Heatmiser integration help
Good afternoon
I wonder if anyone could help please.
I am integrating my Heatmiser neo underfloor heating into HA.
I can successfully communicate and get and set temps etc but wanted to know the current state of each room ie is the room being heated or is it off. I have scoured the linked pdf which shows commands without success. Thank you in anticipation.
Andrew
At the first sight, the API works by devices, which are attached to rooms/zones.
{"GET_LIVE_DATA":0} seems to return the status of all devices, including which “zones” they are attached to.
Of interest is also {"GET_DEVICE_LIST":"room name"} which returns the devices by room.
Hi Many thanks for the prompt reply, Unfortunately the ‘’‘GET_LIVE_DATA’’’ seems to return global setting and not room specific data. Once again thank you for taking the time to respond.
Cheers
Andrew
¯\_(ツ)_/¯
The doc says that “The devices section is then duplicated for everything attached to the system.”, including, e.g. "ZONE_NAME": "Bathroom"
If it doesn’t do that…
Hi Chris
Well you certainly sorted the first part of this so thank you, I was sending the request via node-red using TCP and received that data in a debug node. What I didn’t realise was the debug node will only display around 1000 characters and by a bit of coding realised that the string was over 10000. Therefore the individual date for heating zones was actually there.
After quite a lot of splitting and parsing I was greeting the required values but the realised that the final zone (8) the data was missing.
I am presuming that either the Heatmiser has an issue or I am doing something wrong.
Thanks again Chris
