Heaty - a flexible heating control, facilitating schedules and manual intervention
Heaty doesn’t care about the current_temperature attribute at all. This is intended to report back the current temperature as measured by the thermostats temperature sensor and has nothing to do with the setpoint functionality.
You don’t have to wait for appdaemon… Just run
pip install --upgrade appdaemon==3.0.0b5
after you installed hass-apps and you’re fine.
Oh wait, I thought only current_temperature would be 0, but temperature is as well…
You’ll have to try to set the operation mode to on and the desired target temperature via HA’s GUI and then look whether the temperature attribute reports something sensible or not.
Sadly, it doesn’t :frowning: See below.
It just changes the mode and operation_mode, not the temperature. My guess is that this means that I can’t use Heaty for my hot water?
  "aux_heat": "off",
  "unit_of_measurement": "°C",
  "custom_ui_state_card": "state-card-custom-ui",
  "temperature": null,
  "mode": "MANUAL",
  "min_temp": null,
  "supported_features": 2177,
  "max_temp": null,
  "operation_mode": "on",
  "current_temperature": null,
  "friendly_name": "Hot Water",
  "operation_list": [
    "auto",
    "on",
    "off"
But when you set the target temperature via HA’s UI, the hot water gets heated up to that temperature, right?
If yes, you could use Heaty, but have to life with some warnings in the logs. What a damn thermostat…
Ah, no. I think you may have a misunderstanding as to how hot water systems generally work in the UK. Generally speaking, there are two types - on-demand or hot water tank.
On-demand systems (also commonly known as “combi” boilers) heat water whenever it is needed. There is obviously no need for these to have a HA interface.
Rather more old fashioned, and still much, much more common, hot water is heated to a pre-set temperature (either by a boiler - usually the central heating boiler, using a dedicated plumbed circuit - or an electric element eg in summer time) and stored in a tank ready for use. The temperature cannot be changed by the user but is generally hard wired to be 50-60C (not so hot as to scald, hot enough to avoid disease). The user can generally choose the times when the hot water is heated to the pre-set temperature.
So, no - I cannot set a hot water temperature from HA. But I can and do set a schedule for when that water heat exchanging circuit is operating.
I am not at all unusual in this set up. All the main thermostats (even Nest etc) support this behaviour, otherwise they would not sell at all in the UK.
Ok, but then you can at least use Heaty to toggle the operation mode between on and off based on time and replace your existing schedule that way. Just configure opmode_heat: on and opmode_off: off and set a temperature of 0 in the schedule for the times you want the heater to be on. Then just set OFF as a fallback.
Perfect - that is the answer to the question I had. I was not sure whether temperature or current_temperature needed to have a value for the code to work.
I will go back to the Appdaemon beta and do the new virtualenv tomorrow.
temperature should indeed have a value (which it has in your case). If, for any reason, temperature would be missing from the attributes completely, that would cause an endless re-sending of the commands (or at least as often as configured by set_temp_retries). Just take care that you don’t try to set something different than 0 as the temperature, or you’ll face the re-sending problem as well.
OK, so just to be clear - when I want the hot water to be in heat mode I dictate a temperature of 0. And nothing if it is in “off” mode? So a schedule snippet would be something like this? -
    hotwater_winter_default:
      - { weekdays: 1-5, start: "05:45", end: "08:00", temp:  0    }
      - { weekdays: 1-5, start: "12:00", end: "12:30", temp:  0    }
      - { weekdays: 1-5, start: "16:30", end: "20:30", temp:  0    }
      - { weekdays: 6-7, start: "05:45", end: "10:00", temp:  0    }
      - { weekdays: 6-7, start: "12:00", end: "12:30", temp:  0    }
      - { weekdays: 6-7, start: "16:00", end: "20:30", temp:  0    }
This would have the effect of heating the hot water between the times shown and the system being off otherwise?
(Yes, I know this is inefficient coding :slight_smile: )
No, think of what you learned about precedence of rules… How should Heaty know what to do in the times not covered by your rules? You need to add OFF as a fallback.
Here are the latest docs with the installation howto:
http://hass-apps.readthedocs.io/en/latest/getting-started.html
Hey @roschi - OK, I see. Thanks for your forbearance.
So because off_temp defaults to OFF my schedule snippet will actually work - right? (For good order I will actually explicitly include it)
No, it won’t work without a fallback rule that explicitly sets OFF for any time not mentioned before in the schedule.
off_temp: OFF only specifies what to set the thermostats to when the master switch is turned off and has nothing to do with schedules at all.
This wasn’t described correctly in the sample config due to historical reasons, my fault. I now fixed it.
Hi all,
I implemented some enhancements around thermostats which don’t support setting a temperature (as the one @PianSom is using for hot water). Ordinary switch entities should (at least in theory :slight_smile: ) now also work as thermostats when configured appropriately. It would be really cool if some of you could test the new features.
These are the concrete issues:
https://github.com/efficiosoft/hass-apps/issues/15
https://github.com/efficiosoft/hass-apps/issues/16
Best regards
Robert
EDIT: And, of course, you need to install directly from the git repository in order to test the new features. How that works is described in the docs on the Getting started page.
First TRV finally arrived, with a second due today, and a 3rd tomorrow; after that i have a pending order for 8 more; which will get me started.
I have normalised my installation to a Ubuntu Installation on a NUC, and chosen to do the manual install of Hass.IO, now that i understand the approach taken with docker. From here I have installed the container for AppDeamon.
Sitting in my ./homeassistant/appdaemon/apps folder, I cloned in your application with the following command
sudo git submodule add -f  https://github.com/efficiosoft/hass-apps.git hass-apps
Then, in the same ./homeassistant/appdaemon/apps folder, I copied in the sample, and loaders
sudo cp hass-apps/hass_apps/data/hass_apps_loader.py .
sudo cp hass-apps/docs/apps/heaty/sample-apps.yaml heaty.yaml
To refelect the folder structure I then edited the file hass_apps_loader.py
from hass-apps.hass_apps.loader import *
And, also edited the sample file, which i now call heaty.yaml; pointing to my Spirit TRV
# This is a minimal example configuration that does just basic things.
# If you want to have further control over your heatings, use open window
# detection, set temperature based on entity states etc., please see the
# full example below.
heaty_minimal:
  # Obligatory settings that tell appdaemon where to find the app.
  # You shouldn't need to change these two.
  module: hass_apps_loader
  class: HeatyApp
  rooms:
    # Define such a block for each room you want to control.
    office:
      thermostats:
        climate.eurotronic_eur_spiritz_wall_radiator_thermostat_heat:
      schedule:
      # From Monday to Friday, set temperature to 20.5 °C from 7.45 am
      # to 10.00 pm.
      - { temp: 22.5, start: "07:45", end: "22:00", weekdays: 1-5 }
      # On weekends, set temperature to 20.5 °C from 8.15 am to 11.30 pm.
      - { temp: 22.5, start: "08:15", end: "23:30", weekdays: "6,7" }
      # At all other times, set temperature to 16 °C.
      - { temp: 16 }
  #kitchen:
  #  thermostats:
  #    climate.heating_kitchen:
  #  schedule:
Finally, AppDeamon is checking all folders for configurations, so i delete the sample in the docs folder
sudo rm hass-apps/docs/apps/heaty/sample-apps.yaml
With this complete, I then restarted the AppDeamon container, to be greeted with the following log.
It appears that the TRV is updated to the setpoint, but i am not sure why the error
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 03-version-requirements.sh: executing...
INFO: Supervisor version requirements checks passed.
[cont-init.d] 03-version-requirements.sh: exited 0.
[cont-init.d] 20-init-configuration.sh: executing...
[cont-init.d] 20-init-configuration.sh: exited 0.
[cont-init.d] 21-compiled-dir.sh: executing...
[cont-init.d] 21-compiled-dir.sh: exited 0.
[cont-init.d] 30-auto-password.sh: executing...
[cont-init.d] 30-auto-password.sh: exited 0.
[cont-init.d] 31-ha-url.sh: executing...
[cont-init.d] 31-ha-url.sh: exited 0.
[cont-init.d] 50-compiled-symlink.sh: executing...
[cont-init.d] 50-compiled-symlink.sh: exited 0.
[cont-init.d] 80-system-packages.sh: executing...
[cont-init.d] 80-system-packages.sh: exited 0.
[cont-init.d] 81-python-packages.sh: executing...
[cont-init.d] 81-python-packages.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
starting version 3.2.4
[services.d] done.
2018-03-27 13:14:42.657132 INFO AppDaemon Version 3.0.0 starting
2018-03-27 13:14:42.657274 INFO Configuration read from: /config/appdaemon/appdaemon.yaml
2018-03-27 13:14:42.657690 INFO AppDaemon: Starting Apps
2018-03-27 13:14:42.658887 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2018-03-27 13:14:42.665189 INFO AppDaemon: HASS: HASS Plugin Initializing
2018-03-27 13:14:42.665406 INFO AppDaemon: HASS: HASS Plugin initialization complete
2018-03-27 13:14:42.665572 INFO Starting Dashboards
2018-03-27 13:14:42.668185 INFO API is disabled
2018-03-27 13:14:42.671790 INFO AppDaemon: HASS: Connected to Home Assistant 0.66.0.b2
2018-03-27 13:14:42.718688 INFO AppDaemon: Got initial state from namespace default
2018-03-27 13:14:44.715775 INFO AppDaemon: Reading config
2018-03-27 13:14:44.727670 INFO AppDaemon: /config/appdaemon/apps/heaty.yaml added or modified
2018-03-27 13:14:44.727774 INFO AppDaemon: /config/appdaemon/apps/apps.yaml added or modified
2018-03-27 13:14:44.727867 INFO AppDaemon: /config/appdaemon/apps/hass-apps/docs/apps/motion_light/sample-apps.yaml added or modified
2018-03-27 13:14:44.727947 INFO AppDaemon: /config/appdaemon/apps/heaty.yaml added or modified
2018-03-27 13:14:44.728012 INFO AppDaemon: /config/appdaemon/apps/apps.yaml added or modified
2018-03-27 13:14:44.728083 INFO AppDaemon: /config/appdaemon/apps/hass-apps/docs/apps/motion_light/sample-apps.yaml added or modified
2018-03-27 13:14:44.728155 INFO AppDaemon: App 'heaty_minimal' added
2018-03-27 13:14:44.728222 INFO AppDaemon: App 'hello_world' added
2018-03-27 13:14:44.728286 INFO AppDaemon: App 'motion_light' added
2018-03-27 13:14:44.728401 INFO AppDaemon: Adding /config/appdaemon/apps to module import path
2018-03-27 13:14:44.728540 INFO AppDaemon: Adding /config/appdaemon/apps/hass-apps to module import path
2018-03-27 13:14:44.728671 INFO AppDaemon: Adding /config/appdaemon/apps/hass-apps/hass_apps to module import path
2018-03-27 13:14:44.728793 INFO AppDaemon: Adding /config/appdaemon/apps/hass-apps/hass_apps/motion_light to module import path
2018-03-27 13:14:44.728942 INFO AppDaemon: Adding /config/appdaemon/apps/hass-apps/hass_apps/heaty to module import path
2018-03-27 13:14:44.729090 INFO AppDaemon: Adding /config/appdaemon/apps/hass-apps/hass_apps/data to module import path
2018-03-27 13:14:44.729208 INFO AppDaemon: Adding /config/appdaemon/apps/hass-apps/docs to module import path
2018-03-27 13:14:44.729317 INFO AppDaemon: Adding /config/appdaemon/apps/hass-apps/docs/apps to module import path
2018-03-27 13:14:44.729422 INFO AppDaemon: Adding /config/appdaemon/apps/hass-apps/docs/apps/motion_light to module import path
2018-03-27 13:14:44.729535 INFO AppDaemon: Adding /config/appdaemon/apps/hass-apps/docs/apps/heaty to module import path
2018-03-27 13:14:44.730674 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/hass_apps_loader.py
2018-03-27 13:14:44.744765 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/hello.py
2018-03-27 13:14:44.749383 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/setup.py - ignoring
2018-03-27 13:14:44.749503 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/common.py - ignoring
2018-03-27 13:14:44.749616 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/loader.py - ignoring
2018-03-27 13:14:44.749705 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/__init__.py - ignoring
2018-03-27 13:14:44.749789 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/motion_light/app.py - ignoring
2018-03-27 13:14:44.749870 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/motion_light/__init__.py - ignoring
2018-03-27 13:14:44.749947 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/heaty/schedule.py - ignoring
2018-03-27 13:14:44.750019 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/heaty/room.py - ignoring
2018-03-27 13:14:44.750107 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/heaty/util.py - ignoring
2018-03-27 13:14:44.750179 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/heaty/app.py - ignoring
2018-03-27 13:14:44.750249 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/heaty/config.py - ignoring
2018-03-27 13:14:44.750322 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/heaty/thermostat.py - ignoring
2018-03-27 13:14:44.750395 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/heaty/expr.py - ignoring
2018-03-27 13:14:44.750465 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/heaty/__init__.py - ignoring
2018-03-27 13:14:44.750533 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/hass_apps/heaty/window_sensor.py - ignoring
2018-03-27 13:14:44.750601 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/hass-apps/hass_apps/data/hass_apps_loader.py
2018-03-27 13:14:44.750706 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hass-apps/docs/conf.py - ignoring
2018-03-27 13:14:44.750804 INFO AppDaemon: Initializing app heaty_minimal using class HeatyApp from module hass_apps_loader
2018-03-27 13:14:44.809794 INFO heaty_minimal: --- heaty v0.12.4 initialization started
2018-03-27 13:14:44.812218 INFO heaty_minimal: --- Heaty id is: 'default'
2018-03-27 13:14:44.817138 INFO heaty_minimal: --> [office] [climate.eurotronic_eur_spiritz_wall_radiator_thermostat_heat] Received target temperature 22.5.
2018-03-27 13:14:44.829364 INFO heaty_minimal: --- Initialization done
2018-03-27 13:14:44.829460 INFO AppDaemon: Initializing app hello_world using class HelloWorld from module hello
2018-03-27 13:14:44.830167 INFO hello_world: Hello from AppDaemon
2018-03-27 13:14:44.830716 INFO hello_world: You are now ready to run Apps!
2018-03-27 13:14:44.830791 INFO AppDaemon: Initializing app motion_light using class MotionLightApp from module hass_apps
2018-03-27 13:14:44.830938 WARNING AppDaemon: Unable to find module module hass_apps - motion_light is not initialized
2018-03-27 13:14:44.831221 INFO AppDaemon: App initialization complete
2018-03-27 13:14:45.003809 WARNING AppDaemon: ------------------------------------------------------------
2018-03-27 13:14:45.004084 WARNING AppDaemon: Unexpected error in worker for App heaty_minimal:
2018-03-27 13:14:45.004434 WARNING AppDaemon: Worker Ags: {'name': 'heaty_minimal', 'id': UUID('755b51d8-2773-4da9-a033-78a1f187ee36'), 'type': 'timer', 'function': <bound method HeatyApp._publish_state_timer_cb of <hass_apps.heaty.app.HeatyApp object at 0x7f7cf37ff898>>, 'kwargs': {}}
2018-03-27 13:14:45.004626 WARNING AppDaemon: ------------------------------------------------------------
2018-03-27 13:14:45.005253 WARNING AppDaemon: Traceback (most recent call last):
  File "/usr/lib/python3.6/site-packages/appdaemon/appdaemon.py", line 529, in worker
    funcref(self.sanitize_timer_kwargs(app, args["kwargs"]))
  File "/config/appdaemon/apps/hass-apps/hass_apps/heaty/app.py", line 120, in _publish_state_timer_cb
    self.publish_state()
  File "/config/appdaemon/apps/hass-apps/hass_apps/heaty/app.py", line 276, in publish_state
    self.set_app_state(entity_id, state)
  File "/config/appdaemon/apps/hass-apps/hass_apps/common.py", line 105, in set_app_state
    self.AD.set_app_state(entity_id, state)
TypeError: set_app_state() missing 1 required positional argument: 'state'
2018-03-27 13:14:45.005486 WARNING AppDaemon: ------------------------------------------------------------
@DamianFlynn
The docs don’t tell you to copy the whole git repository into the apps directory. :slight_smile: If you follow the official steps, you won’t ever need to edit any *.py file.
Don’t use appdaemon 3.0.0 final, use 3.0.0b5 instead.
You know that you need to compile openzwave yourself to get the spirit thermostats working…
All of this has already been discussed here, but if you have further questions beyond what’s explained in the docs and issues, feel free to ask.
Thank you,
Appears that the Hass.IO supplied AppDaemon has autoupdafed to the latest release, despite the configuration set to not update. I have logged a bug on that issue, and manually rolled back the runtime version.
I understand that i deviated from the guide for installing, but as i wish to keep the upgrading process clean, using the git submodule approach enables me to run a production and development environment with a consistent configuration from GIT.
For the issue with the Spirit thermostats, I was able to accomplish the isolation required, to allow staying current with the HomeAssistant releases, yet benefit from the speed and simplicity of docker. If anyone is curious, this is the step i adopted, and has been working well so far. Eurotronic Spirit temperature not changing
Thanks for all your amazing work on this solution, hopefully something here will be of value to other Hass.io users
cheers
Damian
@DamianFlynn Ok, the submodule approach seems reasonable, but maybe you can clone the repo one directory level above and just symlink hass_apps and hass_apps_loader.py into apps?
And reports of working setups are always welcome. :slight_smile:
Hi Robert,
I want to ask you if it is possible to use dynamic time and temprature setup and take values from HA. That way it would be much more comforable to change the setting instead of editing the configuration files.
Something like examples bellow.
Off temperature:
heaty:
  class: HeatyApp
  off_temp: app.get_state("input_number.summer_temperature")
Schedules:
schedule:
- temp: app.get_state("input_number.bedroom_high_temperature")
  start: app.get_state("input_number.bedroom_hour_first_on")
  end: app.get_state("input_number.bedroom_hour_first_off")
Or even more complex:
schedule:
- temp: app.get_state("input_number.bedroom_high_temperature") if app.get_state("binary_sensor.workday_sensor") == "off" else Ignore()
- temp: app.get_state("input_number.bedroom_low_temperature")
I have to say that I did not yet test myself. And before playing in deep I want to know if I am not trying to go out of the Heaty borders.
Thanks.
Hi @TriStone
This has already been discussed in this thread. Dynamic start/end times are not possible. Heaty works with an event-drivven approach to dynamically configure temperatures. So you’d need to write a rule without start/end time constraints which decides the temperature based on time of the day. The time object is available for that purpose in the evaluation environment of temperature expressions. And then fire a re-schedule event whenever one of the variables involved in the temperature expression changes, just as normal.
Something like this should work:
{ temp: 20 if time.hour >= int(app.get_state("input_number.start_hour")) and time.hour <= int(app.get_state("input_number.end_hour")) else Ignore() }
Or this shorter one:
{ temp: 20 if time.hour in range(int(app.get_state("input_number.start_hour")), int(app.get_state("input_number.end_hour")) + 1) else Ignore() }
Best regards
Robert
