Has anyone tried the Heatit Z-dim (Thermofloor)? It works in HA, but i get Z-Wave panel says “Unknown: type=0003,id=2200”.
Config parameters is not available.
How do I add it correctly?
I will try to install it in a week or so.
I installed one the other day and it works great. Created a new Open Zwave device xml file to get the config parameters to work but apart from that I think everything like setting dim level etc should work out of the box through zwave auto discovery?
Not sure if it is always the case
I haven’t grotten around to configure it. It works, but no config parameters. Could you share your xml?
Sure, sorry for being slow to reply:
Doesn’t look like the OZW 1.4 device database is being maintained so didn’t create a PR for this.
That is awesome! Thanks!
It actually is, surprisingly. You might get lucky and have a PR accepted. The only objection (I’m speculating) might be that there is no upstream version for 1.6.
