I´m working on migrating fra my old outdated HA server to a new VM with all the updates. Everything works great exept the Z-wave JS integration towards my Heatit Z-TRM3´s. I´ve tried to pair them in all possible ways, and everything seems go work, but when i check HA, there is no entitys there, exept a “ping device” and “dead or alive”. Is seems to go back and forth between dead and alive every few moments.
In the new HA the device (Heatit Z-TRM3) is only called “Node X” (I´ve tried 3 different devices, same error):
Everything is up-to-date… What am I missing?
Debug log:
Logg from re interview:
Abonnerer på Z-Wave JS-loggmeldinger …
Loggnivå endret til: Debug
2022-09-11T19:44:43.684Z CNTRLR [Node 003] Beginning interview - last completed stage: None
2022-09-11T19:44:43.685Z CNTRLR [Node 003] new node, doing a full interview…
2022-09-11T19:44:43.685Z CNTRLR » [Node 003] querying protocol info…
2022-09-11T19:44:43.688Z SERIAL » 0x0104004103b9 (6 bytes)
2022-09-11T19:44:43.689Z DRIVER » [REQ] [GetNodeProtocolInfo]
payload: 0x03
2022-09-11T19:44:43.690Z SERIAL « [ACK] (0x06)
2022-09-11T19:44:43.691Z SERIAL « 0x01090141d39c01040806f2 (11 bytes)
2022-09-11T19:44:43.692Z SERIAL » [ACK] (0x06)
2022-09-11T19:44:43.692Z DRIVER « [RES] [GetNodeProtocolInfo]
payload: 0xd39c01040806
2022-09-11T19:44:43.695Z CNTRLR « [Node 003] received response for protocol info:
basic device class: Routing Slave
generic device class: Thermostat
specific device class: General Thermostat V2
node type: End Node
is always listening: true
is frequent listening: false
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2022-09-11T19:44:43.695Z CNTRLR [Node 003] Interview stage completed: ProtocolInfo
2022-09-11T19:44:43.695Z CNTRLR » [Node 003] pinging the node…
2022-09-11T19:44:43.698Z SERIAL » 0x010800130301002507c4 (10 bytes)
2022-09-11T19:44:43.699Z DRIVER » [Node 003] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 7
└─[NoOperationCC]
2022-09-11T19:44:43.700Z SERIAL « [ACK] (0x06)
2022-09-11T19:44:43.708Z SERIAL « 0x0104011301e8 (6 bytes)
2022-09-11T19:44:43.708Z SERIAL » [ACK] (0x06)
2022-09-11T19:44:43.709Z DRIVER « [RES] [SendData]
was sent: true
2022-09-11T19:44:47.833Z SERIAL « 0x010700130701019d71 (9 bytes)
2022-09-11T19:44:47.834Z SERIAL » [ACK] (0x06)
2022-09-11T19:44:47.835Z DRIVER « [REQ] [SendData]
callback id: 7
transmit status: NoAck
2022-09-11T19:44:47.837Z CNTRLR [Node 003] The node did not respond after 1 attempts, it is presumed dead
2022-09-11T19:44:47.842Z CNTRLR [Node 003] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2022-09-11T19:44:47.842Z CNTRLR » [Node 003] querying node info…
2022-09-11T19:44:47.842Z CNTRLR » [Node 003] pinging the node…
2022-09-11T19:44:47.846Z SERIAL » 0x010800130301002508cb (10 bytes)
2022-09-11T19:44:47.847Z DRIVER » [Node 003] [REQ] [SendData]
│ callback id: 8
└─[NoOperationCC]
2022-09-11T19:44:47.848Z SERIAL « [ACK] (0x06)
2022-09-11T19:44:47.856Z SERIAL « 0x0104011301e8 (6 bytes)
2022-09-11T19:44:47.857Z SERIAL » [ACK] (0x06)
2022-09-11T19:44:47.857Z DRIVER « [RES] [SendData]
was sent: true
2022-09-11T19:44:52.012Z SERIAL « 0x01070013080101a043 (9 bytes)
2022-09-11T19:44:52.013Z SERIAL » [ACK] (0x06)
2022-09-11T19:44:52.013Z DRIVER « [REQ] [SendData]
callback id: 8
2022-09-11T19:44:52.015Z CNTRLR [Node 003] The node did not respond after 1 attempts, it is presumed dead
2022-09-11T19:44:52.017Z CNTRLR [Node 003] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2022-09-11T19:44:52.017Z CNTRLR [Node 003] Interview attempt (1/5) failed, node is dead.
